Question about HP Office Equipment & Supplies
Scanner failure - HP Office Equipment & Supplies
  • ravonmusic Jan 31, 2009
    Everytime I try to use the scanner it reads scanner failure
  • 50 Answers
Try doing resetting the peinter. and
Unplug the power source and disconnect from the computer.
press and hold the power biutton for 5 sec and then restart the printer.
check if the bulb of scanner glows or not.
else sanner has gone bad.
Posted on Aug 24, 2008
Whats the meaning of error E0202 canon ir copier
Description
An error occurs during the Scanner Unit (Paper Front) HP detection operation (outward).
E202 -0002 -04 Title Scanner HP error
Remedy 1. Connector disconnection/open circuit of the Scanner HP Sensor (SR2).2. Failure of the Scanner HP Sensor (SR2).3. Failure of the Scanner Motor (M1).4. Failure of the Reader Controller PCB (PCB1).
May 11, 2016 | Canon Office Equipment & Supplies
How do I solve the "scanner failure power off and on again" message for an h.p. 6110 officjet all-in-one printer/scanner/fax?
Hi Paul,
Scanner Failure usually results in Hardware Failure. However there is one step you can try. Try connecting the printer directly to wall outlet or any other power outlet and the issue should be resolved.
Regards,
Sean
Apr 19, 2013 | HP OfficeJet 6110 All-In-One InkJet...
Failure in initialization of Scanner. Scanner is offline or , scanner is turned off.
First check if the scanner is working in 'offline' mode by 'counting' a few pages.
Connect to the comp, if SCSI is the interface, you need to start the scanner first, if USB you can connect the scanner even after comp powering on. If the scanner is not recognised, reinstall driver software and scanning software.
S. Mohan, Chennai, India
Dec 21, 2010 | Canon DR-9080C Path-Through Scanner
Try to copy and get scanner failure motice
scanner failure is a hardawre problem. try to copy again and check if the scanner light is on. once the scanner light is not working then try to return your printer in the store that you have purchased it.
Oct 20, 2009 | HP Officejet 5610 All-In-One InkJet...
What are errors 1to5 and 7to8
1- face down sd ram failure
2 face up dram failure
3 cpu dram failure
Sep 23, 2009 | Kodak i30 Path-Through Scanner
Scanner Failure
Scanner failure means the scanner is not making enough light to see the home position. It happens when the scanner lamp ages or is covered with dust. Cycle power is just power off and on again, and see if it goes away.
Jul 02, 2009 | HP Photosmart C6180 All-In-One InkJet...
Scanner link failure
This scanner requires a "Parallel or Centronics" cable and if you have a newer computer, you may only have USB connections. A "USB to CENTRONICS" cable may do the trick, but I'm not sure. Check on the web for one.
Jun 27, 2009 | Umax Astra 1220P Flatbed Scanner
Scanner failure
you just open start-->settings-->control panel-->scanner and camers
delete old scanner
click add imaging device
you can now reinstall
May 24, 2009 | HP PSC 2175 All-In-One InkJet Printer
Scanner failure
After turning on the printer, I am getting a message stating "scanner failure" turn off printer. Can't do anything else.
Aug 14, 2008 | HP OfficeJet D135 All-In-One InkJet...
Scanner failure
scanner failure, turn unit off and back on, does not help
Oct 01, 2007 | HP OfficeJet d145 InkJet Printer
749 people viewed this question
Ben Johnson
