Question about Fujitsu Siemens AMILO Pro V2000 Notebook
Sound device problem
Windows Media Player cannot play the file because there is a problem with your sound device. There might not be a sound device installed on your computer, it might be in use by another program, or it might not be functioning properly. no sound after installing windows xp but had it before
  • neilwillia00 Aug 30, 2008
    audio device not installed
No Audio output deivice is installed.
Posted on Oct 17, 2008
Windows media player throws error when I play any audio
As you may have already notice, there isn't a problem with your driver.
However to gain a better understand the problem you rule out a couple of things. However, if the this problem is only present in windows media player. Then you should try another play i.e. VLC media player.
1. Go to you device manager and make sure the device is working properly. If not try uninstalling the device, restarted the computer letting windows discover the device again.
2. Next go to windows media player file (press "alt" key to get toolbar in newer version. Select options -> devices select your speaker -> properties and be sure that your audio device is available and selected.
3. Finally if all these options has failed, please use an alternative media like the one mention above (VLC media player).
I hope this have been a great help in your troubles. Please provide feedback on the solution.
Jan 19, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Error ID = 0xC00D11BA, Condition ID = 0x00000000
Your sound card might be in use by another application.
0xC00D11BA: Cannot play the file
your sound device, such as a sound card or sound controller. You may
encounter this error message for one of the following reasons:
Your sound device is in use by another program. Quit other programs that may
be using your sound device, and then try to play the file again.
Your sound device is not functioning properly. To troubleshoot the problem,
see the Sound Troubleshooter in Windows Help or refer to your sound device's
documentation.
You do not have a sound device installed on your computer. Install a sound
Apr 10, 2010 | Microsoft Windows XP Professional for PC
If this is the promblem with any music player in your computer than their is no sound driver installed or some sound files are missing to check if the sound driver is installed you can open the control panel---->sounds and check if the driver is installed if it is not you must install it using the motherboard CD that came along with your Pc
May 28, 2009 | Acer Veriton 7600G PC Desktop
No Sound Can Be Heard
that message usually means that the audio file is the wrong format for that media player you can download a different player that plays that format, go into my computer and pull up the music files that dont play right click on one and select properties and it will tell you its format/file type
May 27, 2009 | HP Pavilion zv6000 Notebook
No audio file will play on WMP, no dvd or audio disk will play...
Windows Media Player cannot play several files in the playlist. This might be caused by one or more problems.
To find information about the specific problems, click the Now Playing tab, and then click the blue or red icon next to each file in the List pane.
In some cases, you might encounter this error message if there is a problem with your sound device, such as a sound card or sound controller. For example:
  • Your sound device requires an updated driver. To determine if an updated driver is available, see Windows Update or see the sound device manufacturer's Web site.
  • Your sound device is not functioning properly. To troubleshoot the problem, see Windows Help and Support or refer to your sound device's documentation.
  • You do not have a sound device installed on your computer. Install a sound device, and then try to play the file again
Mar 31, 2009 | HP Pavilion dv6000z Notebook
I have compaq c700, i have problem with windows media player,,
try updating the version of windows media player to the latest, 7 i think.
Mar 23, 2009 | Compaq Creative Sound Blaster PCI 128...
0xC00D11BA
nese sito los drive del sonido y me da este erro por que no tengo los draiver que puedo aser
Jul 04, 2008 | Acer Aspire 3000 Notebook
Audio
try to uninstall the software and then the soud card of your computer.. then attach it again and install the software.
Mar 25, 2008 | Microsoft Windows Vista Ultimate Edition
I can not play audio files
In the windows media player go to > now playing - more options - devices - speakers then changed the audio device to use your soundcard.
Also, uninstall any other players, they usually interfere with each other.
Windows Media Player cannot play the file because there is a problem with your sound device. There might not be a sound device installed on your computer, it might be in use by another program, or it might...
If you are able to hear sound while starting PC issue is not with sound card. that is installed and working properly. If you are clicking on any file that is not playing then window media player is not supporting that file. If you are directly opening window media player from start>>Program>>access>>>>window player and it is giving error. It mean that your player is corrupted. You can upgrade that with higher version of player by going this link. www.microsoft.com/windows/windowsmedia/9series/player.aspx
Aug 20, 2007 | Toshiba Satellite R10-S802TD Tablet PC
Fujitsu Siemens AMILO Pro V2000 Notebook Logo
268 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
