Question about Olympus Camedia D-40 Zoom Digital Camera
Quality mode How do I check the amount of images that I can take and the quality mode?
    Master:
  • 852 Answers
Press the monitor button. The amount of images that can be stored and the selected quality mode will appear in lower-left corner of the LCD display.
Posted on Aug 31, 2005
Toshiba estudio 351c error code ce40
Hi
I hope that this will help you
[CE40] Image quality control test pattern abnormality
(1) Use "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576)"to check the abnormal occurring condition for each color.
(2) Check "Output value display of image quality sensor / Low-density pattern (05-391-0 to 3)" to
check if the low-density pattern abnormality occurs for each color. The values under 320 for Y, M
and C, and under 220 for K are defined as low-density pattern abnormality.
(3) Check "Output value display of image quality sensor / High-density pattern (05-390-0 to 3)" to
check if the high-density pattern abnormality occurs for each color and identify the color which
pattern is abnormal. If the value is 630 or above, it is defined as high-density pattern abnormality.
(4) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image
quality closed-loop control / Laser power (08-557)" to "0" (Invalid).
(5) Perform "Enforced performing of image quality open-loop control (05-394)".
(6) Output the image quality control test pattern (04-270) more than one time and check the patch of the color identified in step (3) to see if the image is abnormal.
(7) Replace the image quality sensor.
(8) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image
quality closed-loop control / Laser power (08-557)" to "1" (Valid).
(9) Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it is
completed normally. (Error [CE40] does not appear.)
(10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576).
Good Luck
Regards
Apr 12, 2011 | Toshiba Office Equipment & Supplies
C-0F32 FOR KONICA MINOLTA BIZHUB C350
Abnormally low toner density
detected Magenta ATDC Sensor
T/C 0.21 % or less is detected ten consecutive times
in the Developing Unit as validated through the toner
replenishing amount determination control.
Check Developer unit, check toner supply ratio in the service mode, under Image Process control and make sure that Toner motor is sping and adding toner into Dev. unit.
Also check and see if you have enough Developer. clean ATDC sensor and run Image Quality adjustment
Apr 13, 2010 | Konica Minolta Office Equipment & Supplies
I have just purchases a 8018. It is default set at 3 mp. I have downloaded the manual and followed the instructions to change mp to 8. However, when the camera is turned off it goes back to 3. Is this...
15
Image Size
The image size and quality setting determines the number of photos that can be saved and the amount of
memory required for each photo. The higher the photo quality the more memory it will use up. The image size
and quality will also affect the maximum size you can print your photo effectively. To set the Image size:
1. Press the Menu button.
2. Press Right/Left button to select the Image Size mode.
3. Press the Up/Down button to select the desired image size.
4. Press the Menu button to confirm, save and exit to standby mode.
If this still doesn't work, press the menu button twice.
Jan 29, 2010 | Vivitar ViviCam 8018 Digital Camera
Canon mp780 is stuck on fine mode and it will not
yes, first change the paper setting button to normal, then you can lower the image quality on copies.
Nov 10, 2009 | Canon PIXMA MP780 All-In-One InkJet...
How was EVF improved?
This camera is equipped with the TFT micro display which has about four times the resolving power (number of pixels) of past models. As a useful mode, it has "Quality mode" of 640x480 pixels (30fps) and "Motion mode" of 640x480 pixels (60fps). Quality mode: The high resolving power is the most important. The detail parts can be recognized, and it is helpful when the focus is checked. Difficult focusing on the past models can be easy without enlarging. Motion mode: It is for recording the moving subject. The same number of resolving power is displayed as the quality mode. However, as the pixels are interpolated from 640x240 to 640x480 in Motion mode, the image in the Quality mode looks better.
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
Amount of images
Sep 01, 2005 | Olympus Camedia C-40 Zoom Digital Camera
Difference between MPEG2 and MPEG4
To achieve MPEG2 video performance, large amounts of data must be written to the SD Memory Card in real time. The read and write speed of the SD Memory Card may differ from manufacturer to manufacturer, so we recommend using Panasonic SD Memory Cards with the high-speed transmission rate of 10MB per second (SD Memory Cards that are 256MB* or higher have a transmission rate of 10MB per second). * FINE Mode recording (High image quality 704 x 480 pixels) recording requires an SD Memory Card that is 256MB* or higher. * NORM Mode recording (Normal image quality 352 x 480 pixels) recording requires an SD Memory Card that is 32MB* or higher.
Sep 01, 2005 | Panasonic SV-AV50 Digital Camera
Video and still image - SD Memory Cards
To achieve MPEG2 video performance, large amounts of data must be written to the SD Memory Card in real time. The read and write speed of the SD Memory Card may differ from manufacturer to manufacturer, so we recommend using Panasonic SD Memory Cards with the high-speed transmission rate of 10MB per second (SD Memory Cards that are 256MB* or higher have a transmission rate of 10MB per second). FINE Mode recording (High image quality 704 x 480 pixels) recording requires an SD Memory Card that is 256MB* or higher. NORM Mode recording (Normal image quality 352 x 480 pixels) recording requires an SD Memory Card that is 32MB* or higher. *Usable capacity will be less. The use of SD Memory Cards other than the ones mentioned above may result in the following error message: [This card cannot record in MPEG2 mode.]
Aug 31, 2005 | Panasonic D-Snap SV-AS3 Digital Camera
Quality mode
Aug 31, 2005 | Olympus Camedia Brio D-230 Digital Camera
Quality mode setting
Aug 31, 2005 | Olympus Camedia Brio D-150 Zoom Digital...
Olympus Camedia D-40 Zoom Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
