SOURCE: unlock code for n73
hi there,
You can try the default 12345 code if you dont ever change it.
br
SOURCE: Unlock & settings restoration code for Nokia 1112
use nokia code generator to find the code to unlock your phone ...........
SOURCE: Set the original factory settings on my nokia n73
Thats very strange. Noka firmwares are not that much different in size. Perhaps this new software added a bunch of Apps to your phone. Select Menu>Applications>app mgr and look at the apps on your phone. For example, there might be a whole bunch of games or Ngage. Delete anything that you don't need. And see if it helps.Don't worry about screwing it up as you can always reflash your phone again.
By the way, Downgrading is not possible with Nokia Software udater. Even with profeccional equipment, its pretty hard to downgrage a N series Nokia phone.
SOURCE: I can't put my nokia 6300 into restore factory settings mode..
The defaulkt security code for Nokia is 12345. You can reset the security code using : *#7328748263373738#. It works on most nokia phones. Worth giving a try.
And if the phone says simcard rejected, then the most common problem is that the phone probably might have been locked. You can get it unlocked for 5 quids in your local market.
