Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Bobbin Case Slipping
I have a Quantum Futura model CE200 & the bobbin case slips out of place. Do you know why & what do I need to do to correct this? Thank you!
Sherry Matthews
  • Anonymous Dec 13, 2008
    I have almost the same problem, but I can't get my case back in, can anyone direct me on how to put in back in it's original spot.?
I have found that this usually starts with the top thread somehow getting stuck - either in the tension control, or wrapped around the post. Generally, this pulls the bobbin case out of alignment, and the needle hits it. If the needle hits in just the right/wrong place, it can gouge the bobbin case, making a rough spot or hook that will catch the thread, causing the problem to repeat more often, and without any apparent cause. If the nicks and gouges are not too bad, I have been able to file them down, or use a pair of scissors to scrape any protruding bits off. If there are too many gouges, or they are too deep for this to work, you need a new bobbin case. I have purchased them from sewvacdirect.com for $20-30, plus shipping.
Posted on Sep 19, 2008
My bobbin casing keeps popping out when I try to sew after numerous of attempts to correct the position.
it would be a good idea to have the bobbin case checked at a sewing machine repair shop to see if the bobbin case needs to be replaced or see if there is something wrong with the hook and hook race.
Aug 12, 2013 | Singer CE-200 Quantum Futura Computerized...
Bobbin bunching on elna 3230
try changing the needle
rethread the machine top and bobbin
make sure the bobbin is inserted correctly into the bobbin case
and that the bobbin case is inserted correctly in the machine
it's also possible that the bobbin case needs to be replaced
also check the bobbin it could be warped
it's also possible that the timing needs to be checked on the
machine
Nov 22, 2012 | Sewing Machines
Futura ce200 Felt on bobbin case worn out
check with singer for the parts
or sewingpartsonline.com
Mar 30, 2012 | Singer CE-200 Quantum Futura Computerized...
Bobbin case on singer ce250 thread gets hung up and pulls bobbin case out of place
is the needle inserted correctly--flat side goes to the back of the machine
the possiblities are
worn or broken gear
machine could be out of time
needs to be serviced
Feb 27, 2012 | Singer CE-200 Quantum Futura Computerized...
The bobbin thread shows
I am having the same problem and can't seem to find the answer. Please email me if you have found a solution!
Debr535@yahoo.com
Sep 30, 2009 | Singer CE-200 Quantum Futura Computerized...
Bobbin case futura singer sewing machine came out
The opening fits on the right side, toward back. There is the silver ring with the slot in it for the bobbin. That slot is facing the sewer.
Jul 19, 2009 | Singer CE-100 Futura Computerized Sewing...
BOBBIN SLIPPING AND STOP EMBROIDERY
First,call the technician and see if he will honor a warranty on his repair work. Next, sew on the machine until it messes up again. Do NOT take all the stuff loose. Take the machine, the garment, the thread,everything just as it is to the technician. Don't even lift the presser foot. He will probably find the problem.
Usually, on a problem such as this, it is the wrong bobbin, the bobbin inserted the wrong way, the tension not working , not threaded correctly, a rough spot on the bobbin case or the bobbin case is not properly positioned.Some times the thread jumps out of the thread take up lever.
sewman7
Aug 25, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer futura CE-200 Can not wind the bobbin thread
In embroidery mode, you have to send a design to the machine before the bobbin winder will work.
Jan 30, 2008 | Singer CE-200 Quantum Futura Computerized...
Bobbin stuck on bobbin winder, how do I get it off? it will not budge!
Is thread under bobbin? can you turn it? can you pull the thread off the bobbin and then remove it? Bobbin that comes with machine may not be right one. Right one has a light blue tint and a slightly domed top.
May 25, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
172 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
