Question about Magellan RoadMate 360 Automotive GPS GPS Receiver
No sound on GPS
I have reset my Magellan GPS from the factory software installed in the unit and when it cam back on there was no sound no alerts nothing
  • bamps417 Jan 27, 2009
    no sound
The internal memory was formatted. This is a catastrophic occurrence and the most common E-mail message I get asking for help. Look under Bugs on the Tips and Tricks page for some background. Before buying an RM360 on eBay, make sure that it comes with the original Magellan SD map card and not a blank one, and make sure that the original owner did not format it! A formatted unit will not speak or make sounds. Because the RM360 is a discontinued device, Magellan WILL NOT FIX THIS. If you want to attempt a reflash, see the Hacking page.
Posted on Dec 01, 2008
Roadmate 5045 slow after update
Magellan support was actually pretty good helping me with the exact same issue. The problem (at least in my case) was that the map files were fragmented. I tried using the Windows defragmenter, but that made fragmentation even worse! The Magellan support engineer recommended I download UltraDefrag instead:
http://ultradefrag.sourceforge.net/en/index.html
Here's what I had to do to completely resolve my issue:
1. Download and install UltraDefrag
2. Connect my GPS to my PC
3. Move the MAP directory from my GPS drive (J:) to my hard disk
4. In UltraDefrag, make sure Action > Skip removable media is not selected
5. Run the optimizer (Ctrl-F7 or Action > Full optimization) after selecting the GPS drive (J: on my computer)
6. Copy the MAP files back to the J: drive AFTER optimization has completed
I double-checked the fragmentation after the files were copied and got 0%. After disconnecting the GPS from the PC, the unit rebooted and doing an address search no longer takes 15 seconds. POI searchs are also much faster than before.
Feb 19, 2012 | Magellan Roadmate 5045 GPS 5inch Screen...
Tip
How To Reset Your Magellan Maestro/Roadmate GPS Units
Factory Reset
Do not attempt to perform a factory reset on the Roadmate or Maestro GPS units by holding down both the "Reset" and "Power" buttons. This will cause the GPS unit to format its own hard drive. Doing so will erase all data, including the GPS software, from the unit.
  1. Locate the button marked "Reset" on the left, right or bottom of the unit.
  2. Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
  3. If the unit does not reset, immediately press the button again and hold it for up to 10 seconds.
If your Maestro GPS Touch Screen Doesn't work, try performing a Hardware Reset
  1. Remove the Magellan Maestro from the holding cradle.
  2. Hold down the "Power" button on the right side of the device, until the unit powers on.
  3. Straighten the end of a paper clip. Place the paper clip in the reset hole, located on the left side of the GPS unit. Hold down the "Reset" button for 10 seconds. Remove the paper clip.
  4. Turn the Magellan Maestro unit off by holding down the "Power" button. Turn the unit back on again. The device is now reset.
If your Roadmate GPS is locked up, try performing a Hardware Reset
  1. On the RoadMate, press + + - - + -
  2. The "hidden menu" will appear.
  3. From there, you can access the shell and perform a hard reset.
on Feb 15, 2011 | GPS
Magellan 315 frozen
Occasionally, a unit will need to be reset. This can be due to software errors, firmware updates or simply at the command of technical support staff. A reset either will restart the unit, possibly clearing up any minor errors, or will restore the unit to the settings it was built with. There are three major Magellan units, which utilize different methods to perform this task.
Things You'll Need:
  • A thin object (such as a paper clip)
Using the stylus, tap "Main Menu" and select "View."
Tap "Settings," and select "Restore Factory Settings." You will be given the option to confirm this action. Be sure that you want to reset to the settings that the GPS was built with. This action is irreversible.
Tap "Confirm," and the unit will begin to reset.
Tips & Warnings
  • Do not attempt to perform a factory reset on the Roadmate or Maestro GPS units by holding down both the "Reset" and "Power" buttons. This will cause the GPS unit to format its own hard drive. Doing so will erase all data, including the GPS software, from the unit.
Jul 20, 2010 | Magellan GPS 315 GPS Receiver
Turns On but not past the loading screen
Hello :
I recommend you to reset your RoadMate .
To reset your RoadMate please follow these steps :
1: Locate the button marked "Reset" on the left, right or bottom of the unit.
2: Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
3:If the unit does not reset, immediately press the button again and hold it for up to 10 seconds.
NOTE : Please don't attempt to perform a factory reset on the Roadmate or Maestro GPS units by holding down both the "Reset" and "Power" buttons. This will cause the GPS unit to format its own hard drive. Doing so will erase all data, including the GPS software, from the unit.
This solution should help with your problem . If that didn't help , then I recommend you call Magellan service for help .
PLEASE DON'T FORGET TO RATE !
Apr 16, 2010 | Magellan RoadMate 1340 GPS Receiver
My gps is stuck on magellan boot up screen.
turn on your 1210 once it boots to the magellan screen press and hold the power button for about 15 seconds, once it shuts off, power it back on by pressing and holding the power button for up to ten seconds then let it load.
if that fails,power it up and try the reset button, (either on the bottom or on the side)the little pinhole, and use a paper clip to depress the reset
button.
bill
Jan 01, 2010 | Magellan RoadMate 1210 Car GPS Receiver
My magellan GPS Roadmate 1400 hard reset
there is a little pin hole on the side on the unit. you need a paper clip to reset it
May 27, 2009 | Magellan RoadMate 1400 Car GPS Receiver
Stuck on magellan load screen where it says magellan
there should be a small hole eather in the back or side of the unit to insert a tooth pick or something not share to reset the unit to factory defaults.
that should do it
May 13, 2008 | Magellan RoadMate 800 GPS Receiver
https://www.magellangps.com/support/
select: Product Support & Updates
select your unit and download firmware update for you unit
Dec 08, 2007 | Magellan RoadMate 360 GPS Receiver
Magellan Roadmate
Same problem. I finally threw it away and bought another brand GPS
Nov 12, 2007 | Magellan RoadMate 360 GPS Receiver
GPS Logo
201 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
