I have a 42" Panasonic plasma model TH 42PA50A. It continually turns itself off after 20 minutes. I have had the power supply replaced, however the fault continued. The repairers could not replicate the fault in the workshop and sent it back faulty even though they had seen it fail in my home. The power to the house is good. I have tried different cables and power points.
  • mikeinoz Aug 24, 2008
    Additional information, the LED on the front blinks 4 times.
    Novelist:
  • 210 Answers
If it's a plasma, and not a rear-projection TV... try situating a floor-standing fan behind the TV, blowing over the back casing. (as hard and close as possible)
If it lasts longer, or doesn't fail at all, you know you have a problem with (probably) a transistor or two (or more!)
Bigger heatsinks or replacing the transistor(s) with higher heat-rated units can be the fix for that. (cheapest option first, but best option is to replace faulty transistors)
Posted on Aug 24, 2008
    Master:
  • 848 Answers
Did you check the inverter in your tv .........
    Genius:
  • 1,847 Answers
IF YOU HAVE TO UNPLUG THE T.V. TO GET IT TO RESTART, IT IS PROBABLY HIGH VOLTAGE SHUT DOWN. IT CAN BE THE FLYBACK TRANSFORMER OR POSSIBLE BE A SHORTED CRT.
DOES THE SET HAVE HIGH USAGE ON IT ? WAS IT A FLOOR MODLE ? IS IT WATCHED MORE THAN 4-6 HOURS A DAY ? YOU CAN DROP THE CRT BOARDS AND SEE IF IT STAYS ON. OR REMOVE THE HIGH VOLTAGE (RED ) LEADS OUT OF THE HIGH VOLTAGE BLOCK. MAKE SHURE YOU DON'T REMOVE THE ONE GOING INTO THE BLOCK. ONLY GOING OUT. ALSO CHECK FOR COOLANT LEAK ON THE BOARD. IF THE STK'S ARE ON A SEPRATE BOARD YOU CAN UNPLUG THE CONVERGENCE BOARD AND SEE IF IT STAYS ON.
  • Legin Varghese
    Legin Varghese Aug 24, 2008
    irst of all, you should try making sure in your menu that you do NOT
    have your timer set to shut off. You'd be surprised how many people
    call Zenith every single day and fuss at me because their tv is
    'broken' and they have a timer set. Secondly, it sounds to me like it
    could be an issue with your power supply. Does it turn itself back on
    randomly as well? Do you hear any popping sounds when it turns off?
    Check with your manufacturer to see what their repair warranty is.
I accidentally overheated my Panasonic Plasma TV TH-42PZ700U. It won't turn on, and the power button blinks TEN times.
Check and see if there are any blown caps on the power supply. If there are replace them or change your power supply.
Thank you
Mar 20, 2012 | Panasonic TH-42PZ700U 42 in. Plasma...
42 " panosonic plasma model th-42px6ou keeps
There is an energy save setting on your controls. Turn that off if you don't want tv to keep turning off while you are changing inputs. Hope this helps.
Oct 16, 2011 | Panasonic TH-42PD50U 42 in. Plasma EDTV
If you remove the back panel and check on the power supply board, you will find a couple of bulged caps that need to be replaced, or just replace the power supply board.
Jan 21, 2011 | Panasonic (TH-50PZ700U) Television
Help my 42 inch panansonic plasma tv will not turn on red light just blinks
Hi:
Replace or have the power supply serviced, the most common failure with panasonic plasmas is tthe power supply.
Dec 23, 2010 | Panasonic TH-42PZ700U 42 in. Plasma...
Got my hands on a Panasonic th-42px75u 42 inch but it won't turn. On is it worth fixing and how much would it cost thanks
The tv can be fix about half of the price of a new one.This tv brand and model known to have alot of power supply board issues.The price about between $500-$550 Tech. replaced tv with a new refurbish power supply board replacement or troubleshooting and by replacing components parts on the power supply board.
Dec 07, 2010 | Panasonic TH-42PX75U 42 in. Plasma...
My 42in panasonic plasma viera blinks 10 times and will not turn on
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 02, 2010 | Panasonic TH-42PZ700U 42 in. Plasma...
No power
I would guess it's the power unit for the TV itself.
If it's still under guarantee I would have thought you should be able to get it replaced.
Feb 19, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
My panasonic tv got problem
when it is warm, shut off, then after take a rest it will automatic on again, probably you need change the on anf off switch.
How long have you had the TV?
Jul 10, 2008 | Panasonic TH-42PX75U 42 in. Plasma...
Panasonic th-42pa20 plasma 42 inch tv
Try to replace the Main Power Supply board first.
Dec 29, 2007 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
TH-42PA50A - power supply problem
Ok,Sounds Like A Board Failure,Main Board,If you Have an Extended Warranty,Look for the Closest Warranty Station to you....Not an Easy Fix ttech
Jul 29, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Electro Med Services...
