Easy to check. Remove nails from gun and connect to air supply. Using hard rubber pad or soft wood depress and hold trigger and push nailer safety against pad and hold there. The gun will fire but the driver will stay down until you pull back on the gun and relieve pressure on the safety foot. With driver down examine the tip of the driver. It should look square and should extend about 1/4 inch or more past the nose. If tip is broken replace driver. If lots of air is leaking past the nose during test, also replace the lower bumper. Good luck
Most nailers have a two position setting on the trigger to allow for single fire or bump fire. If set on bump fire, the gun will work better when you bump fire the gun instead of placing the gun on the work then depress trigger. Bump fire works best when safety spring has good tension. Easy test. Make sure that the safety spring is in place (with air hose removed, contact foot should spring back quickly when pushed against work). With air connected, hold trigger and quickly bounce the gun against the work. If the gun does not fire when you bump, the trigger is most likely set to single fire. With trigger set to single fire, you must place the gun against the work, then depress trigger. If the gun shoots two nails while set to single fire, most likely worn trigger or worn out trigger valve. These parts are not expensive and are easy to replace. Good luck
Remove nails and air supply. Firmly depress safety foot against work with trigger depressed and make sure that firing pin is pushed all the way in. If firing pin is being activated by safety foot most likely problem is stuck cylinder or head valve. If the gun has been dropped the cylinder my jam. Remove the head and make sure that the cylinder and or headvalve moves and that the driver is not stuck in place. Good luck
If the trigger is set to single fire, you will need to place the gun against the work then pull trigger as you have done. Try setting the trigger to bump fire and try again. If hear a thump inside the gun, remove the head and check that the head valve in not stuck from lack of lubrication. Easy test, remove the nails, remove trigger pin, remove trigger and manually push trigger firing valve. If the gun fires then suspect faulty trigger or safety arm not lifting enought to activate the trigger valve. Good luck
New user will jam the gun/ nails because gun was most likely not bump fired. Placing the gun then depressing trigger will usually cause double fire in the hands of new user. New user should practice on scrap lumber bump firing at many angles till they get the idea; or give them a training period with a nailer that has a single shot trigger (they may develop bad habits with single shot however).
Orings /other parts tend to stick when nailer is new. Dewalt uses some vinyl orings that have been causing premature failure. Be sure to add a few drops of oil when used. Too much oil is not good. Wrong oil will cause orings to swell and cause problems such as yours. Your nailer's firing valve can be reset by rapping the nailer against rubber surface such as a thick rugger mat or coiled rubber air hose. Remove airline and nails, being carefull not to damage the head, rap had against rubber mat and retest gun. If it did not reset rap against nose of gun and test. If no joy, you will most likely need to remove head and manually move cylinder up/down and /or check vinyl orings for failure. Before you try to reset the gun, make sure that the safety is pushing the firing pin all the way in. Air removed, look under the trigger as you push down on safey, if it does go all the way in try bump-firing the gun (for test have nails removed). Hold in trigger and quicky /firmly strike gun against rubber pad. Good luck
This happens sometimes try holding it up against a board with the trigger depressed and then inset the battery.
The goal is to try to force the firing sequence to get the piston back to the right position with corded units this is simply done by attaching the air hose with the trigger pulled this causes air to rush into the gun chamber pushing the piston back and firing a nail out.
The cause of this is a misfire or jammed nail that stopped the piston in the wrong location so air will not build in the chamber correctly.
Professional-grade varieties are automatic, and fire a nail directly upon pulling the trigger. A semi-automatic nail gun is more appropriate for beginners, since it requires a two step process: pull the trigger and then tap the barrel against the wood. This safety feature protects the user from accidentally firing a nail gun and injuring himself or others.
