Question about HP DeskJet 5550 InkJet Printer
Printer cartridges not moving
NOT REALLY ... the green and red light are still blinking together and ink cartridges are not budging.
i was printing and the paper got jammed; this happened before and i've followed the directions you gave regarding removing the paper. The ink cartridges are all the way to the left and are not moving. When I turn the printer off and then back on, it makes it usual noise but the cartridges are staying put.
any ideas?
  • kyusho70 Aug 24, 2008
    Yeah!! Thanks very much. It worked. I was quite happy when I saw the printer cartridges moving again and the lights stopped blinking.
  • 876 Answers
Try turning the printer off and unplugging it both from the wall and from the computer. Take the paper out.
Open the paper jam door and gently push the paper roller forward or upward until it clicks. Close the paper jam door.
Leave the printer unplugged for several minutes (15). Then plug it back in. Do not turn it back on yet and restart your computer. then turn on your printer.
I hope this reset works for you. You may have to do it more than once. I've been through this one myself.
Thank you for using Fix Ya! Your ratings are always appreciated.
Posted on Aug 24, 2008
  • Gayle Ashbach
    Gayle Ashbach Aug 25, 2008
    That is great. Let me know if you have any future problems and thanks for the great rating!
Dell1110 Laser Printer. Changed Cartridge - New Fuse - Checked twice Simpson 260 No blown fuses on circuit board. (1) Fuse, (2) wire. No burn spots Red & Green lights blink after 10 sec of OR/GR...
If you have flashing RED and GREEN LEDs on your Dell 1110 your printer will need servicing by the Dell service department. It is hard to say what is wrong without looking at the printer in person but those two lights together spell trouble not easily fixed. It could be a damaged circuit board or component. This typically has nothing to do with ink, paper jams, etc.
Regards, Chris
Aug 17, 2011 | Dell 1110 Laser Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Reset. Orange light blinks several times. Then Green. Then orange several times, then... on and on. Cannot reset. All ink cartridges have ink.
count the number of orange flashes in between the green light. two flashes = out of paper, 3=paper jam, 4=empty ink tank, 6=print head not installed, 7=print head defective, 8=waste ink tank is almost full
Jun 08, 2010 | Canon i850 InkJet Photo Printer
Its stop printing and the LED power light green and orange at the center blink, like there is a paper jam.
Feb 11, 2010 | HP DeskJet 1280 InkJet Printer
Epson C88 shows red alternately blinking lights
the problems are :-
  • cartridges are not recognised or installed
  • there is a paper jam.
Feb 05, 2010 | Epson Stylus C88 InkJet Photo Printer
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
EPSON R230 PRINTER
ONCE PRINTE COMMAND IS GIVEN PAPER IS ROLLED IN AND THEN PAPER JAM RED LIGHT BLINKS. CAN NOT PRINT ANYTHING.BUT NOZZLE CHECK PRINT CAN BE PRINTED.
Jul 23, 2008 | Epson Stylus Photo R200 InkJet Printer
Not printing, please help
yohoo
It is usually one of these 3 things. Out of paper, paper is jammed or one of your ink cartridges is out of ink. But make sure your cartridges are seated correctly.
Davecapt
Mar 25, 2008 | Epson Stylus C60 InkJet Printer
Both the Red and Green lights are burning steady
k, heres a long 1...=P
>the green light is just your power light, if it is glowing, its on, if its blinking...its receiving a job/replacing cartridge/charging cartridge/or cleaning heads
>the red light being constant on is any of the following...
-ran out of ink, ran out of paper, or has a paper jam.
hope this helps.
PS: re-manufactured cartridges can not always be trusted...some companies accidentally send empties...simple mix up im sure,we're all human after all, but be on look-out.
Feb 08, 2008 | Epson Stylus C60 InkJet Printer
It will not print.
Hi Greenhorn, Your info is slightly conflicting - I think. As I remember the C60 has just 2 LED's: 1 - Green for Power 2 - Red for Error The third button - Cartridge exchange - has no LED Now it is a while since I looked at a C60 and my brain leaks like a sieve, but that's the way I remember it and feel free to correct me if I'm wrong. The error codes I remember are: Printer status - Indicators - Priority Power - Error Power ON condition On - Ink sequence Blink - Ink Cartridge change mode Blink - Data processing Blink - Paper Out *1 - On Paper jam condition *1 - On Ink end (Black) *1 - On -> Blink Ink level low (Black) - Blink-> Blink Ink end (Color) *1 - On -> Blink2 Ink level low (Color) - Blink-> Blink2 Ink end (Black and Color) - On -> On No Ink Cartridge (Black or Color) *1 - On Maintenance request (Ink Overflow Countererror) *1 Alt Blink Alt Blink Fatal error *1 Off On Special setting Blink2 Blink2
Mar 27, 2007 | Epson Stylus C60 InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
106 people viewed this question
Ben Johnson
