Make sure your iPod is set to output the right kind of TV signal for your TV: NTSC or PAL. NTSC is primarily used in North America and Japan, while PAL is used in most European countries.
If you need to connect four mics, they should attach to the four XLR type connectors.
The terminal strip above is only for TWO mics.(#5 and #6)
For those you connect the SHIELD to the middle terminal of each under the "MIC5/6" labeled "GND". The each of the BALANCED microphone lines for the two extra mics go to the left and right terminal beside the respective GND terminal.
If you are looking to use the headphone jack on your ipod touch, you'll simply need a cable with two male 3.5 mm ends that will run you $2-20.
If you would like to control your ipod touch using the steering wheel, you'll need to either purchase the GM Accessory Personal Audio Link (PAL) or one of the dozens of aftermarket models. Be careful to choose one that exactly matches your audio system specifications or else you could lose use of your satellite radio or other features.
