Question about Olympus D-400 Zoom Digital Camera
Download images
Can I download images on a computer equipped with a built-in Universal Serial Bus (USB) port?
    Master:
  • 852 Answers
Yes and no. Although you cannot directly attach the camera to a USB port, you can purchase an Olympus USB SmartMedia Reader that will facilitate the transfer of images via a USB port. For details and system requirements visit our webpage at: http://www.olympusamerica.com/cpg_section/cpg_digital_acc.asp?val1=1&accessory=4
Posted on Aug 31, 2005
Usb port hub does not recognize external hard drive
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.cleverfiles.com/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
hope this helps
Jul 05, 2012 | Rocketfish 4Port HiSpeed USB Hub
Hi sir, I need help on my pc, i install a usb 2.0 pci to usb card on the mother board but cant get it working, i have on device manager under other devices have an exclamation mark on universal serial...
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
http://download.cnet.com/via-usb-2-0/3000-2098_4-10163319.html
Available in this download are drivers for VIA USB 2.0 host controller on a system running on Windows 98/98SE/Me. Due to licensing agreements, USB 2.0 drivers for Windows 2000/XP are not available for download. They are supplied on CD with new mainboards or available through Windows Update. This version is a bug-fixing release.
hope this helps
Jul 30, 2011 | NEC Televison & Video
Compac n6000 usb port problem
The issue could be due to corrupt USB Driver. I will give you a few steps to re-install the Drivers.
Please perform the following steps to uninstall USB Port.
1. Right-click on My Computer icon and select Properties.
2. Click Hardware tab. Click the Device Manager button and double-click the Universal Serial Bus Controllers.
3. Select a device listed under Universal Serial Bus Controller, right-click and Uninstall.
4. Click Yes to confirm the uninstallation of the device.
NOTE: Repeat step 3 and 4 until all the devices under Universal Serial Bus Controller are removed.
The USB port is now uninstalled. Now, restart the system. The system automatically detects and reinstalls the USB port.
Step 2:-
Try the following update for the USB port.
http://support.microsoft.com/kb/822603
Thanks
Rajesh
Jul 13, 2008 | Computers & Internet
USB connection problem using Windows 98 Second Edition.
The cause of this problem can be traced to both the computer's hardware configuration and Windows 98SE (Second Edition). PhotoMAX cameras and other devices featuring USB (Universal Serial Bus) connections may not work with computers running Windows 98 Second Edition and equipped with the following computer hardware: * an AMD processor (350 MHz or higher) * VIA Technologies USB Host Controller or SiS 7001 USB Host Controller To find out what USB Host Controller is on your system: 1. Click Start > Settings and choose Control Panel. 2. Double click the System icon. 3. Choose the Device Manager tab. A window similar to the one shown below appears. 4. Expand the Universal Serial Bus controllers listing by clicking on the "+" sign next to the listing. 5. Note the type of host controller in the listing. The example above shows the SiS 7001 PCI to USB Open Host Controller.
Sep 14, 2005 | Polaroid PhotoMax PDC 1300 Digital Camera
Sep 14, 2005 | Polaroid PhotoMax PDC 1100 Digital Camera
Sep 14, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
Sep 14, 2005 | Polaroid PhotoMax MP3 Digital Camera
Sep 14, 2005 | Polaroid PhotoMax Fun Flash 640 SE Digital...
Download images
Aug 31, 2005 | Olympus D-490 Zoom Digital Camera
Download images
Aug 31, 2005 | Olympus D-460 Zoom Digital Camera
Olympus D-400 Zoom Digital Camera Logo
54 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
