Prints are not aligned square on paper. Canon mx700
    Novelist:
  • 210 Answers
If the printouts are not aligned properly with the page, it can only be a roller problem as far as I can see.
Start of checking whether the paper-aligning arms are set for A4 (or whatever size you are using) and restest.
If everything appears to be feeding IN to the printer correctly, then there's a possibility that one of the rollers has seized up... a bit like if a tank's left-side track stopped, it would start turning left in a circle.
If you are willing to take a plunge and strip down the printer so you can access the many rollers and feeds inside, you could probably identify which rubber wheel is jammed and perhaps free it up. It could be something as simple as one of the rubber wheels having grease on it... so the paper sort of slides through it instead of being steadily fed through.
If it's a cheap printer, it's not worth having a technician look at it. You'd get a new cheap printer for the same price as his consultation fee! Good luck!
Posted on Aug 24, 2008
  • Steve Rand
    Steve Rand Aug 24, 2008
    of = off (I hate spelling mistakes) =-]
  • Steve Rand
    So... that doesn't fix the problem?
Mx700 prints right side and bottom cut- off abt. 3/4". any ideas?
Verify the fuser unit exit parts,a little paper is jammed,or the roller is dirty.
Feb 20, 2013 | Canon PIXMA MX700 All-In-One InkJet...
Print head seems to be out of alignment. Lines of print seem skewed and blurry. Edges of pictures are not in alignment.
Run the alignment in the maintenance software. Each new print head must be aligned.
Possibly release and remove the print cartridge and reinsert it. Maybe it is skewed.
Mar 21, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Canon MX700 with new cyan cartridge very faint
The print head needs a chemical solution. You have to soak it to chemical solution to unclog it. It should be a chemical solution that is really use for print head. If it does not work, the worse thing to do is to buy a new print head.
Sep 24, 2009 | Canon MX700 Office All-In-One InkJet...
Canon MX 700. I cannot get print alignment. I am missing lines. Have done head alignment 20 times and still cannon resolve issue. Have replace cartridges, cleaned heads, rollers, deep clean and still no...
My MX700 is 1 year old and I to have issues:
1) Alignment
2) Says it's out of paper when there is paper in it. Shutting off an Turning on usually helps
3) Feeds multiple pieces of paper at once!
HELP
Aug 30, 2009 | Canon MX700 Office All-In-One InkJet...
Pages comes out all crooked yet aligned to start with?
Hello sir; onthe paper path there got to have something stuck over there it block the paper go through so crooked. clean up paper chip or paper clip.
Aug 06, 2009 | Canon MX700 Office All-In-One InkJet...
My print is crooked.
try to change the ink cartridge and see if that works and also do the alignment after
Jul 20, 2009 | Canon MX700 Office All-In-One InkJet...
Canon mx700 paper won't go through either feeder
Get good fresh, dry paper. Don't force anything. If you are using photo quality paper, make sure it is right side up.
May 01, 2009 | Canon MX700 Office All-In-One InkJet...
Canon PIXMA MX700 printhead immediately coated with ink, smudges
It's likely that the foam pads that the print head rests on when the printer is not in use are saturated with ink. They're to the right as you look into the printer: a rectangular one for black ink and a square one for the colored ink. If you power the printer off and back on, with the cover open, you'll see where the printhead goes to rest.
The pads aren't easy to get at, but you can blot them with a paper towel. Gummy, half-dried ink dissolves in rubbing alcohol, and you can soak a paper towel or a cotton ball with alcohol and wipe down the area. I've had good luck soaking the pads with alcohol, then blotting them dry with a rag.
Feb 18, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Some paper got stuck recently in the printer but it has now cleared, however everytime I print now the document comes out slightly misaligned and the sentences for example are not in a straight line , can...
Dear Winsor Family,
It sounds as though you still have a small peice of paper caught in the auto sheet feed assembly. This is the part just behind the carriage rail. This is not an issue that any body other than a canon technician can fix. It will most likely involve the stripping down of the unit and the consequent re aligning of the asf. this can only be done by a trained technician.
Gremlin 11
Dec 09, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Printing 4x6 glossy paper photos on Canon MX700
I have a Canon Pixma MX700. I have printed many great photos but not it prints a faint image in the background but the rest of the photo is covered with black ink spots, what can I do to correct this problem?
Nov 09, 2008 | Canon PIXMA MX700 All-In-One InkJet...
121 people viewed this question
jasbo
jasbo
