Question about KitchenAid KSRG22FK Side by Side Refrigerator
Icemaker Nothing to do with the thermostat--freezer is working well. Ice maker is not working. Infrared not working sometimes, no water is sent to unit.
  • s19p52 Sep 01, 2008
    I have water coming through on the water dispenser.
    Genius:
  • 2,920 Answers
You may have a clogged water line going to the ice/water dispensor
Posted on Sep 01, 2008
Top ice maker in Samsung RFG298AAPN does not make ice. No water cycles into icemaker. Icemaker has been reset, nothing after 2 days. Should I replace the icemaker or the water valve.
On these models I've noticed that the temperature in the ice maker area warms up due to a ball of ice forming inside the freezer compartment ice maker fan that has vent going to the ice maker. Until it is found whether or not that ball of ice is blocking the vent and fan you won't be able to go to the next step. The switch on the ice maker will test the ice maker by filling it with water and rotating the Forks that dump the ice into the ice bin Appliance 911 Sea Breeze
Aug 31, 2016 | Samsung Refrigerators
Ice maker has built in thermostat that turns cycle on at around 10 degrees F. If freezer temp does not reach that point the ice maker will not cycle. So either the freezer is not cold enough or the thermostat is faulty.
Make sure that the ice maker motor that turns the cams and controls the various stages is also working.
Apr 08, 2017 | Frigidaire 20.6 cu. ft. Top Freezer...
Icemaker stopped producing ice
Your ice maker can be rebuilt. I would disconnect it from the plug and remove it and carefully take it apart. Be careful not to loose the lever arm spring as you disassemble. Look at it once the screws ar removed under the front cover. It is rare to have a defective new water control valve. But once the ice maker is unplugged you will know because the ice maker is what tells the water to come on once the cube rake reaches home position. Sometimes the thermostat that tell the water on is stuck or the micro switch that tells the heater below the ice maker to remain on causing the same symptoms. So it will be most likely the ice maker and less likely the water control valve. The parts are priced so high it is cheaper to buy new than to buy parts. But I have fixed them without replacing parts. Sometimes the micro-switches just get stuck. What to rebuild it and me help you? Sea Breeze
Apr 11, 2010 | Whirlpool ED2FHEXN Side by Side...
No water to ice maker
It will only call for water when the thermostat is satisfied. Now if you advance the icemaker when the ejector blade reaches 10 oclock thats when it should call for water. If you dont here the valve humming then it would be in the water switch inside the icemaker.Also make sure the thermostat is not set too cold. if its too cold it will never satisfy your control.
Manually advance : remove the cover on icemaker then turn the small gear counter clockwise
Oct 04, 2009 | U-Line Icemaker
Icemaker not making ice
check your fill tube
it might be frozen solid
Oct 02, 2009 | Refrigerators
I have a Whirlpool refrige. side by side and the ice maker has stopped working. The infrared light keeps blinking. I have unplugged it a couple of times as well as turned the infrared off. Any advice?
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig
Sep 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Sep 05, 2009 | Whirlpool Refrigerators
Kenmore freezer-on-top icemaker not getting water into icemaker. I replaced the water valve solenoid with a new one, but no change. There is no AC voltage at the solenoid terminals. The icemaker itself...
First check the temperature in the freezer to make sure it is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
If the temperature is ok then the ice maker mold thermostat needs to be replaced. And yes you can replace just the thermostat.
Aug 19, 2009 | Refrigerators
Icemaker on Hotpoint Model HSS25GFPAWW Refrigerator not working
try turning the temperature for the freezer down a little bit. it has to at least be around 17 degrees before the older ice makers start to work.
Jan 20, 2009 | Hotpoint HSS25GFP Side by Side...
Maytag mzd2766gew icemaker
Sounds like you have a bad motor module on the icemaker. Part # is W10122536
Jan 05, 2008 | Maytag MZD2766GES Side by Side...
KitchenAid KSRG22FK Side by Side Refrigerator Logo
159 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
