Question about Ld Asus P5LD2-VM LGA775/945G/DDR2/Dual Core/A&V&L/MATX Motherboard (MOTAS28)
Cant get to bios
Hi, I have an asus p5ld2-vm in a small desck top my problem is that when i turn it on nothing happens at all. the green power led on the motherboard comes on and the fans start up but thats it.I have tried starting it up with no devices connected but I am unable to get to bios as the monitor dose not activate.I have tried reseting the cmos but it will not work, I am at a loss could you please help me.
  • brollys2 Aug 25, 2008
    Hi,Thanks for the sugestion but the monitor and cable are fine and the harddrive does not seem to booting up on start up? anymore more ideas would be helpfull. more info there is no start beep codes and I had just installed windows xp which had a fatal error about two days later and shut down, the rest is history.
    Sergeant:
  • 226 Answers
Is it possible that your monitor is bad? or could the cable connection from the monitor to the computer case be in some fashion defective. Look at the cable end that hooks to the computer for bent pins due to improperly plugging the VGA cable into the computer case. If you find such a bent pin, very carefully try to straighten it out with a very small metal tube like some that come in ball point pins. You will need to be very careful doing this as the pins on the VGA connector are very sensitive to breakage if overly pressured. Make sure all power is turned off before attempting this fix. Also, is your Hard drive running, i.e. does the computer seem to be booting up all the way even tho you can't see any display. Normally during boot up, you will see the case Hard drive LED provide a series of displays, indicating that the hard drive is working and booting up. If these displays are occurring, then the next best guess is the monitor or monitor cable. Also you might be able to straighten the VGA cable pins with a very small set of tweezers or needlenose, but please be careful. It is normal to have what appears to be a missing pin when looking at the VGA connector, don't worry about that. What is wrong tho would be a bent pin.
Hope this has been of help
Posted on Aug 24, 2008
  • Ravel Lively
    Ravel Lively Aug 25, 2008
    yes I will have more suggestions once I look at the specs on your system, Give me a little while to do that please
How to launch the boot menu on asus p5ld2-vm ?
Hi, you can download a manual here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5LD2VM/#download
Please select your windows version.
Select manual and click on global for download.
Unzip the file before you can read it.
Press the delete button when it boots to enter the bios.
The rest you can read in the manual.
Sep 11, 2011 | ASUS P5LD2-VM Motherboard
For P5LD2-VM/S I want to find bios P5LD2VSI.ROM
ftp://ftp.wortmann.de/TERRA_Computersysteme/PCs/Mainboards/ASUS/P5LD2-VM_S/bios0405_rev1.zip
ftp://ftp.wortmann.de/TERRA_Computersysteme/PCs/Mainboards/ASUS/P5LD2-VM_S/bios0705_rev2_rev3_rev4.zip
Mar 21, 2011 | Ld Asus P5LD2-VM/SI Intel ICH7R Chipset...
I have an asus p5ld-vm and it's so old.And texts on the mothoerboard are erased so that i don't know which one is the hdd led place .can you help me?I'm confused
hi Drift.
left side of the power switch pin, is a power led
at the lower side or behind power led is hdd led, right side is the positive pin then left is negative.
Feb 05, 2011 | ASUS P5LD2-VM Motherboard
Hello - my ASUS P5LD2-VM restarting wen i working - were the problem?
this could be the power pact or the prossessor over heating,try and clean as mush dust out. go to bios settig and check do a health check. (switch on and press del to enter bios settings warning do not ajust anything).just see if prossessor is getting above the normal heat temprature of your system.
Dec 12, 2009 | ASUS P5LD2-VM Motherboard
Help find driver
hi! download you motherboard driver from here!
www.nodevice.com/driver/P5LD2-VM/get34084.html - 15k
drivers.softpedia.com/get/BIOS/Asus/Asus-P5LD2.shtml - 55k -
www.driverfiles.net/Bios/ASUS/P5LD2/download/page,sh,30052,172,6,.html - 60k -
Jul 18, 2008 | ASUS P5LD2 Motherboard
P5LD2 DOES NOT PWR ON AFTER INSTALLING CONROE 6700. GREEN STAND BY LED LIGHT IS ON...BUT DOES NOT POWER ON FURTHER THAN THAT. IT WORKED FINE WITH MY P4 HT. WHAT GIVES
Check your motherboard version. Note:
Only PCB R2.0(or higher) support Intel® Core™2 processor
You should find the information between the pci slots Or close to the asus heatsink next to the cpu.
Its quite small text, eg 1.01 1.0 2.0 etc.
If the number is difrent from R2.0 or 2.0 then your motherboard does not support the cpu.
If it is so then you have to change to a difrent motherboard.
Feb 08, 2008 | ASUS P5LD2-VM Motherboard
Slow data transfer rate
Do you have this Bios version? P5LD2-VM BIOS version 1303
Support new CPU's. Please refer to Asus website at: http://support.asus.com/cpusupport/cpusupport.aspx
Your board came out around June-2005 so improvements are here. I'm not saying its all about the CPU & FSB but it may help.
Jan 27, 2008 | ASUS P5LD2-VM Motherboard
Pc restart problem
Yes, your mobo Asus P5LD2-VM support CPUs with Conroe-core ("Core 2 Duo"). http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5LD2-VM But for new CPUs strongly recommended use last BIOS version - 1401 from 2007/08/14. http://dlsvr01.asus.com/pub/ASUS/mb/socket775/P5LD2-VM/P5LD2-VM-1401.rar
Oct 03, 2007 | ASUS P5LD2-VM Motherboard
Ld Asus P5LD2-VM LGA775/945G/DDR2/Dual Core/A&V&L/MATX Motherboard (MOTAS28) Logo
224 people viewed this question
Top Ld Computers & Internet Experts
David Payne
David Payne
Are you a Ld Computer and Internet Expert? Answer questions, earn points and help others
