Break up of digital signal on ITV - Televison & Video
Instead of moving the antenna, I tried moving the amplifier instead (the small metal box where the electric plug wire and both coaxial cables meet).
This helped a lot, and my digital signal breaks up much less frequently now.
Posted on Nov 06, 2008
Why can I not receive ITV channels
This could be too much signal thanks to the Freeview retunes going on. Your aerial is more sensitive at some frequencies, so there's more signal power higher up the frequency range. The signals for BBC and ITV are among the strongest ones broadcast. If they are now at a point on the aerial's range where they are too strong for the TV then the tuner will over-saturate. The result is the same as no signal.
A simple and inexpensive diagnosis tool is a variable attenuator. The MA1620 on this page is perfect for that job:
Splitters amplified splitters and attenuators
It will give you a way to reduce the signal level at one TV without affecting the other TVs in the house.
Sep 08, 2014 | Televison & Video
Ihave Bushldc 26" T.V. and
The most common cause of that is signal break up causing firstly "blocking" of the picture and audio drop out. Heavy clouds can also cause signal deteriation as does heavy rain.
Hope that helps.
Jan 18, 2011 | Televison & Video
Loss of some channels on 32LD30U B
Weak digital signal. Either antenna or tuner.
May 03, 2010 | Televison & Video
Itv and ch4 channels have no signal on my digital
First check with some of your neighbours to find out if they have the same problem if you are using a communial aerial, if thiers are ok, try re-tuning the TV from "Auto tune" in the set-up menu, this will retune the entire TV & should pick up the missing channels.
Apr 14, 2010 | Televison & Video
Will not tune into itv3 all other channels ok. itv 3 does not come up when scanning channels!
Two things make certain the aerial is good and the cable from it is not the old type brown cable (replace it with satellite cable). Digital sets need good signals and it will clear up the breaking up of the picture when cars go past etc.
If you do have a good aerial & cable. Try resetting it to the factory default. That should clear the memory settings of the tuner. As sometimes it remembers you had channels and therefore ignores them. Then rescan!
Feb 11, 2010 | Panasonic TX-32LXD1 32 in. LCD Television
My itv channels keep breaking up or freezing since the switchover
I'm guessing the signal from the antenna is too weak. With digital, it will not get fuzzy as with analog, but rather will pixelate, go blank, or freeze. You need to figure out how to get more signal to the TV by moving or re-aiming the antenna, improving the connections (clean or repair), or amplifying the signal.
Dec 01, 2009 | RCA DRD485RG DirecTV DTV Receiver
Cannot get good tv signal since ITV and other channels have gone digital in the last 3 weeks. The picture keeps breaking up and the sound goes intermittently.
The transition from analogue TV broadcasting has been painfull in some areas. the only way to get out of this frustration is to buy yourself a digital set top box . This will convert the digital TV signals to analogue form so that your TV can pick them clearly. In any case ,the trend is to have all analogue transmissions phased out altogether
Oct 23, 2009 | Televison & Video
UNABLE TO VIEW ITV CHANNEL 4 OR SKY SPORTS NEWS ON MATSUI TV
try tuning tv in another room, if it works it is then your cable or socket, try the cable next. If it wont tune its a faulty set.
May 26, 2009 | One For All URC-3445 Remote Control
LE32R74BDX
this is because most new lcd tv's have a poor tuner built in and require a stronger ariel, to pull in the analogue or digital signal. Check that your ariel is freeview capable whether using freview or not, as these ariels are better at pulling in the signal, or do what i have had to do and buy a mains plug in signal booster from Asda for about £6.00, this did the trick, especially if you don't want to replace an ariel costing about £30.00
Jun 13, 2007 | Samsung LN-R409D 40 in. LCD Television
Televison & Video Logo
459 people viewed this question
Top Televison & Video Experts
