Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Kenmore 596.73502200 Elite Trio
Freezer appears to be working, at least it's cold. Refrigerator is not working. There does not appear to be any air flow into refrigerator compartment. There is only a very slight frost on rear evaporator cover panel. I'm suspecting evaporator fan has failed (since there is absolutely no air flow into refrigerator section). Is there a procedure available to step through removal of ice maker, removal of cover, removal/replacement of fan ? Thanks...BOb.
fridgetech
  • 473 Answers
SOURCE: Refrigerator Not Making Ice, Frost in Freezer and Refrigerator Not Cold
It has a defrost problem.  Most likely cause would be the defrost thermostat which clips onto the evaporator behind the back panel in the freezer.  Next most common would be the defrost timer.  Third would be the defrost heater.  Let me know if you want to try to test these parts.  If so I will need the entire model # from the sticker in the fridge or on older models on a plate at the bottom front below the door.
Posted on Oct 10, 2007
Amigaman
  • 248 Answers
SOURCE: Frost buildup
  It is not defrosting.  You have to remove back wall of freezer where frost is and take hairdryer to melt away frost.  You need to check defrost heater.  This is on bottom of evaporator coils.  It has wires going to it on both sides.  This has to be checked for continuity.  If ok on top of coils is a round unit called a defrost terminator.  This needs to be checked for continuity also.  This must be done before you defrost coils.  It should have continuity when its cold.
  If these are ok you probably have a bad timer or defrost board.
Posted on Oct 25, 2007
  • 146 Answers
SOURCE: getting at a clogged drain in evaporator compartment
There is a panel over the evap. in back of the freezer section. Remove it and you will see the drain at the bottom of the freezer below the evap.. You will see a little tray with a hole in the center of it. You will need to clean out this tray and run a wire down through it to clean out the tube that runs to your drain pan. Don't use a coat hanger or anything too stiff as it may puncture or pop the hose off. It has to be something flexible but strong. That should do it!
Good Luck!
God Bless
Posted on Dec 26, 2007
SOURCE: kenmore elite refrigerator, model # 59676534500
I went ahead and signed up for Sears' service warranty since I knew I had to get someone to come out.  IT costs $200/yr.  They say it covers everything, but when the technician came out, he told me that it just covers $500 per visit.  He said that a new motherboard and the labor alone was going to make it $498.  Anyway,   he had ordered a new motherboard. Apparently the motherboard wasn't working.  It is located in the back bottom left side of the refrigerator behind the panel.  There is a compartment on the lefthand side that slides out and houses the motherboard.  He put that in and also had to fix the fan that is in the back of the freezer.  That fan is the one that sends cool air up to the refrigerator part. When I had looked at the fan before the repair man came, it was not moving at all.  So at least take a look at the fan in the freezer.  Just take out the freezer drawers, and the fan is located in the top center of the freezer behind the compartment cover.  Maybe that's the problem with your refrigerator, the fan.  Hope that's all it is. Good luck!
Posted on Jun 25, 2008
SOURCE: Kenmore Trio Freezer section makes snow in freezer compartment.
no its not a compressor problem. it not going into a defrost.
Posted on Jan 22, 2009
Srl629ev refrigerator
It is likely to be either the circulation fan in the freezer or the defrost element. The cold air is blown from the freezer into the fridge if the fan doesn't work then no cold in fridge.Otherwise it could be a defrost problem, if the element doesn't work the rear fills up with ice and the air cant flow. Both are behind the rear panel of the freezer
Jul 08, 2013 | Refrigerators
I have a smeg fridge freezer and the fridge does not appear to be cooling enough. The motor is running permanently but no matter how far we turn down the temperature it is not enough. There was a build up...
A refrigerator not cold enough is a hassle, because you are at risk of spoiling the foods you store in there. Most often, this problem is caused by something easy to fix.
1. Faulty Door Gaskets
The door gaskets in a refrigerator ensure a sealed closure every time you shut the door. Torn or loose gaskets on the door of the refrigerator can result in a leak in the cold air. As a result, the refrigerator is warmer. Repetitive and frequent opening and closing of the refrigerator is also a possible cause, because the warm air from outside replaces the cold air in the refrigerator every time you open it.
