Question about IBM Infoprint 1352 Laser Printer
IBM Infoprint 1352 won't power on
As a technician for a small school district (we have a school) I have a printer that will not power on. Are there any safety overrides to prevent power from coming on? How do I get the power supply out to check it? Any way to get documentation for this printer?
Thanks,
  • 300 Answers
LVPS (low voltage power supply).
To get to it remove the right side cover (to do this, take the toner cart out and you'll see a screw on the inner right side, remove this. Remove the rear cover, the if you look through the top of the metal frame on the inner right side you'll see another screw, remove this. the cover will then come off.
Remove fuser assembly
Remove the LVPS mounting screws (2) from the rear of the bottom pan.
Pull the LVPS assembly far enough out from the right side of the printer to disconnect the fuser lamp cable.
Warning:
The LVPS assembly may be difficult to remove from the printer. Do not use excessive force in the removal.
Remove the LVPS access plate.
Disconnect the interconnect card cable from the LVPS.
Remove the LVPS.
Posted on Aug 25, 2008
IBM infoprint 932 service printhead error
go on line and type in
ibm infoprint 1352 laser printer error 932
enter
or
ibm 1352 infoprine error message 932
rod
Feb 06, 2009 | IBM Infoprint 1352 Laser Printer
IBM INFOPRINT 1352
check for paper jam in duplexer - or it is not seated correctly. power cycle printer after reseating to re-init printer.
Nov 17, 2008 | IBM Infoprint 1352 Laser Printer
IBM 1352
DC Pick motor error: No Encoder feedback. Try to remove all paper from tray 1 and replace it.
It basically means there is a tray1 paper feed problem.
Oct 14, 2008 | IBM Infoprint 1352 Laser Printer
How to enter maintenance menu on 1352
Turn off the printer. Hold Go and Return and restart the printer. hold until you see performing self tests. That is Diagnostics mode.
Oct 07, 2008 | IBM Infoprint 1352 Laser Printer
IBM 1352 Infoprint
It means it's due for a service, normally the consumables ie fuser, pick up rollers, charge and transfer rollers are coming to the end of their life.
Aug 18, 2008 | IBM Infoprint 1352 Laser Printer
Question on the Infoprint 1352
if your unit comes multifunction capabilities then yes you should be able to, if you bought this as a standalone printer only then you need to buy a separate multifunction board that can cost you as much as 500-600 $
Jul 25, 2008 | IBM Infoprint 1352 Laser Printer
Print Cartridge
Unfortunatly, no. This is the compatibility list for that part number: IBM2.gif InfoPrint 1352 / 1352n / 1372 / 1372n Laser Toner Printers
May 14, 2008 | IBM Infoprint 1332 Laser Printer
IBM Infoprint 1352 Laser Printer Logo
82 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
