Sata have no floppy disk can i put drivers on a cd rom
  • supercrook
    supercrook Aug 27, 2008
    thamks i will just bin it
    Problem Solver:
  • 7 Answers
The short answer is no. Because of the aged technology of XP it will only recognize A drive (floppy) . A USB flash drive won't work either. You have to use a slipstrem utility like "nlite" and burn a special XP CD that should have your SATA driver integrated into. You can load the SATA driver from computer makers' support site. If you have a CD burner and a working computer you can make a slipstream XP CD by following the instructions available.
Posted on Aug 24, 2008
Bad Locksum BIOS CD_Rom not found when I try to
it's not locksum ,its Check SUM or CRC errors.
what OP, are you running,? windows what. i guess.
the CMOS battery just died.
install a new one.
all puters this old do that, the battery is good for 7-10 years,
and all fail.
DO NOT FLASH your BIOS, fix the real problem first
when the battery dies, all our bios setting were lost
including boot device, and order
fix battery
then go into BIOS and put back boot order.
Mar 22, 2017 | HP Pavilion a815n (PS512AA) PC Desktop
I need to instal - raid driver-
1. put Motherboard Cd (come with p5rd1vm) in cd/dvd rom.
2. BIOS configure as boot from cdrom.
3. restart machine Motherboard CD boot with press enter
4. command line shows 4 option
5. Select 1st option for exact and proper copy ULi sata driver for winxp.
6. Insert floppy press enter
7.you see d copy procedure.
8.then this floppy insert when winxp setup asking F6 for additional driver.
Jun 17, 2011 | ASUS P5RD1-VM Motherboard
WATS THE PROCEDURE OF INSTALLED SATA DRIVER ON P5RD1-VM?
put the one end SATA cable to the HD and other end to motherboard then connect the sata power cable to the hd as well.
Sep 15, 2009 | ASUS P5RD1-VM Motherboard
I want to reinstall my Y computer but the restore CD does not seem to work. So i tried a new XP cd, but that too could not work as it does not see the SATA hard disk installed. The Bios on the Tecra M9...
Hi, your Windows XP install CD doesn't have SATA drivers for the hard drive included, so it's not able to address your hard drive. You can't disable SATA in the BIOS to make it work since your hard drive is still SATA. You'll need to get a 3.5" floppy disk and drive if your laptop doesn't have one. They make external 3.5" USB floppy drives that will work.
1. download the SATA drivers for your laptop (iastor.sys and inf)
2. copy the drivers to your floppy disk (about 6-7 files)
3. plug the floppy drive into your laptop
4. boot to the Windows XP CD
5. as soon as the installation starts, it asks you to "Press F6 to specify RAID or controller drivers" - Press F6 now
6. When setup asks for it, point it to the floppy drive
7. Installation will continue and find your SATA hard drive
Ta-da! Rock on with your bad self.
May 18, 2009 | Toshiba Tecra M9-S5517X PC Notebook
NO INTTALEDWIN XP IN SATA HDD
you need your windows xp disc preferably slip streamed with SP 2 or SP 3 and then you should be able to install it onto your sata hard drive.
If you are having issues then you may need to extract the sata drivers onto a memory stick or floppy disk and press F6 before windows xp loads and specify to use the sata drivers which you can download from the motherboards manufacturers website generally as a zip file which you will first need to extract into a folder.
If that does not work using the memory stick you can use nlite to slipstream the drivers with your windows xp disc :
Nlite download
if you need more help post back
Apr 11, 2009 | Mercury KVM800M Motherboard
My PC don't recognize HD Samsung Sata II 250gb
If you mean the drivers for your SATA harddisk, you should have gotten a CD with your motherboard that contains drivers they might be labeled as RAID, sata, or EIDE controller. when you click that it should prompt you for a floppy disk to put the drivers on, you need to put a floppy disk in drive A and then extract the RAID drivers to your floppy, when installing windows press F6 at the begining of the installation and it will act like it didn't work for a minute and then it will pop up asking you something, you press S and then you will be asked to insert your floppy disk. It might ask you if you want to install the x86 or x64 drivers, x86 is 32bit and x64 is 64 bit, if you don't know which you are using it should tell you somewhere on your windows disk. another option is to get a sata controller that isn't part of your motherboard, it would be a pci-e card and it would come with drivers. I don't know where you could download your drivers from because I think the driver you need is specific to the type of SATA controller your motherboard has in it, but I do know that seagate and western digital have sata drivers available as well for their harddrives so I don't know what to tell you. best shot is your motherboard driver CD.
Dec 18, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Installation
You need to use floppy disks (called boot disks) to boot DOS with cd-rom drivers, because the win98 cd isn't bootable by default.
I suggest you to go to http://www.bootdisk.com/bootdisk.htm and grab the respective windows 98 boot disk.
You will need a functional computer to write the disk image into the floppy.
After that put the boot order in BIOS as floppy first.
Once you see DOS prompt A:\> just access your cd-rom drive like d: or e: and then type install
WaZZie
Jan 04, 2008 | Microsoft Windows 98 for PC
Trying to install windows xp on SATA hdd wd raptor 74 g , i can see it in biosĀ  but can`t install windows on it, i boot the cd with data lifeguard tool from western digital but nothing....need help
you need to put the sata drivers onto a floppy disk and when it asks during the xp setup do you want to install any 3rd party drivers say yes and load the drivers from the floppy. The sata drivers with the floppy generator should be on the drivers cd you recieved.
Oct 25, 2007 | ASUS S-presso Standard S1-P112...
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
