Question about Danby DPAC8020 Air Conditioner
Danby DPAC8020 loosing it's cool
Have a 5yr old Danby DPAC8020. Been recently using it in the evenings, with the evenings being relatively humid. The compressor will turn off for long periods of time, with the fan remaining on. When the compressor does come on, it blows cool air, but not cold enough to really cool down a room that's less than 200 square feet. It's still venting hot air through the exhaust, but there isn't much water in the tanks in the morning.
Wondering if there is a problem with my unit, possibly with refrigerant coolant getting low or something else.
I would appreciate any suggestions.
  • lopezo100 Sep 07, 2008
    Just as you suggested, there was a lot of dirt build-up, cleaned it and works like a charm......TVM
Had the same problem 5 YR OLD unit and I was sweating. Took off back and side panels. Cleaned out the H2O hose and Took out lots of dirt and grim covering the unit. It seems when the unit is covered with this dirt n grime the auto cut off engages to prevent damage and/or possible fire. After a through cleaning I grabbed for the blanket that evening. Been on 12 hours now and gosh the room is cool,
Posted on Sep 07, 2008
I HAVE MODEL # MPK-10CR IT HAS 2 DRAIN PLUGS ON BACK OF UNIT RECENTLY BOTTEM PLUG HAS BEEN DRAINING NEVER HAS BEFORE IS THERE A PROBLEM ?
Run the fan for 2 hours to evaporate the water that can build up with frequent usage and high humidity days. Also...I would check for blockage in the back line and the side bucket. You can always run weed eater line up to clear the blockage.
Jun 30, 2010 | Danby DPAC8020 Air Conditioner
Danby DPAC8399 Portable Air Conditioner no Cool air
You possibly might have a bad switch or have a dirty ac unit.Try 1st turning off the unit and cleaning the inside ...
May 27, 2010 | Danby DPAC8020 Air Conditioner
I need a manual for everstar model# MPM210crbb6 what site do I go onto to down load the manual
http://safemanuals.com/user-guide-instructions-owner-manual/DANBY/DPAC8020
You have a different unit listed from the header unit. The above site can take you to a site that has one of the manuals. Look in the box on the right and download the Danby unit manual. You can also browse to see if the other one is there too.
Aug 15, 2009 | Danby DPAC8020 Air Conditioner
Using the DPAC 8020 AIR Conditioner (Danby)
these portable units will usually have a knob reading from low to high. set it about half way and adjust as needed. half way is usually low 70's
Aug 03, 2009 | Danby DPAC8020 Air Conditioner
Water tank fills up every 3hrs
The amount of water that is getting extracted from the air in the room is based on how humid the air is. The good news is your unit is really getting quite a bit of moisture out of the air and as such, is working well to cool your room.
It is working as designed. You may want to see if you can connect a hose to a drain port (if yours has that included) to let the unit room longer without the need to drain the condensate (water) every 3 or so hours.
Hope this helps and best regards!
Jul 31, 2009 | Danby DPAC8020 Air Conditioner
Everstar MPK10CR-1 water not draining into receptacle
there is probably alot more humidity in your area this year than in the past. these units will the the condenstion water to help cool themselves by splashing it onto the condensing coil. the unit is apparently making more condesation then it can use os the extra goes into the collection pan. the FIX is hook up the drain hose.
Jul 29, 2009 | Danby DPAC8020 Air Conditioner
Do u put water in everstar mpm-08cr-bb4
No. It pulls water out of the air (dehumidifier) and will fill the bucket pretty quickly on a hot humid day.
Jul 02, 2009 | Danby DPAC8020 Air Conditioner
Need owners manual for Everstar Portable AC MPM1-10CR-BB6
Here's the 34 page manual from Danby Canadian website. =>
http://www.danby.ca/cms/uploads/products/en_manual/DPAC8020.pdf
Please leave feedback. Thanks.
Jan 03, 2009 | Danby DPAC8020 Air Conditioner
Manual
found it here: http://www.retrevo.com/support/Danby-DPAC8020-Air-Conditioners-manual/id/886bh630/t/2/
Jul 01, 2008 | Danby DPAC8020 Air Conditioner
Danby Dehumidifier
I dropped the water bucket by accident on the dehumidifier, and I have the same problem. Here what I found :
First, remove the water bucket and find the circuit diagram, it is very useful.
E1 code is related to the room humidity sensor, E2 code is related to the room temperature sensor and E3 code is related to the safety thermistor sensor. If you have one of these error code displayed, you will probably have to replace the sensor.
The humidity and temp sensors are located on the same board. To access it, remove the water bucket and you will see the 2 screws holding the front panel. Remove the screws, then gently prayed the front panel. Be careful, there is two plastic clip on the top of the panel and they are really easy to break. The board is located at the top right, under the cover. The safety thermistor is located on a pipe on the right side of the dehumidifier.
Aug 02, 2006 | Danby DDR583R Dehumidifier
Danby DPAC8020 Air Conditioner Logo
211 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
