I didn't click safely remove hardward device when I took out my flash drive, now it won't recognize my flash drive at all. It will work on other computers so I know the flash drive doesn't have a problem.
    Novelist:
  • 110 Answers
This should have nothing to do, with the safely remove hard ware option.
Plug the USB key back in and check your device manager for conflicts? If the usb key is listed as a conflict, uninstall it and then reconnect your usb key.
Also, is this computer on a network... if so, it may be a coincedence, and a entire issue all together.
Put it this way, if the USB ports on your computer still work with other devices, and your flash drive works with other computers... nothing is wrong with either. Something is just probably conflicting with it
Posted on Aug 24, 2008
Sandisk cruzer 8gb suddenly not recognized when connected to my computer
1. Try the other USB slots to see it the board is ok. Most modern pcs have two slots in the front and two to four slots in the back, try them all.
2. Do you have another pc that you can plug it into? If it works on that one you may have driver problem or the board is bad on the other one.
3. Have you tried to plug other USB devices into the slot(s) to see if the port is ok?
I have the same one and have had to mess it sometimes. Have to right clicked the "Safely Remove Hardware" in the right corner of the task bar. Right click and then left click the Safely Remove Hardware. That will show you all USB devices loaded. If you see the Flash Drive, click it and when you see the next prompt to remove it wait a few seconds and then plug it back in. If that does not work, reboot and leave the Flash Drive plugged in and see if it loads when the pc fully is loaded.
4. Goto the Control Panel> System > Hardware > Device Manager. Look for your drive in the list of Disk Drives. Pick it and then pick the Action Menu and Scan for hardware changes. If the Flash Drive is working properly you should not see any errors. You should also be able to see the drive in explorer.
5. If you still do not see the Flash Drive in explorer but you do see it in Device Manager, right click it in Device Manger and unstall it and reboot and let windows search and reinstall the device drives.
Good luck and post back.
Jun 01, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Tip
How to Download Files to USB Flash Drive
MS Windows Users<br /> 1.Connect the USB flash drive to an empty USB port on your computer. <br />Depending on your computer, there can be USB ports on the back, side or front. The flash drive can also be connected to an external port hub device. Once you connect it, the computer will automatically recognize it as a removal device.<br /> 2.Double-click "My Computer" on the desktop. You should see your USB flash drive's icon listed together with other removal devices on your computer.<br /> 3.Double-click the flash drive's icon to open the flash drive window and <br />reveal the contents saved on it. Locate the file you want to download to the <br />flash drive from its current location on your computer and right-click it. Click "Copy."<br /> 4.Right-click an empty spot on the flash drive window and click "Paste" to download the file to the flash drive.<br /> 5.Close the flash drive when you are done. Click the "Safely Remove Hardware" icon on the system tray. A new window will open. Left-click the flash drive and click "Stop." A message will pop-up indicating that it is safe to remove the device from the computer. Disconnect the USB flash drive from the computer (or external hub).<br /> <br />Mac Users<br /> 1.Connect the USB flash drive to an empty USB port on your computer. The computer will automatically recognize the device and display its icon on the desktop.<br /> 2.Double-click the flash drive icon on the desktop to open its window and <br />reveal the contents on it.<br /> 3.Locate the file you want to download to the flash drive from the location <br />where you have it saved on your computer and right-click it. Click "Copy."<br /> 4.Right-click an empty spot on the flash drive window and click "Paste" to download the file to the flash drive. Close the flash drive window when you are done and drag the flash drive icon to the trash can to safely eject it from the computer.
on Feb 01, 2011 | Computers & Internet
Laptop will not recognize flash drive
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive to working order you need to format the flash drive,BUT you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm www.CardRecovery.com
Mar 24, 2011 | Computers & Internet
When i plug in the u3 flash drive it says usb device not recognized
Hi ,dkjran,
If your computer affected by virus will not show in the pc .so you will install it to another pc,and format it .Flash drive can not recocknize,becayse there are some reason .
  • VIrus affected
  • Sometimes when a flash memory stick or USB external hard drive fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory USB hard drive device appears to malfunction it may be possible to restore it by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted then it will indicate that it is Healthy.
If this doesn't work then it is faulty.
hope it will help you
Dec 12, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have a transcend 2gb pendrive but it has failed to work whenever i try to connect it to my computer , it displays usb device not recognized. Now what shall i do to fix this problem ???
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you need to format the flash drive, but you will lose the data stored on the flash drive.
Jan 09, 2010 | Transcend T.sonic 610 MP3 Player
My memory stick pro-hg duo just stopped working all of a sudden for no apparent reason, it can't be recognized by any of the devices i have that support it, is there a way i can repair it
When the flash memory USB hard drive device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
Dec 21, 2009 | Sony Electronics - Others
Can not recognize my new USB flash disk 32M( 614910458 )no response Help me please ! No drivers are installed for this device. Universal Serial Bus controllers "Standard USB Host Controller" Thank you for...
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
Dec 17, 2009 | Computers & Internet
One of two USB drives wont recognize anything
Dec 13, 2009 | Toshiba Satellite A205-S5804 PC Notebook
Toshiba satellite memory stick problem
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Oct 09, 2009 | Toshiba Satellite A135-S4527 Notebook
Computer does not recognize CD/DVD drive
If updating the drive firmware does not work, then replacement of the drive will be necessary.
Jan 30, 2009 | HP Pavillion ZV6000 Notebook
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
