Question about HP P1100 21" CRT Monitor
Not powering on
I have a HP p1100 21" CRT
When I power it on U can hear the switching mode clicking and after 5 to 10 seconds the power button goes from green to flashing amber.
It just wont come on
  • 114 Answers
You will need to take it in for repair. This is most likely a power supply problem.
Lou
Posted on Aug 24, 2008
SONY LCD SWITCHES OFF BY ITSELF
From my experience with sony tv it's normal.The set is going through update mode.Leave the set for about 10 minutes and it should be back to normal.
Jan 06, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Tried unpluging and nothing tried al buttons nothing the computer was at a shop to BE FIXED AT SHOP OK CAME HOME STUCK IN POWER SAVE MODE BUTTON ORANGE ON MONITOR HIT GOES GREEN SAYS PAWER SAVE MODE HIT...
Press and hold the power button for 5 seconds this will turn the system completely off wait 5 seconds then turn it back on as soon as it boots up go into power options in the control panel and click the option from power saver mode to do nothing as there is a fault with some computers that it gets stuck in power saver mode
Jun 27, 2011 | Computers & Internet
Hi my name is mike and have a serious problem with my playstation 3 well my system froze up in the middle of a game so i turned it off to reset it and now a red screen comes up and says a serious error has...
Try to start to the system in safe mode to check if this will resolve the problem.Safe mode is available to PS3 system software version 2.60 or later. To do the safe mode follow these steps:
  1. Verify that the power indicator on the PS3 system is solid red, and then turn off the MAIN POWER switch.
  2. Turn on the MAIN POWER switch, then touch and hold the power button.
  3. Keep touching the power button even after you hear a short beep after 5 seconds.
  4. After 10 seconds, you will hear another short beep and the system will shut down (release the button at this point).
  5. Touch and hold the power button again.
  6. Continue touching the power button even after you hear a short beep after 5 seconds.
  7. Release the button when two short beeps are emitted after 7 seconds.
  8. As instructed by the on-screen message, press the PS button to start up in safe mode
Mar 30, 2011 | Sony Playstation 3 (PS3) Console
My laptop went to hibernate and I cannot wake it from that mode. I only have a blank screen.
you have to press the power button once to get it out of hibernation. If nothing else works you can do one of two things:
1] Press and HOLD the power button for about 5 seconds or until you hear the laptop turn off. Then turn it back on again by pressing the power button momentarily.
2] You can DISABLE hibernation. To do this - follow these steps,
  • right-click the desktop and click on and click on "properties".
  • click the screen saver tab.
  • click the power settings button
  • in the power options properties dialog box click the hibernate tab.
  • uncheck the enable hibernation check box.
  • click OK then click OK again
Hope that helps
Good Luck
Feb 07, 2011 | HP Compaq Presario V3000T Notebook
Ps3 initial screen says hard drive file system is corrupted and then goes through a restore. when it gets to100% it shows the start screen and then displays same corruption message again
Sounds like power must have failed while the update was writing to the PS3 harddrive.You might be able to fix this problem by booting the PS3 into safemode. Here's the steps to do that:
Step 1: Turn off the PlayStation 3 by holding the Power button on the front of the unit till the Power light is red.
Step 2:
  1. Touch and hold the Power button, you will hear the first beep, meaning the PlayStation 3 is powering on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a third beep and the system will power off (Power light is red).
Step 3:
  1. Touch and hold the Power button, you will hear the first beep, again for the PlayStation 3 to power on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep for video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a quick double beep. At that point release the Power button. If you succeeded in activating Safe Mode, you will see a message on the screen saying, "Connect the controller using a USB cable and then press the PS button."
    Connect a USB cable to the controller and the PlayStation 3 and press the PS button to enter Safe Mode.
  • Then you will see the Safe Mode menu.
  • This last step can possibly erase the data you have stored on your harddrive, so I recommend the options in this order...if one of them works stop and don't try the others, that way you may be able to retain your data.
    1. Restore Default Settings
    2. Restore File System
    3. Rebuild Database
    4. Restore PS3 System
    Mar 28, 2010 | Sony Playstation 3 (PS3) Console
    When I press the 'power' button, I hear it click, but no picture comes on. I hear it click a couple more times, then it stops.
    If it clicks then goes to standby, then the fault is in your power supply circuit. If the sound comes on then the fault is in the line timebase circuit. Aquick way to check the line circuit is to place the back of your hand about 1" from the screen as you switch on, you will feel the hairs on your hand standing to attention.
    Feb 24, 2010 | GE 31GT740 31" TV
    All the connections work the ps3 comes on but then goes black
    You may have messed up the Screen-Settings, to solve this try this.
    Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
    Step 2:
    1. Touch and hold the Power button, you will hear the first beep, meaning the PLAYSTATION 3 is powering on.
    Step 3:
    1. Touch and hold the Power button, you will hear the first beep, again for the PLAYSTATION 3 to power on.
    4. Connect a USB cable to the controller and the PLAYSTATION 3 and press the PS button to enter Safe Mode.
    5. Then you will see the Safe Mode menu.
    Step 4
    : We recommending performing the safe mode options in the following order until one of the options works for you. If one of the options work, do not continue onto the other options.
    3. Rebuild Database
    4. Restore PS3 System (This will wipe your harddrive, so remember to backup savegames.)
    Oct 10, 2009 | Sony Playstation 3 (PS3) Console
    No audio/video
    sounds like fly back failure. high voltage transformer
    Aug 12, 2009 | RCA 27V514T 27" TV
    Not Powering up.
    Hello there
    I understand your Notebook is not powering ON. You can perform power drain to resolve the issue.
    1) Perform power drain. Follow below steps for Power drain.
    a) Shut down the Notebook and remove the battery completely from the Notebook.
    b) Press and hold the Power button for 30-50 seconds.( This will discharge any static electricity in the picture tube)..
    c) Connect the battery and switch on the Notebook.
    If the problem still persists log on to HP.com 24X7 chat support by clicking the below link or pasting it in the address bar of a web browser.
    http://welcome.hp.com/country/us/en/contact/chat_1.html
    Feb 16, 2009 | HP Compaq nc6000 Notebook
    Monitor shuts off during boot. Let the machine boot full up, hit the power button, the monitor flashes windows for a split second, and goes back to power saving mode
    Hey there Celius,
    Chances are the 'Refresh Rate' somehow got set too high for the monitor. On flatscreens , the result is a black screen.
    If you have an old monitor (crt type) hook that up temporarily and reboot.
    • Right Click the Desktop
    • Click Properties
    • Click Settings
    • Click Advanced
    • Click Monitor
    • Lower the refresh rate or set at optimal
    • Check the box 'Hide refresh rates this monitor can't display'
    Shutdown, Switch back monitors and try it now.
    Good luck
    Mike
    Oct 29, 2008 | LG Computers & Internet
    HP P1100 21" CRT Monitor Logo
    106 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
