Question about Apple Mac OS X 10.4
OS X 10.4 PHP MySQL problem
I don’t know what's going on, PHP and MySQL aren't connecting with each other, what could be the cause of this?
    President:
  • 2,336 Answers
To change the location where MySQL creates its socket file, do this:
1. Open your preferred text editor and create a plain text file.
2. Type this text (on two lines as shown):
[mysqld]
socket=/tmp/mysql.sock
3. Save the file as: /etc/my.cnf
To change the location where PHP looks for the socket file, follow these steps:
1. In Terminal: sudo cp /etc/php.ini.default /etc/php.ini
2. Open /etc/php.ini in your preferred text editor.
3. Find the [MySQL] section, and change the mysql.default_socket directive:
4. ; Default socket name for local MySQL connects. If empty, uses
5. the built-in
6. ; MySQL defaults.
7. mysql.default_socket = /var/mysql/mysql.sock
8. Change the permissions on /var/mysql so that www can read the socket, by executing this in Terminal:
sudo chmod 775 /var/mysql
Posted on Aug 26, 2008
Warning: mysqli::mysqli(): (HY000/1045): Access denied for user 'root'@'localhost' (using password: YES)
Open up the PHP Config File Config.php (File name can vary) where the MySQL DB connection details are entered.
Change the machine source name, user name and password as per the current system config.
If still not fixing, go to the PHP line causing the issue and echo the connection details, and see if correct values are there.
Mar 04, 2013 | Computers & Internet
Write a C/C++ program that connects to a MySQL server and checks if the InnoDB plug-in is installed on it. If so, your program should print the maximum number of concurrent threads that the InnoDB plug-in...
I know this is a Homework problem. You aren't going to learn anything if we do it for you. I will give you this hint: There is a C++ library that has to be loaded in the header section in order to access the MySql Functions. It can be done using the core C++ header file for Databases but it is much harder to do. Once you add the proper header it should take you about an Hour to complete the program. Good Luck
Jul 28, 2011 | Computers & Internet
I can't log in, it is saying bad account or password, and then if I hit create new acct it says Warning: mysql_connect(): Too many connections in...
:D
Having a bad day?
Ok, go to IE tools->internet options
Clear your Cache, cookies and History
Close IE
Restart IE
All should be well
If not - the server has reached capacity and no more users can log on at this time and you need to wait.
If this helped please remember to vote
Oct 04, 2009 | Computers & Internet
Installing MySQL on Mac OS X
You can install MySQL on Mac OS X 10.3.x (“Panther”) or newer using a Mac OS X binary package in PKG format instead of the binary tarball distribution. Please note that older versions of Mac OS X (for example, 10.1.x or 10.2.x) are not supported by this package.
The package is located inside a disk image (.dmg) file that you first need to mount by double-clicking its icon in the Finder. It should then mount the image and display its contents.
To obtain MySQL, see Section 2.5, “How to Get MySQL”.
Hope this helps, -- Joe (Access 2003 Examples)
Sep 01, 2008 | Sun MySQL
Php mysql problem
The Error In The Mysql
Now you need to searsh him in :
ftp***************/ /var/www/update.php on line****
exemple :
ftp.fixya.com/dir/car/www/update.php on line 8
This Is an example
Aug 06, 2008 | The PHP Group PHP
Mysql Report Error
An example of getting feedback from MySQL about a PHP problem -
mysql_connect("my.site.com", "username", "password")
This can also be done with this code -
die(mysql_error())
Each of the above lines will return the errors, if you have problems connecting to your MySQL database.
There are many more ways, this is just a taste.
Jul 29, 2008 | Sun MySQL
Connecting html form to Ms-access data base
If, as I suspect, this is for a web form, then it effectively can't be done on a "proper" web server. This is because you cannot install MS Office on an MS server OS (e.g. Server 2003). You need to use MS SQL Server or MySQL instead. If this is for very limited use (i.e. only a few clients at a time), you can use XP running IIS but this is really not a good idea. The sedurity implications don't bear thinking about :) Linking a web page to Access can probably be done using ASP (never even thought of trying it - anyone else here know for sure?) If you are using a Linux web server then it's totally out of the question. Use Webmin or PHPMySQL to set up a MySQL database & PHP to code the linkage between the page and the DB. There are plenty of tools out there that will automate this for you, some of them Open Source and therefore free to acquire.
Sep 26, 2007 | Microsoft Office Standard for PC
Apple Mac OS X 10.4 Logo
164 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
