Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Low virtual memory what shoul i do?
Pentuim 4 aoc
    Novelist:
  • 210 Answers
Start-settings-control panel-system
Click on the Advanced tab
Click settings under performance
Click on Advanced
Hit "Change" at the bottom
From here, it's usually set to "system managed size", but if not, set it to that, or manually set the size to 1.5 times the amount of system RAM you have. (your choice)
If there is no problem there, then the disk with the virtual memory (page file) is probably full and has no space left.
If that's the case, use a different disk for the page file. (a few clicks on that same page)
Posted on Aug 24, 2008
Hi. I have a AOC F19s monitor and I somehow locked the "OSD" and need help UNlocking it. Thank you.
Pressing and holding the menu key for a couple of seconds shoul do the trick.
Please come back and leave a rating/testimonial if helped or post a comment for further assistance.
Thank you for using FixYa, the community-based help site :)
Jul 30, 2011 | AOC FOVI F19S Monitor
Virtual memory too low
  1. Click Start, right-click My Computer, and then click Properties.
  2. In the System Properties dialog box, click the Advanced tab.
  3. In the Performance pane, click Settings.
  4. In the Performance Options dialog box, click the Advanced tab.
  5. In the Virtual memory pane, click Change.
  6. Change the Initial size value and the Maximum size value to a higher value, click Set, and then click OK.
  7. Click OK to close the Performance Options dialog box, and then click OK to close the System Properties dialog box.
I hope this helps you with your issue. Don't forget to rate. Have a great day!
Feb 26, 2010 | Acer Computers & Internet
System says low on virtual memory even after I zero & format the hard drive with new operating installed?
this is virus instaled on computer bios or defective memory boards.
1st replace memory, and check-it.
2nd find a original bios on IBM website, and flash-it.
Nov 22, 2009 | IBM NetVista PC Desktop
Windows XP Virtual Memory is low. How can I regain memory?
Virtual memory is "memory" on your hard drive, not actual memory. The best way to regain this is reboot and shut down some of the stuff that runs automatically when you DO boot up.
(This Virtual memory is space set aside on your hard drive that the processor moves data into and out of like it would put data on a memory module ... but in comparing the two, the virtual memory is SLOW.)
You can increase the size of your virtual memory to anything you want. Some say too large a allocation will slow you down and too little will cause crashing or slow opertion. You are 99.44% probably set to let Windows manage your virtual memory (default) at this time.
thanks for posting your question to FixYa.com
positive comments are welcome
a
Nov 02, 2009 | Gateway Essential 500 PC Desktop
Virtual memory is low computer is very slow
hello frnd, you can increse your virtual memory manually...
1.go to properties of my computer
2.go to advance tab...
3. there is option to change virtual memory.
4.click on it and change virtual memory accordingly..
hope this will help you
Jun 30, 2009 | Dell Dimension 2400 PC Desktop
Low virtual memory
You have to increase the Virtual memory.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 04, 2009 | Dell Inspiron 1300 Notebook
Temporary Internet Files
Temporary internet files could harm your pc if the files contents virus, this could also slow your pc because if you have files that was infected with virus specifically the application files. Those files were automatically load into the services and in the processes and also in the start up without your consent. If all these files will run in the system this will cause " a low virtual memory" because the memory speicified was use by these useless and annoying application.
If you encounter these problem i would suggest that scan you computer with a potent antivirus, you should empty the temporary files and the recycled bin.
If you are sure that the computer is virus free and still encountering the "low virtual memory" you can increase your virtual memory by doing these:
1 right click my computer and then properties
2. click the advance tab
3. in the performance., click setting
4. then " advance tab"
5. in the virtual memory click change
6. check custom setting
7. in the initial size double the size of your memory
7. maximum double the initial size you setted.
If these will not solve the problem i would recommend you to format and reinstall your system.
Hope this help
Jan 22, 2008 | Computers & Internet
Nintendo DS lite game card
there several steps like these....
may be the virtual memory is low.... you trying increasing virtual memory..
this can be done by following
1. go 2 control panel,system,advanced tab
2. in performance option click settings
3.go to advanced
4. go to virtual memory option there click change select your operating system drive and increase the virtual memory minimum for 700 and max to 900... give ok
and then have check...
if same problem persists may be ram u r using is low upgrade your ram to atleast 512mb ram
or
may be you are using the old version of directx... install latest version of directx ( atleast you install directx9.0c)
or may be operating system problem(may be due virus attack system files have became unstable) try reinstalling it...
Jan 16, 2008 | Computers & Internet
Virtual memory
yes upgrading your ram (random access memory) helps alot
also incressing your virtual memory paging file might work if it is set 2 low.
Windows XP loadTOCNode(2, 'resolution'); 1. Click Start, right-click My Computer, and then click Properties. 2. In the System Properties dialog box, click the Advanced tab. 3. In the Performance pane, click Settings. 4. In the Performance Options dialog box, click the Advanced tab. 5. In the Virtual memory pane, click Change. 6. Change the Initial size value and the Maximum size value to a higher value, click Set, and then click OK. 7. Click OK to close the Performance Options dialog box, and then click OK to close the System Properties dialog box.
Dec 07, 2007 | Acer Aspire 3000 Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
