Question about Visioneer OneTouch 9000 Flatbed Scanner
Instalation software i have uninstalled,my onetouch 9000,and i cannot find the software to reinstall please can u help me
    Guru:
  • 1,463 Answers
Hello walsel
try here for a fresh download Visioneer OneTouch 9000 and 9020 Drivers and Manuals
riz.
Posted on Aug 24, 2008
I cannot get the scanner buttons to work. Nothing is showing up on my system tray to control the scanner buttons. The scanner works fine with software control thru Paperport. I have reinstalled One...
This is usually a symptom of either the basic driver being installed (not the OneTouch 4 software), the destinations for the buttons not being set in the OneTouch 4 software correctly or the monitoring program not being active. (For the X7600, the OneTouch 4 software comes with PaperPort programmed as the default destination for the scan button. If that setting got changed, it could cause the problem.)
The drivers and software are available here: http://www.xeroxscanners.com/en/us/products/drivers.asp?PN=X7600 . Scroll down for the manuals. If you have the basic Xerox driver installed, uninstall it (remove the scanner from the Device list by right clicking on it and choosing uninstall) then disconnect the data cable. Finally restart the computer and then install the One Touch 4 software.
If you have the OneTouch 4 software installed, check if the program is set to run on startup.
Click Start > Run then type "msconfig" (without the quotes) in the Open box. Click OK. Choose the startup tab and look for the Xerox software. Make sure the box is checked. Click Apply after changing the settings and restart the computer.
Next, launch the program (Start > All Programs) and try to launch a scan from the One Touch button panel on the computer. Adjust the settings if needed in the Configuration section of the software (see the manual for screen shots).
I hope this helps.
Mar 29, 2011 | Xerox 7600 Flatbed Scanner
Tip
Maxtor OneTouch 4 Mini overview
MAXTOR MANAGER & SAFETY DRILL SOFTWARE - Clarification
(Please also see tip 'PC RECOVERY & MAXTOR ONETOUCH 4 MINI SOFTWARE' for some more details about managing this invaluable, but problematic, software).
1.) The CD Included with OneTouch 4 Mini
- is only used as a boot disc for system restoration using 'Safety Drill' copies of a whole system
(see 5. and 6. below).
n.b. Maxtor Manager and drivers are not on this CD
2.) Maxtor Manager
- When the drive is new, the installation files for Maxtor Manager (a set of utilies), as well as a comprehensive User Manual, are pre-saved as files on the drive itself. This is why the manual strongly recommends copying and saving them on the PC for future use. This is just in case you need to format the drive and then cannot retrieve the files to reinstall the Manager program later.
3.) Using the OneTouch 4 Mini without extra software
PCs already have the necessary drivers to run external drives so OneTouch can be accessed though its icon in the 'My Computer' window without any other software being required, and files can be copied and 'dragged out' or 'dropped in' as usual.
4.) Installation of Maxtor Manager
- Installation just requires double clicking on the 'Launch' icon, which is among the file icons on the drive itself
This takes you through the installation steps to install 'Maxtor Manager' on the PC.
5.) 'Safety Drill' Copies
- These are copies of the whole system in its current state, which may be saved onto the OneTouch drive by using the 'Safety Drill' utility, which is only one of the programs in the set of utilities accessed through Maxtor Manager.
6.) Using 'Safety Drill'
- To use it to make a copy, first install Manager and run it, then click on the Safety Drill icon in the row of utility icons across the top of each page.
In the event of a disaster, full recovery to the date of the last or an earlier Safety Drill copy can be achieved.
This is done by putting the supplied CD in the PC's drive, ensuring that BIOS is set to 'boot from CD' (the default), connecting the drive, restarting the PC to boot from the CD (see 1. above), and following the on-screen instructions to restore from a Safety Drill copy which has been saved on the OneTouch drive.
7.) If Maxtor Manager becomes corrupt
- e.g if Manager ceases to recognise the drive, or if the list of safety drill copies contains duplicates, it is time to uninstall and then reinstall it, which usually puts things right. But see 2.) if you should wish to format the drive as well, make sure you have saved a copy of these installation files from the drive :-
8.) Diagnose or repair disk errors, & check warranty status
- Seatools
is a free diagnostic, repair, and auto-warranty checker program which can be downloaded from Seagate.
9.) To preserve the Setup Files
Installation of Maxtor Manager is performed by clicking the file marked 'Launch' which can be found amongst the setup files on the OneTouch drive itself, see 2. above. They are not on the CD which is provided.
The files can more easily be identified at first by exploring the OneTouch drive, where they remain unless the drive is formatted. It is a good idea to copy the setup files to PC because no download is available.
on Dec 12, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
My eye 110 web cam stopped working in the middle of chat and never started again what can it be?
HI,
Please uninstall your camera drivers/software and then reinstall it again.This should fix the issue.
If you still face the same issue then reinstall the software you use with your camera(the messenger software with which you chat).
Let me know the result.
Thank You for using fixya.
Nov 17, 2009 | Logitech QuickCam Pro 9000 Web Cam
Updating to SP3 for XP makes Nikon 9000 scanner go dead
Try resetting the scanner. and reinstall the drivers with automatic updates off.
Here is the link for the drivers:
Application uninstaller first
Driver uninstaller second
Driver installer third
Application installer fourth
Location of software
http://software.canon-europe.com/products/0000474.asp
Click the appropriate OS
Click the appropriate language
click Submit
Jun 20, 2009 | Nikon Super Coolscan 9000 ED Film Scanner
Will not do final scan
What version of windows are you using? Which software are you using to do the scan, and what version? It sounds like either the version of scanning software is incompatible with the version of windows, The USB connection (Assuming it is connected via USB) is a older USB connect (1.0 or 1.1) and a update to the firmware is causing a fault in the final scan, or finally the scanner has gone defunk... time to get a new one.
Jun 19, 2009 | Visioneer OneTouch 9000 Flatbed Scanner
Sound is distorted on Logitech quickcam 9000 at the receiving end
Uninstall the Webcam drivers.
Reinstall the Webam drivers, there must be a tick box in the setup somewhere to let you stop automatic updates.
Look closely as the Reinstall proceeds.
May 29, 2009 | Logitech QuickCam Pro 9000 Web Cam
Cannot install.
Please have a look at my reply to Happi Cappi, who had similar problem.
Sorry to tell you there are no drivers available
Mar 25, 2008 | Visioneer OneTouch 9000 Flatbed Scanner
Maxtor OneTouch 4 Mini 120GB
Go to the maxtor website and request the drivers. They will email a link for the download. Download and install.
Jan 08, 2008 | Maxtor OneTouch III Mini Edition 120GB...
USB connection fails
Hi, There shouldn't be any problem really. A couple of things you can try: 1. Verify that you have SP2 in the new Dell; 2. Verify that you have USB 2.0; 3. Verify that all your USB are enabled in your CMOS/BIOS; 4. Un-check "Allow computer to turn off this device to save power" in your USB Power Management; 5. Try other USB ports (front/rear). Hope this be of some help/idea. Post back how things turns up or should you need further information. Good luck and kind regards.
Sep 28, 2007 | Visioneer OneTouch 9000 Flatbed Scanner
Visioneer OneTouch 9000 Flatbed Scanner Logo
151 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
Mark Gough
Ed Mac
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
