Windows Media Center comes up with Windows Messenger failure, though Messenger is installed and running. This seems to cause the program Guide to be Not Available. Norman
    Master:
  • 397 Answers
Click Start>Run then copy this text into the run box and click OK:
RunDll32 advpack.dll,LaunchINFSection %windir%\INF\msmsgs.inf,BLC.Remove
This will uninstall Windows messenger 4.7 from your machine.
This is Windows messenger and not MSN messenger, Windows messenger comes bundled with all versions of XP and is meant for LAN messenging (your personal network in your home or office, if you have one)
Posted on Aug 24, 2008
Sony VAIO VGC-RB38G PC Desktop needs the media center re-installed
I would seriously doubt that your kids know how to remove Media Center. Maybe they just removed the icon from the desktop. Click Start/My Computer and open the Local Disk C. Look for the Programs File Folder. If you are using Windows 7 or Windows Vista there might be two Program File folders (Program Files and Program Files (x86). Look thru the program files folders for the Windows Media Player Folder or Windows Media Center Folder. Open the folder and look for the Media Player. When you see the Icon you can Right Click on it and select Properties. If the Type of File in the properties windows says Application, that is probably the program that runs. You can close the properties window and double click on the icon and see if it runs.
If it runs, you can close it and go back into the folder and Right Click on the icon and select the option Sent To then select Desktop (create Short Cut). Right Click on it again and select option to Pin To Start Menu.
If you just want to download and install it again.
Get onlineand got to www.google.com In the google search box type: "Download Media Player" or "Download Media Center" (without the quotes). Select a site from Microsoft that will download and install it.
Apr 30, 2012 | Computers & Internet
Windows Live Sign-in Assistant is not working. When I click on it, I get a message prompt that windows live messenger stopped working and I get this following after.. .....C:\Program Files\Windows...
Try installing the program again using the original installation media or contact your system administrator or software vendor for support.
Jul 09, 2017 | Computers & Internet
Windows XP Media Center edition... get a ''Cannot Find Windows Messenger'' error when starting up media center... wouldn't bother me - but my son just got an XBox 360, and it cannot connect to the PC due...
This should a simple fix to enable Messenger if you have your XP disk handy.
Go to "Add/Remove programs"
You will see an add/remove windows components, or something similar.
If the Windows Messenger box is already ticked, untick it and OK it then exit out and go back to this.
Now Tick the box. It may ask you to insert your CD.
Once done, OK it again and restart your PC.
DONE.
If this still causes issues, try downloading Windows Live Messenger (about 175MB) and run it directly from the website. Saving to yourPC has issues and often does not work.
I'm not really clued up with Xbox and other game boxes, so all I have done here is to activate Messenger in one format or another on you PC.
Regards
Jan 15, 2010 | Microsoft Windows XP Media Center Edition...
Live tv skips in media center
no this has no effect. Usually jittery audio is hard drive or resource related as it is writing data and outputting data at the same time.
one reolution may be to scale down the quality of the recording to see if that helps.
Lastly check for updated audio/capture card drivers
Jan 18, 2009 | Microsoft Windows XP Media Center Edition...
Messanger Failure while loading Media Center Setup Wizard
SP3 issue. you can uninstall SP3 and then hide it so that you will continue to receive other updates. Every 2 weeks you should unhide it and try another install. If problem persists you may need to reinstall OS from disk. Follow directions closely so that you won't loose any files.
Dec 30, 2008 | HP Media Center m7260n (EG642AA) PC...
Unable to open live TV in HP PC Media Center
Look at the alerts in the security and firewall of Norton antivirus. It might be blocking it. also keep an eye on your bottom right corner when you attempt the live TV. Norton may be alerting you about the blocks in that area. Make sure you allow those connections. I would check Norton firewall and security before messing with the Windows firewall.
Dec 07, 2008 | Computers & Internet
Media center unable to open messenger
The problem can not and will not be solved by a reinstall of the operating system or a reinstall of messenger. The issue comes from a security update from Microsoft. Go to this link to a blog written by a member of the microsoft Media Center Security Team, it has a couple of easy solutions to the problem. Click on the Registry fix downloads for whatever option you want to use. The fix, in a nutshell, is to either ban the security update from media center OR to stop messenger from being used in media center. Personally, I have no need for messenger let alone using it in media center. Good luck!
Nov 11, 2008 | Toshiba QOSMIO F15-AV201 Notebook
Canon Scanner n650u
Try re-installing the drivers , your crash could of corrupted the installed drivers causing your issues. I have installed Media Center on my Father in Law's cpu and found that it is very unstable at times and also many of his installed programs that worked fine under Win XP SP2 either crash frequently or wont work at all. Driver support is an issue for Media Center IMO. I would recommend if you cannot get the scanner to work after you re-install them , think about changing your OS. Good Luck.
Apr 24, 2007 | Canon CanoScan N650U Flatbed Scanner
Windows Media center recorded TV playback
Some possible causes can be system heat causing the video card to freeze. Sometimes it can also be related to the video driver or MPEG2 decoder. Make sure to use the right decoder and filter for the video playback.
Mar 06, 2006 | Microsoft Windows Media Center Edition...
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
