Question about Kitchen Ranges
The oven has switched itself off when being used for more than 30 minutes. When it has cooled down it switches back on again.
  • 639 Answers
I'm Neil
No problem
There may be an electronic problem perhaps a bad !
Call service!
Please rate my solution
Posted on Aug 24, 2008
Door locked after self clean cycle.
Ensure you let the oven cool down completely after a clean cycle before trying to open the door.
If the door still won't open after a couple hours of cooling down, then go to the main power panel in your house and shut off the breaker to the oven. Leave it off for 5 minutes, then switch it back on again.
Then try the oven door again.
Good luck.
Feb 28, 2011 | Viking Ovens
Hello, i have a stoves q720 grf do double oven and the problem is with the lower oven, after about 20 minutes the oven switches itself off and the lights on the front of the oven flash on and off. van...
I have the same problem. After anywhere from 5 to 30 minutes the oven(s) switch off and the light and clock start flashing - I have to switch the cooker on and off to start using the oven again.
Any resolution please?
Oct 07, 2010 | Stoves 720EF Electric Double Oven
Stoves 900DFa oven cuts out
Hi.
The most probable cause is failure in your panel cooling fan 9not the one inside your oven)
If the appliance switches on again after 15 - 20 minutes then the fault is most likely here.
Unfortunately as you have gas the you will need a Gas Safe Certified engineer to repair
Regards
aardvark repairs
Nov 18, 2009 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Keeps going off when above 180 degrees, then back on again after 10-15 minutes ?!
Hi.
Without knowing your exact make and model I can only guess that your console cooling fan (sits at the top back of your oven) has failed. This is used to keep the the clock and controls from overheating. If it failes then a safety switch will activate and turn everything off in your cooker. when it cools down it will remake the contact and then switch everything back on again.
Hope this helps
Aardvark Repairs
Nov 15, 2009 | AEG B1180-4 Electric Single Oven
Oven turns off if too hot
There is a temperature switch that shuts the power down if the temperature goes too high. This is to prevent a fire if your thermostat sticks on. Sometimes the switch will become weak and open the circuit at too low of a temperature. Replacing the switch should solve your problem.
If you need more assistance, post a comment with the model and s/n of your stove.
Thanks,
Tim
Jun 28, 2009 | Ovens
Electrolux EOB6630x - Oven switches off after 10-15 minutes, then back on again after it has cooled down, obviously the overheat stat is working otherwise it wouldnt switch itself off, what part is it that...
there is a casing fan which is operated by a fan stat.remove top cover and it shoud be accessible. check it is free to rotate and has continuity. fan stat is located on top of oven as i recall
Nov 16, 2008 | Electrolux Kitchen Ranges
Shut down after 10 minutes
it is reaching the correct temperature and then switches back on when cools a bit?
Jan 11, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Oven cuts out after ten minutes and comes back after cooling down.
We have the same problem with our oven, AEG B2190-1.It started on on Christmas day[worst day of year]gets up to temperature after 10-15 minutes cuts out everything switches off until the oven has cooled down, The oven is only 18 months old. We have been told that it is a thermostat problem.
Dec 10, 2006 | AEG B2100-4 Electric Single Oven
Kitchen Ranges Logo
48 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
