Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Wont turn on
The green light on power button stays on for 5 seconds and makes a screech sound then the light goes out then the green light and the sound for 5 seconds and the same one more time no picture or sound besides screeching noise
  • surfinboy55 Aug 25, 2008
    My power green blinks and then shuts offf. a service guy wants a lot of money, he says the deflection something has to be replace. Can your company help me get the part and install it????
    Mike
    I do not want to spend 400 dollars.
  • sons5870 May 11, 2010
    The green light comes and stays on for 5 seconds and it makes a fuzzy noise then it shuts itself off
    and will not come back on
  • 69 Answers
There may be a short in the system. Bad news: You should have a licensed pro help you diagnose it and fix it. Good news: its fixable.
Posted on Oct 05, 2008
  • Kevin Croissant Oct 06, 2008
    Another thought:
    Can you tell where that screeching noise is coming from? What part of the tv does it appear to be emanating from?
  • martha wilson May 30, 2013
    aleft side black box kinda in the front or maybe towards the middle
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Why does my vizio tv only stay on for a few seconds before the picture goes fuzzy and the tv makes a very loud screeching noise and shuts itself off
Sounds like the power supply board has gone out. It can probably be replaced, but only by someone qualified to do so.
Oct 21, 2014 | Vizio L32 32 in. LCD HDTV
I am currently working on a Sharp Lc37sb24u. I was originally thinking it had a bad inverter board but now I am not so sure. When I turn the tv on the picture comes up with audio for about 2 seconds the...
Did you check the service manual troubleshooting guide yet. You can try disconnecting the power to the inverter board and see if it will stay on and have sound.
Service manuals:
http://elektrotanya.com/?q=showresult&what=Sharp%20LC37SB24U&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 27, 2011 | Sharp LC37SB24U 37 in. LCD TV
MY TV WONT STAY ON. WE TURN IT ON IT TURNS OFF. WE DID THE RESET SYSTEM BUTTON.
when it shuts off and power light goes off do the self check this model has.
When green light (power) goes out, on front of set press and hold both the menu and Input buttons for at least 5 seconds and release both.
WATCH THE POWER LIGHT closely, the light should blink a two digit error code.
for example, 2 blinks, 2 blinks and a pause, it should repeat the code at least five times.
Let me know what code you detect and I will tell you what it means.
SD TECH
Feb 12, 2011 | Mitsubishi WS-55511 55" Rear Projection...
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
Mid game my console beeped and shutoff. Now it wont eject disk or turn on at all. Light goes Green, Yellow then flashes Red
your PS3 overheated, what you need to do is remove the power cable and hold the power button for 5 seconds to make sure that there is no power left, then plug it back in and press the eject button hold it down, it will power up and eject disk, if that fails, you need to RMA your ps3 to sony or you can try and return it to vendor with the game case or dvd case of the disk that is stuck they should replace both
Jan 03, 2010 | Sony Playstation 3 (PS3) Console
I am attempting to instal a Canon iP4700. Step 3 in the instruction booklet states 'Make sure the Power lamp lights green' After connecting to mains and pressing power button the green light comes on for a...
First try taking the inks out and the printhead and see if power stays on. If so you need a new printhead. the part number is on the side. If not, sounds like a bad power supply.
Nov 06, 2009 | Office Equipment & Supplies
Green power light comes on for a split second, then red.
The power supply (AC adapter) is bad. It has enough power to light the red LED, but not enough to power the TV.http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=12+volt+5+amp+power+supply&_sacat=See-All-Categories
May 23, 2009 | Proscan 19LA25Q 19 in. LCD Television
Tv sound and pic goes out and green light flashes for 38 seconds
I have the same tv and it did the same thing. I replaced my lamp and it corrected the problem.
Jan 25, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
My RCA is screeching
You have a bad colorwheel in the light engine. Due to the complexity of the repair, I suggest you call a tech to check this out
Dec 18, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
143 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
