Question about Nokia 6300 Cellular Phone
Get restart again and again nokia6300
When ever i apply themes ,send or recives data through bluethoot,my phone get restart.please give me some solution.
thank you
  • musmac_haide Aug 25, 2008
    i have try but it does't work.someone told me to upgrade my nokia6300 operating system.but i dont have that o.s, can u help to provide me that .
    thank you
  • arifce Dec 18, 2008
    i forget my security coad
  • 199 Answers
Try this, its a hard reset for your phone, to refresh all you application and software but all your data will be lost,
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
While holding these buttons, press the power button and switch on the phone
When the message ‘Formatting’ appears on the screen, release all of the buttons
Posted on Aug 25, 2008
My nokia 3110c phone restarts 2 to 3 times....n then it gets switch off
Hi!
There are many solutions for this issue, please check and try the one that applies. Make sure you back up any data before proceeding.
- Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
- Don't get your phone loaded with too many themes downloaded from the internet or atleast, don't switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
- Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
- Don't try updating of music library frequently or don't often transfer data in/out of your Nokia 3110c phone.
GoodLuck!
eBookBoy
Jul 11, 2011 | Computers & Internet
When i apply theme my phone will restart again and again till i reject my memory card some time it also restart autometically plz solve my this problem plz
i m using nokia 3110c from a long time ago and i also face this problem
but
when i use internet on is and download themes from mobile internet and apply the theme then i did not face this problem
but when i transfer some data from computer to mobile with the data cable or computer bluetooth my mobile do the same it will restart again and again
then i think that it will be a technical problem so
i will say use the mobile internet and download themes and enjoy it and yourself maybe it will help full to you
thankyou
Mar 06, 2011 | Nokia 3110 Cellular Phone
In my phone the theme's are not appling (unable to open corrupted) in nokia 6300
hi
don't try to apply themes with larger size . because some nokia phone will support those themes but will be slow in action. restart your phone and tre to apply the themes. if still having same problem then format your phone. this will fix your phone..
thank you
Dec 20, 2010 | Nokia 6300 Cellular Phone
Nokia 6300 themes not applying
its virus attack. use only authorized themes
May 09, 2010 | Nokia 6300 Cellular Phone
I can't apply the built in themes on my 6300.
check your phone memory specially check your recieved file folder if you have any contains in recived file folder move it to your memory card than try applying theme
Feb 10, 2010 | Nokia 6300 Cellular Phone
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
Hai. In my nokia6300,unable to apply themes
are the themes correct for the phone which is in your case an s40 platform????
go to this site called zedge for themes which are specified for each model
Sep 07, 2009 | Nokia 6300 Cellular Phone
Please help
First go to these sites and downloads the skins for your mobile
http://www.ringtones-direct.com/mobile-phone-themes/motorola-v3i/
http://www.mobileheart.com/cell-phone-themes/819-Motorola-RAZR-V3i-Themes.aspx
After downloading the themes connect your computer to your phone and send the themes to your mobile.....
After sending the files........the place where you have sent the themes click on your recommended theme and choose apply themes and your theme will be applied in your phone
Aug 22, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Nokia 3110 restart problem
please remove memory card from ur phone & check again
gud luck
Jul 29, 2008 | Nokia 3110 Cellular Phone
Nokia 6300 Cellular Phone Logo
114 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
