Question about Roper RAX4232KQ Top Load Washer
Putting cabnit back on
Can not get the cabnit sitting on correctly to get the back on
  • 21 Answers
Flip up the control panel and then tilt the casing forward a bit. slide the casing under the lip of the front of the base.(I just push it with my foot a bit) make sure the tabs at the rear of the base go into the slots in the casing you are trying to put back on. push the clips down and you should be set.
Posted on Dec 29, 2008
How to correctly install the correction tape in a smith corona electric typewriter SD770
you have to turn the spool with the knob untill there is tension on the tape or it won't stay in place
Nov 08, 2011 | Smith Corona Wordsmith 100 Typewriter
How do I replace the lid switch
there should be two screws on the back of the head the plactic piece on the left and right side that hold it down once you undo the screws the head should come up then there is two brass looking clips depending on how old you put your screwdriver in thoughs and unhook them from the cabinet from ther you simple lean the cabinet forward and you have easy access to the switch
Jun 02, 2010 | Roper RAS8244KQ Top Load Washer
GE CAFE dishwasher was installed and I can see the hindge at the bottom of the door. Can it be installed deeper in the cabnit
if it was installed correctly you should only be able to see the hinge uif you were looking at it on a downward diagonal
Nov 16, 2009 | GE Cafe C2S980SEMSS Stainless Steel Dual...
Read the question
Dear FixYa:
Just to let you know, I'm a general contractor in the state of michigan.And after I didn't hear from you
I just made a phone call to reasure myself on my question, because it's been a while since I installed
kitchen cabnits.Almost every spacesaver cord is located on righthand side.
May 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How do I replace the drive coupling?
ok ...unplug unit first...remove the 2 screws on each corner with a phillips head screw driver..if the screws are not in the front console corners there on the back...now flip the console back and let it hang..look at the top of unit remove lid swtch connection..2 gray wires on one side and a brown and greenist,,connnected by a white connector...ok at each end theres a brass clip on booth corners..pry the up with small screw driver...now pull the cabnit toward you,,jus the cabnit ,,move it to the side,,now we have to kneel down,,,the white plastic pump have to be remove,,push the bottom clip down and the upper clip up..i do it with my hand you made need a pair of pliers..dont take the 2 big black hose of pump just let the pump hang,,,ok your going to reach around on the right side of the motor and remove that connection just press down on the top on the connection clip...good ...now remove the motor clips you may have a 1/4 nut driverscrew through the clip ..remove clips the same way you removed pump clips..now change your broken drive coupling...just reverse to put toghter...onthejob please rate on completion..
Jan 31, 2009 | KitchenAid KAWS850L Top Load Washer
Can't remove motor from Whirlpool dryer (LER3624EQ1)
no set screw,,,put the motor back,,,put the motor clip back on...lock it back down...ok now take a wrench and put it on the end of the motor where the belt goes,,if your by your sef,,prop the wrench againt the inner cabnit wall,,,than turn the blower wheel its hard but it will come off you..just lock that motor shaft down,,grip pliers..wracket,,,please use glovers to turn blower wheel..housing is very sharp..onthejob
Jan 24, 2009 | Whirlpool LER4634J Electric Dryer
How to remove fan from dryer motor LGR6611LQ0
ok corvett your there you just jumped one step..put the motor back and put the 2 motor clips back on,,,ok,,,,now you need to hold the belt side with a tool a grip pliers,,a wrectet head with handle turn which ever tool handle so it will hit the side of the cabnit the right side looking from front,,now wedge that tool..be careful go behind ,,put on worh gloves a must the side of blower wheel housing are sharp..caution got your gloves on,,now turn it to the left not the right,,counter clock wise..onthejob
Jan 09, 2009 | Whirlpool LGR6611L Gas Dryer
Lid switch is bad and needs changing
ready ok lets go...hi always unplug unit first,,facing unit take your hand and grasp corner caps on console,,on right and left corner,of console pull firmly and they will un snap..now remove the 2 phillips head screws..flip console back,,dont remove just flip back..now you will see the lid switch connection it has a gray and brow wire with the green ground,,pull apart,,,now there are 2 brass clips at each corner,,pry up with small screwdrivers from front of clips..pull cabnit towards you,,and leave machine..now on the cabnit theres 2 phillips head screws holding switch,,pull wire over 2 clip at recess in cabnit,,reverse to put together,,
Dec 27, 2008 | Kenmore 24032\24036 Top Load Washer
Roper RAX4232KQ Top Load Washer Logo
16 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
