Question about Canon EOS-20D Digital Camera with 17-85mm Lens
Connection Problem I recently purchased a Canon EOS 20D. When iconnect it to computer and ZOOMBROWSER it keep telling me cant connect as the LCD is on. It is not turned on and I cant get around the problem. I can easily copy the files to folders, but Zoombrowser is so much more convenient. All advise appreciated
    Sergeant:
  • 255 Answers
I too have a Canon 20D and receive the same message. Zoombrowser works fine with my Canon G3, so the way I get around this problem is by using the other software that came with the 20D called EOS Viewer. This software will download your images every time. You might try sending a note to Canon's support team on the Canon website. They are very quick to respond to all questions and they can probably respond to this question too. Good luck!
Posted on Aug 31, 2005
SOURCE:
I HAVE A CANON EDS 20 D IT KEEPS CLICKING ERR
Try removing the batteries and wiping the connectors on the batteries and the connectors in the motordrive with a lens cloth. This worked for me. Sometimes the connectors get dirty and need to be cleaned for a complete connection. Hope this helps.
Apr 23, 2010 | Canon EOS-20D Body only Digital Camera
I got error 099, before I was getting error 05. and the flash dos not open canon EOS 20D
I also get the error 99 message and cannot take any photos... I have been able to solve this problem by taking out the batterys and wiping down the connectors on both the batterys and the connecters in the motordrive with a lens cloth. keep the lens cloth on hand when shooting. It may be that either oils, or dirt has gotten onto the connectors. I hope this helps.
Mar 23, 2010 | Canon EOS-20D Body only Digital Camera
Rear lcd screen black in shooting mode but works fine in playback
Solved the problem by going to the Canon product support site. It seems that there is no problem at all. The way the camera is designed is the problem. To be able to use the rear display lcd as a view finder, the camera needs to be able to lift the mirror to allow the sensors to pick up the image and display it on the screen. The 20D does not have this abilitiy. Apparently some later models do allow you to raise the mirror. It was this feature on those models that led me to believe that the 20D should do this too.
Jan 25, 2010 | Canon EOS-20D Body only Digital Camera
Lost my canon 20d software that came with camera
All of the software, manuals and drivers are available on Canon's website.
ZoomBrowser is the the only software that may present installation problems if a previous copy is not already installed on your computer. Any old copy of ZoomBrowser will allow the most current version to be loaded from Canon.
Oct 30, 2009 | Canon EOS-20D Digital Camera
Not wanting ZoomBrowser
Start EOS Utility. Click Preferences. Click Linked Software. Select None.
Feb 22, 2009 | Canon Cameras
Can't download photos from Canon PowerShot to PC via Zoombrowser
I have used zoom browser for two years to download pictures from my canon powershot SD1000 digital elph. I installed Uniblue updates for speedupmypc and twicker. now my pictures will not download. Is there a connection with uniblue, is it a coincidence ? How can I fix this problem? Scoc
Dec 09, 2008 | Canon ES-E1 EOS Link (4593a006) for PC
Canon zoombrowser Ex downloading problem
Try updating the Zoombrowser software.
If you have a connection to the camera, go into my computer and get images directly off the camera using scanner and camera wizard, microsoft's default program. This will at least allow you to transfer your images until you can resolve the software problem.
If you have no connection to the camera via your computer, you need to try some other troubleshooting steps to get a connection. I will post those below in the next post.
May 30, 2008 | Canon PowerShot G7 Digital Camera
My computer is not recognising my EOS 20D!
Hi I have exactly the same problem. I'm running Windows Vista Business as the OS and have installed the disk that came with the camera with no avail.
It keeps recognising it as a scanner, but I cannot open the pics. I've tried different cables as well. No use.
Mar 11, 2008 | Canon EOS-20D Digital Camera with 17-85mm...
My Canon EOS 20D has a problem
could be that you have dust / dirt on the sensor even when mine was brand new it had dirt on it.
Jan 27, 2008 | Canon EOS 20Da Digital Camera
EOS 20D - LCD dead??
So far this year we have repaired 4 Canon 20D's with this problem and it always is either the Main PCB ( the interface IC which controls the main display and which sits on the main board shuts down ) or the LCD monitor that have to be replaced so your camera has to go to Canon I am afraid ( ask for a quote as this is a relatively expensive repair ). The fault BTW cannot be caused by using non Canon lenses.
Oct 03, 2007 | Canon EOS-20D Digital Camera
Canon EOS-20D Digital Camera with 17-85mm Lens Logo
139 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
