Turned tv on got picture and sound,turned sound down lost picture now can only get sound and no picture
  • graniteview Aug 25, 2008
    Thanks, but have tried all that and nothing happened. It is also the same to play dvd's. It is a small tv with dvd player built in at the back if that is any help
    Novelist:
  • 110 Answers
Sounds like a loose video connection. Try re-attaching your cables. Also, see if the same thing is happening with DVD's
Posted on Aug 24, 2008
2 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: no picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jan 26, 2009
I have a JVC model HD-52G886 tv. that loses sound.
Replace or have replaced the Audio board in the set----a lot of them fail.
Mar 12, 2012 | JVC HD-52G786 52" Rear Projection HDTV
Model KV-24FS120 lost picture and sound while on
Hello
The chroma jungel IC of your set is damaged
Mar 05, 2012 | Televison & Video
Lost picture at first and now it appears to have lost sound also
Hi,lost picture - Sometimes, the TV may display a black screen, now you need to check the cables whether they are properly plugged or not. Reconnecting all the cables can also work for this problem. Also, if the screen has a screen saver, check how it's set up. And, if nothing works for this issue, then there is a possibility that the lamp, rear projection, or the LCD panel may have been damaged. Now, you need to check your warranty card of your television and se your set comes under the manufacturer's warranty period. Call the customer service for technical problem and get replaced if a part demands it.
consigning no sound on your TV
You might need to do some troubleshooting tips first before calling arepair man to replace the sound IC inside the TV.
Check the volume setting. It might sound simple, but it's the best place to start. Make sure the television sound is not muted or turned all the way down using the remote or buttons on the front of the television. If the batteries are dead in the remote and the TV is muted or turned down, it might seem like the sound is broken.
Examine cables connected to the TV. Sometimes a loose connection can cause a loss of sound. Ensure all cables are tightly connected to the television and correctly inserted. Some peripherals are connected using a three-plug system and are usually labeled red, white (sometimes black) and yellow. Both the red and white leads are sound cables. Try removing all the cables (except the power) from the back of the television and turning it to TV mode, then listen for static or other sound.
Plug in headphones to the television with all cables re-attached. See if you can hear sound through the headphones. If you can, it may indicate that the TV's internal speakers are not working. If you can't hear anything through the headphones, it may be indicative of a larger problem.
Call a repairman. If at this point everything has failed to produce a sound, it's time to call in the professionals. A qualified technician should be able to fix the problem either at your home or in a workshop.
May 28, 2011 | Vizio 42 in. LCD TV
Picture turned dark and blurred. any ideas would
do you have sound? if you have sound but not picture you have to buy the tv inverter.check
at www.partstore.com they can give you the rigth part
Aug 15, 2009 | Televison & Video
TV has power, but picture or sound will not come on.
It sounds like something in the set has failed. These newer TV's have shut down circuits that won't let the set come on if there is a short or excessive voltage somewhere in the set. Most failures in TV's occur at the moment the set is turned on.
Jul 09, 2008 | RCA F36650 36" TV
No pic No sound
your bulb is connected to all the audio
the bulb blew out and you need to have it replace local cuircut city has a repair man on call for this
Feb 16, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
