Question about Whirlpool AWM5145/2 Front Load Washer
Machine will not spin
I have had the top of the machine off to make sure tha the belt is still in tact, which it is, bu the machin just will not spin.....can anyone help?
  • Whirlpool Master
  • 5,568 Answers
The lack of spin could be caused by a safety switch that has failed; all machines are equipped to prevent spin if the switch is not activated, normally by a closed lid or door.
If the switch fails (not uncommon) the machine thinks the lid/door is open.
The location of the switch varies widely but is always activated by the closure of the hatch.
Posted on Aug 24, 2008
Washing machine won't wash I.e. bowl won't turn in wash cycle or spin. Fills with water ok. Will drain if start button is reset. Rear panel removed, drive belt in tact.
pull shafe out it is likly broken to find out between timer and shaft look to see if timer move by itself and if it does sorry u have broken shaft
Feb 16, 2013 | Washing Machines
My kenmore 87872800 dryer wont spin. everything else is working but drum wont spin.
Left the top of the dryer top, check to see if the belt isn't broke or loose, if that is in tact try turning the drum by hand to see if it turns easily. if not, the bearing in the back of the drum needs replaced. this is easy to replace, remove the drum by removing the dryer top and then remove the belt, and the drum slides up out of the machine. replace the bearing then reassemble dryer.
Jun 16, 2011 | Dryers
Machine will not spin. Belt is in tact, Drive pulley in place but does pull up and down...Is this correct? Water drains, but no spinning. What other part could be responsible for this issue?
check cuter pin on rocker arm 2 solenoids one cuter pin worn out
to check put in spin cycle open and close cover you should hear click but no spin
Jun 12, 2011 | Admiral AAV7000A
Will not ring out clothes, still wet after spin cycle.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 19, 2011 | Maytag Atlantis MAV6000 Top Load Washer
My machine seems to labor in the kneading cycle, then stops and you hear that engine noise of it trying to knead the dough. I follow the recipe exactly. the machine worked well for about 3 months, the...
Hi, Take the pan out of tha machine and see if the paddle spins freely by hand. If yes that's great...if no then the sealed bearing might be sticking and starting to fail. Next check the tension on the belts. The motor and belts are located in the base of the machine. Be sure to unplug machine and ask someone to help you if you are not mechanically inclined. Hank
Sep 23, 2010 | Black & Decker B2250 Bread Machine
What will cause the drum not to spin during cycle? It spins freely by hand. Belt is in tact and motor shaft turns freely manually?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Sep 15, 2010 | Frigidaire FCCW3000F Front Load Washer
Hotpoint washing machine barrel not turning all other functions OK. Motor, belt drive and bushes look ok new curcuit board replaced any Ideas? Model wma64
could be motor not rotating under pressure. When you say brushes have you removed them from motor to check them, also check they slide in and out thier holders ok, as they may be sticking
Feb 11, 2010 | Hotpoint WMA64 Front Load Washer
Machine makes loud clicking noise when in the spin cycle....tub doesn't spin.
You very well could have a broken belt. Sounds like just your pulley is spinning but not the belt. You will have to remove the rear access panel and take a look.
If belt is still intact, make sure tub and bearigs are not frozen up. Make sure motor pulley spins. You can check power to the motor with a voltmeter.
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Nov 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Creda eco washing machine won't spin
It sounds like it needs new carbons fitting in the motor.
It is a fairly straightforward repair.
Remove the top cover, screws at rear, and slide top cover off towards the rear.
The motor is located at the top right right rear, you will see the drive belt.
Slacken the bolt that holds the motor, and push the motor down towards the top of the drum.
You will see the 2 brush holders, they will be either black or white, pull the wires off the holder terminals, and depress the plastic`lug that holds the brushes in place, slide the brushes out of the motor.
fit new genuine Hotpoint carbons, and follow instructions on packaging. Push the leads back on to the carbon terminals.
Tighten up motor, and make sure the belt is reasonably tight.
Job done.
Test on final spin before you refit top cover.
Plz rate my solution.
Thanks.
Dec 23, 2008 | Washing Machines
Machine will not agitate
most likely it's either a broken belt, or the motor is going out. to check it you need to take the outside casing off, not sure exactly how to do that on that model. Anyway open it up, check under the drum for a belt, if the belt is in tact than it's the motor, in which case. Personally I wouldn't put in the effor to replace. as to where you can get a belt if it is broken, I don't know that either. Good Luck
Jun 20, 2007 | Kenmore 22422 Top Load Washer
Whirlpool AWM5145/2 Front Load Washer Logo
124 people viewed this question
Dan Webster
Dan Webster
Sal De
