Question about GE Kitchen Ranges
Ticking sound of spark ignitor persists after burner lights (all 4 burners ticking)
  • Anonymous Mar 14, 2014
    Hi I have just spilt cold water on the hob and now the smallest burner, where it spilt is ticking and has been for about 10 mins is there away to stop it
  • 639 Answers
I'm Neil
No problem
There is an electronic problem perhaps a bad igniter!
Call service!
Please rate my solution
Posted on Aug 24, 2008
Top gas cooking range continues to make the ticking sound ( tick-tick-tick) even when all burners are off. There is sparking at all the burners too with the sound, I have removed the electrical plug f
This seems like the burner control valves are not functioning properly. The rear is still working properly so without knowing brand I would say the control valves are defective.
Apr 19, 2017 | Kitchen Ranges
Frigidaire spark ignitor constantly ticks
This usually is the control going bad if the burners not locking out when it sparks, this usually indicates the flame rectification is not getting any or sufficient DC signal back via the burner ground or flame sensor depending on what you have, try reseating the burner ground terminal on the module or circuit board and the burner assembly burnish the surface mating areas to assist the DC signal to get back home to the board or module.
You can run a 105C rated wire from the burner aseembly to the burner ground or ground terminal this helps often, but sounds like the controls going bad.
May 11, 2013 | Stoves Electric Stove With Heater - Blue
Weak ignitor spark at 1 burner
What is the model number of the unit?
Nov 29, 2012 | Kitchen Ranges
Ge profile gas range. one burner with no clicking and no ignition
You may have a bad burner switch. If you turn one of the other burner switches to make the spark modules spark look and see if the electrode is sparking at the bad burner. Most of the spark modules send a spark to all 4 burners when activated. If it sparks when another burner is activated open the valve and see if the burner will ignite. If so you probably have a bad burner switch.
Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Ignitors keep making ticking sound, all burners turned off, won't go in lock position, and one burner will not ignite gas despite constant ticking
Probably a spillage or boil over has clogged the burner and some of the liquid has dampened the shank switch mounted on the burner post. Get a shop vac and clean the burner. Wait a day or 2 and see if the switch stops. OR disable the ticky ticky by removing the bottom drawer and looking for the spark module. Remove one of the hot wires and tape it up. Light the burners like granny does with a match. LOL
Jul 17, 2009 | GE 30 in.Profile JGP945 Gas Cooktop
Ignitor won't spark
Look at the front ignitors that work and look at how they ground. Then, set the back ones up the same way. Make sure the 'arc gap' is the same too.
Jul 02, 2009 | Kitchen Ranges
One of 4 burners doesn't spark/light -- GE JGP979 Cook Top
I am going to assume you hear the "clicking" sound when you try to light the burner.
open the top of the stove. there are four burner. look at the one that is not lighting. use a straighten paper clip open the holes that is directly in-front of the tube that is facing the center of ignitor.
also make sure that the air vent directly behind the knob is fully open.
Mar 30, 2009 | GE 30 in. Profile JGP979 Gas Cooktop
It is not a GE but it is a Jenn-air
It's either a bad spark module or switch.
Nov 17, 2007 | GE 36 in. JGP628 Gas Cooktop
Ticking Sound of spark igniter persists
Our GE cook-top burner igniter has started ticking even when the oven is shut off. Even after cleaning the bottom of controls the ticking persists. Any suggestions? Thanks
Aug 27, 2007 | GE 36 in. JGP628 Gas Cooktop
Kitchen Ranges Logo
138 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
