Question about Canon PowerShot A60 Digital Camera
Screen Line There seems to be a line running horizontal in the viewfinder which is more noticeable outdoors in bright light. It causes a slight blur across the middle of the viewfinder. Is this normal or a defect? Thanks.
I don't think that this is a defect. I own an A60 and there is an horizontal line running through my viewfinder. I use my LCD screen more often then my viewfinder, so I've never seen the blur. However I'm pretty sure that your camera is fine.
Posted on Nov 17, 2006
Horizontal lines appear in newly saved images
the only thing i can think of is the sensor being misconnected or kaput. are you viewing them on the camera screen or a pc? it could also be camara screen...
Jul 05, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
White lights blurring pix when taking pix outdoors
pls confirm ur problem from here
http://www.imaging-resource.com/badccds.html
it is not ur fault my friend thousands are suffering due to this
It is actually CCD Failure !! U ARE LUCKY ! u can get it repaired FREE OF COST from canon just call them on the number if u are in US go to the link below and they will send u postage paid envelope and repair free of cost PLS RATE ME FIXYA for the help dont u think i deserve it
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
pls dont gorget to rate me FIXYA !
Mar 21, 2009 | Canon PowerShot A430 Digital Camera
CCD failure !! thousands having the same problem
samsung will do it free of cost as all are doing it is a manufacturing fault they cant deny it pls contact ur local samsung support centre
see this
pls rate me FIXYA for help !!
Mar 21, 2009 | Samsung L200 Digital Camera
Sony DSC-V1 optical viewfinder has a horizontal line in it
It shouldn't be there, but as the optical viewfinder is completely separate from the photographic light path it's nothing to worry about either.
Normally it's caused by either a hair or fibre which has somehow entered the viewfinder (rare) or more commonly by a fine scratch across the front window to the viewfinder. Also check the rear viewfinder viewing lens as the same damage could occur there but as that lens is relatively protected it's unlikely.
Any further fixing involves dismantling the DSC-V1 and possibly sourcing spares made of purest unobtanium so if the camera works perfectly well then leave the screwdrivers safely in the toolbox for now.
Feb 21, 2009 | Sony Cyber-Shot DSC-V1 Digital Camera
Problems with viewfinder
My 40D cannot start up. There is no response when I push the On/Off button. It remains the same after changing to the full-charged battery which came with the camera.
Thanks for your help.
Sep 03, 2008 | Canon EOS 40D Digital Camera
The image is getting blurred
Hi
The camera may have moved when the picture was taken. Try steadily squeezing the button intead of a quick press.
2.Try using a tripod, this could fix the blurred images.
3. faster shutter speed will be needed if you need to hold the camera, and cannot use a tripod.
4. Main reason for the lines could be that the subject is to bright.
A vertical bar of light(red, purple) appears on the LCD monitor/ in the viewfinder This is a normal occurrence in devices containing CCDs (Digital Cameras) and does not mean a malfunction. (This red bar of light will not be recorded when shooting still photos, but it will be recorded when shooting
movies.)
Solution to the last point would be to try and switch of the flash if it is in use. Turn the ISO setting (50, 100, 200) to a lower one as well.
Hope that helps.
May 26, 2008 | Canon PowerShot Pro1 Digital Camera
Stripes on my Samsung Monitor
The contrast may be to high.
Adjust the brightness and contrast to make it go away but still readable.
if that does not help the FL (backlight) is going and the unit will need to be replaced.
Sorry.
Jan 02, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Very Bright Outdoor Photos with lines
The shutter is stuck. The electronic "noise" created by the solenoid trying to move the shutter blades causes the lines on your pictures. The bright outdoor pictures is due to the fact that the shutter is jammed open. You can try tapping the camera on the sides and bottom. This may jar the baldes loose. Failing that, you will have to find a shop that can obtain a replacement lens assembly for your camera.
Mar 30, 2007 | Casio Exilim EX-S600 Digital Camera
Stray line on viewfinder
These lines are normal. See the last paragraph on page 8 of the D70 manual.
Sep 19, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Canon PowerShot A60 Digital Camera Logo
214 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
