Unable to delete
Whenever i try to delete recorded programmes the machine freezes. i press blue ot delete but nothing happens
  • marie_beech Sep 11, 2008
    a thompson one, not sure of make or model
    Problem Solver:
  • 8 Answers
What DVR do you have?
Posted on Sep 11, 2008
Unable to do anything!!!
In what state is the unit? Is everything else functioning asides from what you posted?
Feb 02, 2008 | JVC DR-MX1S DVD Recorder/VCR
I recently purchased the Toshiba DR570KU DVD recorder. I live and purchased this machine on a small Caribbean Island,and with respect to local people they have no technical knowledge of what they are...
Hi -
I'll try to explain without confusing you any further, but if anything doesn't make sense, please let me know. The instructions on page 79 are contradictory, which doesn't help very much. The upper part of the page suggests you can create extra space on a DVD+RW disc by deleting titles, while the lower part, in the grey box, states you cannot. The bottom part is actually correct.
I'll split this into two sections - blank/unused and used discs then explore a few scenarios.
Blank/unused discs
A DVD+RW is typically 4.7GB and will record approx. 2 hours of video in SP mode or 4 hours inLP mode. If you record more than one programme, they will appear consecutively in the disc editing menu, and shown as numbered blocks in the Title List. The last block shown will always be 'EMPTY', but the actual size of this block can be all or none of the total capacity of the disc.
If you insert a blank DVD+RW disc into the machine and view the title list, you will see this:
Although you can't 'record' to a block labelled EMPTY, this doesn't mean you cannot record to this disc. The blank space on the disc precedes the block labelled as 'EMPTY'.
If you then record one programme of 1 hour duration in SP mode. the title list will look like this:
Once again, although you can't 'record' to the block labelled EMPTY, this doesn't mean this disc is full or that you cannot record anything else on it. The next programme recorder will appear between title 1 and the 'empty' block - as long as there is sufficient space on the disc remaining to record the programme.
If you then record a second programme of 1 hour duration in SP mode. the title list will look like this:
This disc is now full as 2 hours of video has been recorded in SP mode. However, if you'd only recorded 1 hour in total for these 2 programmes, you would still be able to record another hour of video in SP to this disc. The additional programmes would appear between the last numbered title and the 'empty' block - until the disc is full.
The empty block is always present and you cannot 'get rid of it', but it doesn't mean the disc is full or cannot be recorded on.
Hopefully, this goes some way to explaining it, but I still need need to explain what happens with used / full discs when you want to delete programmes and re-record.
There is a maximum length for messages posted on FixYa and I may be getting close to this, so rather than break off in mid-flow, I will continue the explanation for used discs in another message below this one. I will do this right now, but it will probably take me 20 minutes or so to write part 2, so keep checking back. It will be less confusing if you hold any questions until I've written part 2, but I will be happy to answer any after that.
Regards,
BElectric
May 02, 2011 | Toshiba DR570 DVD Recorder
DRT400 TiVo 40-Hours Video Recorder: unable to delete programmes...
Do a complete CLEAR and ERASE.
This should fix the problem.
May 18, 2010 | Humax DRT400 TiVo 40-Hours Video Recorder
Recording fails to delete
Record another programme so that you have something above the dodgy one in your library. Then go back into your library and press down, blue then green really fast. This worked on mine.
Jan 02, 2009 | Philips DIRECTV H20 DTV Receiver
Thompson recordable freeview box
It's probably a corrupt file. Probably the first one in your library.
What you need to do is go into the library and quickly delete that file.
You need to press delete and confirm before it has had time to notice the file is corrupt.
I think it's green then blue, might be blue then green. I forget.
BTW, If anyone out there knows how to make use of the USB port on these things, can you let me know?
Oct 15, 2008 | Televison & Video
My Thomson freeview recorder box wont let me record anything as it saya that my drive is full but it freezes when i try to delete some of my recordings
Marriott, You will find that it is only one recording that is causing this. This also happens to my box as well when we tape emerdale on a Monday. look through what has been taped and find out if the minutes used is correct for that programme. if not then you need to do the following in very quick procession.
Press the delete button and confirm as quickly as possible when you scan down the the programme that has not recorded correctly.
Hope this helps
Norrie
Oct 10, 2008 | Televison & Video
I have a DT16300-16. I dont use it for Top-up TV but the last few weeks it keeps recording programs from the Lottery Extra channel. I also keep receiving 3-4 minute recordings about top-up. I have had this...
The PVR you have has preset Top-up TV channels it will download from as a preset. You need to go into the main menu and turn off the auto update function of the machine. Then in your "TV Guide" menu find the particular channel and deselect it for download or recording.
The 3-4 minute recordings are commercials for their products and came with the last few auto updates, they're trying to sell their product.
A crash could be a sign of stress on the hard drive, most of these machines have craptastic hard drives that if even rattled or slightly moved while being recorded upon they die. If you're recording and deleting at the same time (with the age of the machine) I would not be surprised if it continued to happen. If it crashes when you do these things individually it is probably the same problem, or the firmware of the machine is corrupt.
Sep 17, 2008 | DTK PRM-0031I Motherboard
My washing machine is showing test
To Deactivate
Press the Start/Cancel button until all the console LED's illuminate.
Press both Start/Cancel and On/Off buttons together until
d OFF appears.
The default screen returns and you can select a new programme.
Note:- The default screen information displayed on these models is that of the programme currently selected by the selector knob.
Jun 02, 2008 | Hotpoint Ultima WF860 Front Load Washer
Frozen hard drive
If you have a Thomson DT16300, here's a handy fix that address freeze ups, lack of reception and problems on your Hard Disk:
goto MENU screen
goto SETUP screen
goto HELP screen
At HELP screen, Enter 1397 - this accesses the engineer panel - you can reformat the HDD in this menu - you will lose all recorded programmes and planned recordings but it clears locked or corrupted files
OR - at the HELP screen, press the GREEN button
On the lower half of the screen youwill see 3 options:
Blue - Reformat HDD - clears all the memory/HDD - useful if you have a corrupted file - you will lose all recorded programmes though
Red - reset the whole box to factory settings - good if you have a locked box or reception problems or cannto scan for new channels. It goes back to when you bought the box, so you will have to input favourites and planned recordings again
Yellow - Software revert - allows you to go back to the previous software driver - you may lose new functions, but you can always restore it back again using the same feature
Feb 15, 2008 | Thomson DPL909VD System
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
