Question about Apple MacBook Mac Notebook
Macbook Airport Problems
My macbook occasionally loses wireless connection, unless I reconnect it manualy, it won't reconnect.
Two questions -
A – Way does it keep losing the connection?
B – Why doesn't it reconnect automatically when the signal is back?
  • Anonymous Aug 25, 2008
    I have the same set of problems with a macbook that until a couple of days ago worked flawlessly with the wireless network. I have reset the airport box back to factory presets and reconfigured it. The home PC and iphone work perfectly since the reconfigure but the macbook remains seriously flakey. I have reached the limit of my knowledge on wireless networks and may be forced to ask apple for help!
    Novelist:
    Champion:
  • 382 Answers
You should check to see if you have the connection set to static or to scan. Your computer could be set to scan, and so when it recieves a stronger signal, even if it is for a second, it will disconnect from the signal you have current. You can go to system preferences , select NETWORK, go to show, then AIRPORT, make sure your signal of choice is at the top of the list.
Posted on Sep 01, 2008
I keep losing my wifi connection
try reseating the wireless card or airport card. if that doesnt work. turn off your wireless router and your macbook. leave off for 10 mins then turn on the router first then macbook. try to connect and see if that fixes the problem.
Dec 19, 2012 | Apple MacBook Air
Apple Macbook Pro does not connect to wireless network
The antennas in the Macbook Pros have had an issue with reception due to the aluminum housing of the laptop but, should still receive decent reception just not as much as a plastic Macbook or plastic PC laptop. It could be possible that the antenna's cables have become disconnected from the Airport Extreme card inside your Macbook Pro, that the card itself is faulty or damaged or that the Antennas themselves have been damaged in some way. As always make sure you have the latest updates and have installed any driver updates from Apple regarding your Airport Extreme card. Here's an article that may help eliminate any wireless interference that may be affecting your signal strength. Apple - Wireless Interference hope this helps, if so don't forget to comment, vote, etc. Thank you.
May 28, 2010 | Apple MacBook Mac Notebook
My older G4 white 12"macbook laptop drops the wireless connection
try to update the Mac Os x and also the airport card drive.This can solve the issue
Feb 20, 2010 | Apple MacBook Mac Notebook
Swapping MacBook Screens
As long as the lcd cable connects to the new screen it should work just fine. Just power it on before putting all the screws back to make sure.
In regards to the wireless I don't understand the question completely. The 2006 will probably only have two wires...just make sure they go where the white and black ones did. You'll just lose a lot of the "N" network strength.
Hopefully that answers you questions. If not, let me know.
--RescueTechLA
Nov 29, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Airport connection says Connection Timed Out.
I don't think this is a problem with your macbook, it is probably a problem with the wireless router that is broadcasting the connection. Try restarting the router and connecting then.
Jul 02, 2009 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Macbook will not connect to wireless connection.
Try to use NetSpot app (it is free) http://www.netspotapp.com/
May 06, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Macbook airport tooooo slow
When your MacBook Air is showing some performance issues, it can be caused by either hardware or system problems. If you don't want to pay for hardware upgrade, then try cleaning the system to improve the Macbook speed. Learn more here: http://www.speedupmacbook.com/speed-up-macbook-air.html
Feb 24, 2009 | 2wire HomePortal® 1800HW Router...
Macbook 13.3" won't log in to wireless
is it a airport used or a router? if so, have you tried to reset it?
Feb 18, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Could not connect to campus wifi through leopard
You may need to access the network with the ASCII password. Is there a system administrator you can contact to get this code? It will be a very long string of characters and replaces the typical password you seen in many Airport type setups.
Aug 28, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Macbook airport
you should try a software update first along with a PRAM and SMC update (hold the power button down when the computer is off for 15 seconds-it will beep. immediately after that hold down the Apple, option, P and R keys simultaneously until the computer reboots and chimes 3 times)
Jun 02, 2008 | Apple Customized 13 MacBook Notebook...
Apple MacBook Mac Notebook Logo
553 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
