I bought the windows vista upgrade and my cd rom will not pick it up. My CD Rom works with everything else .
    President:
  • 1,257 Answers
Are you sure that your  cd rom support dvd's.
cd rom do not support dvd.only combo and dvd writer supports dvd's.
Posted on Aug 24, 2008
No everybody says delete the upper and lower case filters, i dont have any of them listed. mine says no value set. my cd rom work fine then one day stopped i got to use it four times to watch movies. i...
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
hope this helps you
Aug 30, 2011 | Acer Computers & Internet
Upgrade of dvd rom for acer aspire 3000
Does Windows recognize it as something else in the device manager? You probably need to install the right drivers for the drive.
Jan 23, 2008 | Acer Aspire 3000 Notebook
Tip
Upgrade CD/DVD ROM to CD-RW/DVD ROM
I just replaced my original CD/DVD ROM with a Toshiba SD-R2512 CD-RW/DVD ROM in my 1805-S253 running Windows ME. I used "Roxio Easy CD Creator" for writing to CD's. Everything was "plug'n'play" except the bezel that came with the new drive had to be swapped out. Windows ME recognized the new drive immediately and I didn't have to load any new drivers. This upgrade will probably work on other 1800 or 1805 Satellite series machines.
on Apr 13, 2008 | Toshiba Satellite 1805-S253 Notebook
I need solution for this problem immediately I installed windows 7 in my PC. after that in My PC DVD RW is not working.
Was the Windows 7 installed from a clean slate or you upgraded from Vista to Windows 7? If you have upgraded from Vista to Windows 7, then this is definitely a driver problem. You can try to update the driver by going to Device Manager, check if the DVD drive is listed. Pull down the drop down list, and right click on the devices listed under DVD/CD-ROM Drives and choose Update Driver Software.
If the DVD drive came with a software bundle (e.g. Nero Burning Application) Try reinstalling these application under Windows 7 Environment.
Mar 26, 2011 | LG (GCC4521BK) CD-RW/DVD-ROM (Combo)...
Windows crashed total so installed new windows vista pro now my dvd say its only cd and will not write dvd or and tells me no disk in drive when i insert blank dvd
It sounds like you need to upgrade the DVD-ROM drivers on your operating system. You'll need to go to the manufacturer's website to get the drivers for Vista.
1) Determine the manufacturer of your DVD-ROM drive. If you bought the drive separately from the computer, you need to go to the website of the company that made the drive (such as Samsung, Toshiba, etc.). If you bought it as part of a desktop or laptop, go to the website of the company that built the computer (HP, Dell, Lenovo, etc.).
2) Look for a link titled "Support" or possibly "Downloads" in the menu at the top of the webpage.
3) How you find the specific driver for your device will vary depending on which website you are on. Normally you have to enter in the model number of either your computer or DVD-ROM drive and it will show you what drivers are available.
4) Download the driver for Windows Vista (make sure you get the 32-bit version or 64-bit version, depending on your version of Vista)
5) Install the driver, typically by double-clicking the downloaded file and then following any on-screen directions. You'll then most likely have to reboot as well.
Everything should work after this. If you need specific help in finding the driver file to download, you'll need to provide me with the brand and model of your computer or DVD-ROM drive.
Hope that gets you up and running!
Mar 13, 2011 | Computers & Internet
I have lenovo y410 laptop with windows vista installed on it.i changed the os to windows xp ,everything is working fine but the MATSHITE DVD RAM UJ85js is not reading the content of the cd ,but this drive...
Can the "bad" CD-R be properly read on some other computer?
If not, then the disk itself is the problem.
Otherwise, changing from Vista to XP does _NOT_ produce the type of problems that you are reporting.
Mar 22, 2010 | Sony 8x Internal Blu-ray...
Cd wont play
Take the CD-ROM media, and play it in some other computer.
May 18, 2009 | Microsoft Windows? Vista Home Premium...
Canon MP500 all in one printer is not compatible with Windows Vista. Is there a solution for this problem, or do I need to buy a different printer?
My Canon PIXMA MP500, purchased in mid-2006, came with the (then) ScanSoft OmniPage SE2 software on a CD. The PC had WinXP Installed. I had no use for the ScanSoft it so I made no effort to install it.
Fast Forward:
Two PC crashes later, July 2009. Using Win Vista Home Premium
LOST, important WinWord document file, only a hard copy available.
I tried to recover, scanning the "Xerox" copy. The SE Version of OmniPage was very complicated but I succeeded in producing a replacement *.doc file.
It appears that newer editions of WinVista contain the right printer drivers for this Canon Model.
Apr 26, 2009 | Canon Pixma MP500 All-In-One InkJet...
Vista ultimate does not pick up dvd rom
how did you use it? where you using your dvd rom when you were still in vista basic then upgraded it to vista ultimate? if so, probably you havent installed the drivers for your dvd rom after upgrading to ultimate.
Feb 06, 2009 | Sony Optiarc AD-7170S Burner
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
