Question about Funai Emerson DVD/VCR EWD2004
Daewoo VCR/DVD combo not turning on
Is there a fuse in them that can be changed ? May not be the problem . Also doesn't seem to be power to cord . Is it possible for the cord to have fried. How much for new chord? Model# DV6T834N S/N: 97P0992901 My Emerson DVD/VCR Combo Player does not turn on. The fuse is good and I am getting power to the fuse but don't know how to troubleshoot past the fuse..I have no schematic for this player...anyone know of the next step for me to try in order to see what the problem might be? Thank's in advance for any suggestions.....
Check you power button it might be bad
Posted on Jan 03, 2009
Had power outage and now VCR/DVD does not turn back on. lights all work but it doesn't seem to pick up the channel?
Dis-connect the plug from the wall receptical and other leads attached to to the unit. Next press and hold power for too minutes in an attempt to reset the microprocessor, now hook everything back up and power on, if this fails it probably would be cheaper to replace the combo than have it repaired.
Jun 03, 2012 | Symphonic WV806 DVD Player/VCR
My VHS-to-DVD Burned Disc used to work and now it doesn't
Richard,
It could be your disc is scratched or DVD+R can't be read in the DVD player. Check for any scratches. Then pop in the disc in to your PC DVD, to see if it's readable.
May 31, 2012 | Daewoo DV-6T834 DVD Player/VCR
GO Video VR 3845 DVD/VCR combo will not turn on.
Yes,if u want to.Unplug,replug the unit back after about an hour or so.The unit should reset it self out of protection mode and work again,if nothing in the circuit boards are burn.
Jun 15, 2010 | GoVideo Go Video DVD/VCR Combo
Daewoo dvdplayer/vcr combo switct over switch not
that happend to me and we had to take it apart to figure out the problem.
Jul 14, 2009 | Daewoo DV-6T834 DVD Player/VCR
No power to dvd-vcr player
check the circuit breaker. plug something into the outlet that you know works and see if it turns on.
dont think that there is a fuse inside. If the cables seems good ( ohm it out) then the unit might be shot. sorry...
Feb 14, 2009 | Sanyo DVW-7000 DVD Player/VCR
Hello
PROGRAMMING DEVICE CONTROL
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
steps; otherwise skip this section:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
2. On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
5. Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn’t work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
6. Repeat steps 1 through 5 for each device you want to control.
For future reference,write down each working device
Here is a link to your manual:
http://www.ofausa.com/remote_manual/CTGA...
Nov 28, 2007 | One For All URC-3021 Remote Control
HELP ME PLEASE
CBL/SAT,or TV).
then release SET.
DVD/VCR Locked
My DVD/VCR Daewoo locked and everytime i pressed a button it just said LOCK! I plugged off the vcr for a few hours and then plugged it back in and pressed the on button. Now im watching the dvd that was stuck inside. Try it, you just never know.
Nov 19, 2007 | Daewoo DVRS04 DVD Recorder/VCR
Locked DVD/VCR Combo
Hold the power button down for 5 seconds fixed it for me.
Sep 23, 2007 | Daewoo DVRS04 DVD Recorder/VCR
Televison & Video Logo
248 people viewed this question
Top Funai Televison & Video Experts
Demonic-2011
Demonic-2011
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
