Question about Lowrance LCX-15MT GPS Receiver
LCX 15 MT GPS Depth Finder
I have 2 LCX 15 MT GPS Units on my boat and the unit on the console will tell you when turned it on that the program is corrupt and to contact your provider. I did contact the provider twice and about all I got from the support department at lowrance was that parts were hard to come by for this unit. The problem with the unit is that if you turn the unit off there is a flicker on the screen and then it turns off and if the unit is turn back on for an hour or so with the corrupt sign left on/unit turned off and back on the unit will usually come on correctly.
5 Suggested Answers
SOURCE: I have a Lowrance LCX
the nmea network also needs power.
make sure that the power is connected to the unit and to the network
Posted on May 12, 2008
  • 594 Answers
SOURCE: When turning on the Lowrance
here is the link to your the lowrance web site. the trouble shooting guide says that if you tried to it on another boat than you might need to take it in for service. but there is a section that explains how to do a soft reset on the unit. you might try that.
please rate and comment on your experiance with fixya.
Posted on Aug 15, 2008
  • 9 Answers
SOURCE: Lowrance LcX 27C
You need to get a MMC card for it to show Canada.
Posted on Jun 24, 2009
  • 74999 Answers
SOURCE: My Lowrance LMS-332C GPS was
If the GPS works and sonar section does not work at all, check the followings.
1# Check the power cable's connection at the unit. Also check the wiring
2# Make sure the power cable is wired properly. The red wire connects
to the positive battery terminal, black to negative or ground
3# Check the fuse.
4# Measure the battery voltage at the unit's power connector. It should
be at least 10 volts. If it isn't, the wiring to the unit is defective, the
battery terminals or wiring on the terminals are corroded, or the battery
needs charging.
Check whether there have any wiring break, loose. During servicing the boat, there is chance to get the wiring of sonar to sonar sensor at the botom of the boat may have damaged. Check these. OK.
Posted on Aug 29, 2011
Need Lcx 15 mt update 3.6.0
You might find what your looking for here.
Jun 13, 2014 | Lowrance Boating
When turning on the Lowrance the depth indicator will only register 0.0 and continues flashing the number. The Lowrance is a LCX-17M. We tryed the Lowrance on another boat with a working transducer...
Aug 15, 2008 | Lowrance LCX-18C
My depth finder keeps loseing the bottom and just flickers the last reading
Hi, if this happens when stationery check the angle of the transducer, if it only happens when moving check the height of the transducer also. Regards Phil
Jul 02, 2012 | Lowrance Lcx 38c Hd Fish Finder Gps (200...
Lowrance lcx-111c hd, single beam transducer
Hey Tingo,
I have two 113's,, the problem sounds like the transducer is going bad,, Try this.. unplug all your connections,, replug them and see if it helps...
Don't get me started on $$$ updates....
May 15, 2017 | Lowrance Lcx 112c 10.4" Screen Color Gps...
Lowrance depth finder missing adapter cable
I own a 1995 Four Winns and what you need is a Lowrance LSM-1 depth finder unit. It accepts the two pin lead from the transducer and send the depth reading to the dashboard display via the 6-pin connector. There is also a three wire harness (red/blk/wht) that connects to a power supply.
The reason I know all this is my depth finder fried a couple years ago so I removed the Lowrance LSM-1 from the boat in order to find a replacement. Unfortunately, this was an OEM part that is not available from Four Winns or any aftermarket source. Probably your best bet is to look in a boat salvage yard or purchase an aftermarket depth finder.
Jul 28, 2009 | Boating
Gps error message "gps module not responding"
Check the connectors and wiring between the GPS module and sonar unit. If it's an internal GPS module yo may have knocked loose a connector internally.
Jun 01, 2009 | Lowrance LCX-17m Sonar with GPS GPS...
Lowrance 112c gps shuts off when cranking main engine?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} This is very common when using a single battery system in you boat.
If you more then battery connect the fish finder to the second battery.
Or if the Depth finder is connected through the acc. on the boat. The power is being cut off be fore the starter is engaged. By pass this and connect through a correct size fuse.
May 08, 2009 | Lowrance Lcx 112c 10.4" Gps Fish Finder...
Im trying to change my lowrance lcx depth from feet to meters
Press MENU MENU. Scroll down to SYSTEM SETUP. Press the rigth arrow. Scroll to UNITS OF MEASURE. Navigate to depth and select METERS.
Feb 23, 2009 | Lowrance LCX-27C GPS Receiver
Hi i have had the lcx- 15 since 2001. i would like to update the software. plus the latest manual.
Here's the link to then manual =>
There are 3 manuals (pdfs). The first is the manual, the next two are addendums.
Here's the link to software updates page =>
Here's the link to the most current software available from Lowrance =>
Please leave feedback. Thanks in advance.
Dec 07, 2008 | Lowrance LCX-15MT GPS Receiver
Turning on my Lowrance LCX 111HD fish locator creates static with my ICOM M502 VHF Marine radio.
Hello LJones0455. From your detailed attempts there are few options. Position the transducers one foward one aft. Connect the negitives of the battiers to the boat still route both positive & negitive wiring to all devices. Check the continunity of your transducers include flexing while ohming. Let me know of the results.
Oct 07, 2008 | Boating
Lowrance LCX-15MT GPS Receiver Logo
107 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
