Home | Dehumidifiers | Haier 30 pint deh...
Dehumidifiers
Problem for Haier Dehumidifiers
Generic problem for all Haier Dehumidifiers
Haier 30 pint dehumidifier continuous dra...
By penguinf1 on Aug 24, 2008
how do i set up my dehumidfier for continuous drain? the owners manual is not clear. i took off the rubber cap in the back & attached a 10 foot length of garden hose but the bucket keeps filling up. i did not receive any drainage hose with unit. should i run it without bucket? i think that unit will not turn on unless bucket is attached. i have read on haier website about 3 foot drainage hose which i did not receive. i tried to email them but did not receive any answer. can you help?
Solution #1
posted on Aug 31, 2008
Somewhat Helpful)
Mike Kolbay
Rank: Guide
Rating: 92%, 6 votes
Many just attach the hose at the reservoir; from your description, Haier apparently has a separate location. Check that the point that the hose attaches has an opening (many don't, they expect you to drill it). It should then drain through gravity. Check to make sure that no part of the drain hose is higher than the bottom of the reservoir, otherwise it can't drain. It won't siphon because each time the the tank empties, the suction is broken and the siphoning can't continue.
Was this helpful?
Yes
No
Popular Solutions for Dehumidifiers
Questions and Unsolved Problems for Dehumidifiers
Answer
I am looking to purchase an everstar airconditioner/dehumidifier. I was looking to see the value if... (More)
Answer
small basement efficiency that is not occupied during cold months, and accumulates mold and paint... (More)
Answer
I have taken apart an Amcor TC100 to clean it. I found a small, shiny, spring-like device lying on... (More)
Answer
how do I put the drain in a zenith zd30
Answer
Dehumidifier fan runs lights turn on but only get about a cup of water after all day running.... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Haier Dehumidifiers:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