2. Dirty Condenser Coils
Dirty condenser coils can result in improper functioning of the refrigerator. These coils are located on the back or the underside of refrigerators. If you find this to be the cause of the problem, unplug the refrigerator before you attempt any cleaning.
3. Frost-free Feature not Working
If the frost-free feature fails, it causes a buildup of frost around the evaporator coils in the freezer. This causes a malfunctioning of the evaporator fan that blows cold air around. The fan can also be damaged if it hits the frost.
4. Faulty or Incorrect Temperature Control
A faulty thermostat can lead to a refrigerator that is not maintaining the desired coldness. Check for this problem and also ensure that the temperature is set to the correct level. Normally, refrigerators are set to a temperature of about 0°C, whereas the freezer sections are around -17°C.
5. Inadequate Air Flow inside Refrigerator
A refrigerator that is loaded with too many food items can fail to maintain an adequate level of coolness across all the items kept in it. The surface items tend to be colder, and the items underneath do not become as cold. A refrigerator that has very few items in it can also fail to function efficiently. Try to ensure that your refrigerator has enough food in it at all times, but is not so loaded that the air flow gets constricted.
6. Vents between Freezer and Refrigerator Clogged
The vents between the freezer and refrigerating section blow cold air from the freezer across to the refrigerator. If these vents are clogged with ice, the air is blocked and the refrigerator does not cool down. If this is the case, you can unplug the refrigerator, wait for the ice to melt and then connect it back to the power supply.
7. Faulty Door Switch
The door switch is found on the bottom of refrigerator doors. It turns off the light in the refrigerator and resumes cooling action when you close the door. If this switch is not functioning properly, the refrigerator will not be cold and it will also be affected by the heat of the interior light.
8. Refrigerant Leak
A refrigerant leak is very unlikely. This problem can cause malfunctioning of your refrigerator. If you suspect this to be the cause, contact a service technician.
Hope this will help to solve the problem...
Aug 08, 2011 | Smeg Refrigerators
Freezer working, but fridge is not. when you turn it off then back on its kicking on but fridge is not getting cold.
Check the air return on the bottom left wall of the refrigerator side. Check for cold air flow at the top of the refrigerator when the compressor is running. If you feel no air flow, open the freezer door and see if you detect significantly more air flow after opening the freezer door. This could indicate a return air flow restriction and make sure that there no blocking of air vent at the top of refrigerator section that supplies the cold air from the freezer.Check the door seal gasket on the refrigerator for leaks.
If there is still same problem then you need to replace evaporator fan.
Hope this helps.
Shane
Mar 05, 2011 | Whirlpool Refrigerators
I have a Frigidaire Model FRS6R5ESBF that is 3 years old but did not get installed until 4 months ago. The freezer appears to be working fine but the refrigerator side is getting warmer by the day. It...
Could be that the freezer is icing up stopping the air flow coming up into your fridge, try switching it off for at least 12 hours with the freezer door open.
Nov 02, 2010 | Frigidaire Refrigerators
Freezer is working fine. The refrigerator is not
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 02, 2010 | KitchenAid KSCS25FKSS Side by Side...
Refrig not cold enough, ice buildup on banck panel of freezer
ice build up means your refrigerator is not going through defrost cycle. you have ice build up on evaporator which restricts your cold air flow into the fresh food side. check defrost timer, defrost thermostat located on evaporator behind the wall where your getting frost. check defrost heater. it wraps under the evap.
Jun 21, 2009 | GE Refrigerators
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Fridgedaire modle # FRT18S6AW0 - freezer appears ok (staying cold) but fresh food area gets warm -- door seal appears ok; made sure that the vents on bottom shelf were unobstructed to allow air flow;...
If there is any frost on the back wall of the freezer you have a defrost problem and it is keeping the air from getting to the refrigerator section. Also make sure the condenser under the unit in the back is clean. Lack of air flow to cool the refrigeration can cause the same type of problem.
May 07, 2008 | Refrigerators
Zanussi fridge freezer
sounds like the freezer evaporator has iced /frosted up and you will not get cold airflow through it. try a 24 hour defrost to clear it. then check fridge cooling.
Jun 03, 2007 | Zanussi ZEBF250W Bottom Freezer...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
363 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
