Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
The stock windscreen on my 08 HD Road Glide has started a whistling noise at intermediate speeds. I can push the top center of the screen slightly and it stops. What is the solution?
  • 216 Answers
Theres only 2 things that can go "wrong" with a windscreen. It can vibrate loose or it can change its position. Try torquing all the fittings first. If that doesnt do it, reposition it (a litttle more upright, I'd guess)
Posted on Aug 24, 2008
Whistling noise under slight acceleration
check for a cracked manifold or cracked flex section at the manifold
it is under load so it is not a vacuum leak as the vacuum is low under acceleration and high under deceleration or idle
indicates a gas leak or possible blockage from failed cat converter
Dec 13, 2017 | Ford F-150 Cars & Trucks
check for a manifold gasket / pipe leak
Apr 04, 2014 | Ford F-150 Cars & Trucks
2002 HD Dyna Super Glide front brake noise at low speed until slight pressure applied to brake lever
If it sounds like "swish-swish" noise, that is nornal for your bike. HD changed the front brakes in the 90's and the result was better stopping performance but there is that darned swishing sound. Don't worry about it, mate, there's nothing wrong with your bike.
Now, if you start to hear squealing when you pull the lever, take the bike to a shop to have the brakes pads replaced. If you feel vibration when you apply the brakes, take it to a shop immediately and have them check the wheel spokes for tightness.
Dec 17, 2009 | 2002 Harley Davidson FXD Dyna Super Glide
When I reach a speed of 30MPH I get a whistling noise
It is now sorted somehow the window had become slightly open and caused the wind noise.
Dec 04, 2009 | 2002 Jaguar X-Type
Tire pressures 08 super glide---stock tires
i put about 32 psi in rear and 30psi in front (cold)
Jul 04, 2009 | 2006 Harley Davidson FLHR Road king
Loud whistling noise while driving.
I think there is a TSB on that problem. If the wind is coming from the passanger side then roll the window all the way down. Put a 2X4 in the door jam. So the 2X4 will be inbetween the the door and the jeep. Push on the top of the door like you are trying to close the door. What you are trying to do and slightly bend the top of the door toward the jeep. But just do it a little at a time.
Jun 01, 2009 | 2000 Jeep Grand Cherokee
Whisling noise coming out of inside the refrigerator. Louder when freezer door is open. maybe ice maker area?
The whistling is caused by the air circulating fan located just behind the light. It is easily accessed by removing the light cover and the two small hex screws above the light. To stop the whistling I simply turned the freezer off and pulled the fan cover out slightly to reveal the fan blades. I then pushed the blades down, toward the bottom of the until the blades stopped and i could feel the shaft slightly protruding from the top of the blades. Repositioning the blade has stopped the incessant whistling. Hope this helps!
Apr 19, 2009 | GE GSL25JFPBS Side by Side Refrigerator
WHISTLING NOISE DAY AND NIGHT IN FREEZER SECTION REFRIGERATOR GE MODEL GSS201BPDWW WHEN MOTOR IS WORKING
Apr 18, 2009 | GE Refrigerators
Bike won't start/clicking coming from starter relay
Have you tried charging the battery or jumpstarting it with another battery?
Mar 27, 2009 | 2002 Harley Davidson FLHR - FLHRCI Road...
Lands Phones Logo
35 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
