Question about KitchenAid KSRG22FK Side by Side Refrigerator
Ice maker kitchenaid
Ice maker stopped working.
removed ice maker and ice tray thawed and cleaned. reinstalled ensuring correct installation
new water filter with 8 litres flushed through for air bleeding.
model KSRA25CNSS00
what now? icemaker will not work. Infrared light blinks sometimes, other times is not on at all.
  • s19p52 Aug 24, 2008
    I have tried defrosting the freezer section of the refrigerator--thought maybe the supply line was frozen. The infrared light works sometimes but is not consistent. From other postings this is a persistent problem and really don't want to start trying piece at a time to fix it. Many others have posted the same problem--what is the fix???
    This ice maker is equipped with an infrared sensor to stop the icemaker when the ice bucket is full. The sensor sometimes is blinking, sometimes on solid, and other times not on at all.
  • 1,029 Answers
If the icemaker doesn't make ice but you can see the arm swing into motion and you hear a buzz for about 10 seconds after it is finished, the water valve is asking for water that isn't arriving. This means the valve and the solenoid are probably okay, but the water supply is not. Be sure the water supply line isn't kinked behind or beneath the refrigerator (¼-inch copper tubing is much better than plastic fill line).
2) Check to see if something has caused ice to back up around the mechanism—this can cause the fill tube to freeze, blocking the mechanism. When ice cubes are small and seem to be getting smaller, it generally indicates a frozen fill tube.
3) Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, unscrew the copper line from the back of the refrigerator, put the copper line in a bucket, turn on the valve, and see if pressurized water pours out.
4) Check the tap valve; a bad tap valve may cause the problem where the icemaker's supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a ¼-inch hole (as opposed to the "self-piercing" type). You can do this yourself, or call a repairperson or plumber to install an inline water filter when replacing the valve.
NOTE: The water line attaches to a solenoid at the back of the refrigerator, and then travels to the icemaker. The solenoid may be defective or may not be receiving power. You can try removing the sediment screen inside the solenoid and flushing it with water to clean it; be sure to inspect any seals or diaphragms. Unplug the refrigerator first. Unless you're skilled at home repairs, this job is better left in the hands of an appliance repairperson
Posted on Aug 24, 2008
  • 32 Answers
Here is a solution. On the back of the refridgerator there is a small blue pump that pumps in the water. Does the water on the door dispense or do you not have that feature. If you have no way of knowing, take it off and have it tested. Most of the time it is because of those pumps. I have had to replace many in my years with Sears. Another thing is to make sure the laser lenses that pass between the doors is unobstructed and clean. If the lasers line of sight is obstructed then it thinks the ice bucket is full. My guess, without being there to check is the water pump.
    Genius:
  • 1,011 Answers
Here is ur service manual
get it, solve ur problem
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%202301270.pdf
regards,
dont rate it until u satisfied
    Guru:
  • 1,894 Answers
I think there is a faulty thermostat
please have a check
    Genius:
  • 3,422 Answers
HI,
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
    Master:
  • 848 Answers
Check whether thermostat is working properly ...............
I have a kitchenaid french door KFIS25XVMS9. The ice maker has stopped working.
If ice build up in the supply pipe sounds as water fill valve is dripping
May 22, 2014 | Refrigerators
Ice maker making clicking noises even though water and ice working
Hi orangebomber, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Feb 03, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
Ice maker quit
if ice maker is cycleing then it is either water frozen at the tube where water comes in. if it is then shut off refrig. remove icemaker and thaw tube out with a hair dryer. makeing sure not to melt plastic in the back panel of freezer. if it is plastic. if it is not plugged then it is either a bad water valve or the watervalve switch in the icemaker.
May 26, 2012 | KitchenAid Refrigerators
Ice maker not filling...already turned off ref let set for 3 hours to thaw still not working
Noticed you did not list your model number of
your Kitchenaid Refrigerator. I see a model number KSRD22FKST above your post
is that correct? If yes there are a couple things that may be causing this. If
the ice maker mold/tray is
full of ice and will not
cycle most times the ice maker thermostat Click Here=> KSRD22FKST while there look at item number
27 in photo. That is your ice maker's thermostat that tells the ice maker when
ready to cycle and fill with water again. The part Number is=> 627985
they also request that you order the sealant for ice maker thermostat=
Jan 09, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Ice maker stopped working. removed ice maker and ice tray thawed and cleaned. reinstalled ensuring correct installation model KSRA25CNSS00 what now?
take off the cover to your icemaker and make sure the 2 tabs in the center of the main gear are in tack and not broken or bent. if they are, the ice maker module will need to be replaced. if that is okay, check the fill tube in the back of the freezer that goes to the icemaker and make sure it is not frozen. if it is, it will need to be thawed. your water filter may be plugged and need replaced. if all those are ok, then there may be an issue with the water valve itself. Joe
Nov 18, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice Maker Infrared light doesn't light
Each mold tray has a heating element that is turned on to free the ice cubes from the mold tray and allow them to fall into the ice bucket when the tray is rotated into harvest position. Sounds like that is not being turned on... or is defective..
Sep 18, 2008 | KitchenAid KSRG25FK Side by Side...
You did remember to turn it back on? Mine has a handle that detects when the tray is full and you flip it up to turn it off and down to turn it on. Good Luck
Aug 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker quit - LG refrigerator model LFX25960ST, ice maker PN 5989JB0001A
I have the same problem.
Ice in the gears.
Splash from opening and closing the door when liquid water is present seems to be the logical problem.
I had cleared the ice before, thoroughly dried the icemaker and reinstalled it. It worked until I adjusted the icemaker to make large cubes.
I will reinstall it and see how long it last. I will also complain to Sear about the short life of this device.
Dec 27, 2007 | LG LFX25960ST Stainless Steel French Door...
Ice maker won't fill
leaky solenoid? could cause ice build up
Jul 08, 2007 | KitchenAid Superba Architect KSCS25INSS...
Ice Maker troubles
THERE IS A HARVEST CONTROL (SENSES THAT THE ICE IS PRESENT AND SWITCHES MODE TO HARVEST)... THAT MAYBE THE PROBLEM BEFORE YOU CAN SAY ITS THE MOTOR MODULE. IF YOU HAVE A BAR THAT IS VISIBLE OVER THE BIN ... TRY LIFTING IT ALL THE WAY UP WHEN YOU HAVE ICE IN THE TRAY... IT SHOULD SWITCH THE MODE TO DUMP THE ICE. I NEED TO KNOW IF ANY OF THIS WORKS OR NOT BEFORE I CAN GO FURTHER. GOOD LUCK .... YOU CAN WRITE ReckingerJ@aol.com make sure to type (Fix-Ya) in the subject bar.
May 02, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KSRG22FK Side by Side Refrigerator Logo
216 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
rugby prop
Lawrence Oravetz
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
