Techwood TWP4210 Plasma tv
Good morning.
I have about a 1" thick black line running from the top to the bottom of my screen just off center.
Might you have a solution to this problem?
Thanks a million...
Carlyfarly
Ihave a black 30mm line in the middle of my techwood 42 inch screen from top to bottom the rest of the screen is ok . Could you tell me what I should do?
    President:
  • 1,623 Answers
A resistor has developed a dry joint or failed on the data connectors of the plasma panel,there are eight at the top of the plasma. An easy fix if you know what youa are doing,
Posted on Nov 06, 2009
    Novelist:
  • 110 Answers
Power off the unit and disconnect all video cables from it. When you come back up, make sure you are at a blue no signal screen. If the black line is there, then you have a serious issue that would require service.
If not, it is most likely and loose cable, or bad cable which needs to be replaced. It could also be the source (i.e. if it is only happenin watching TV, try a DVD to see if the issue persists
Posted on Aug 24, 2008
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
Techwood 42" plasma screen television
Do not turn this television on! Any electronic that smokes is NOT GOOD! The smoke and accompanying smell is from plastic and solder that is being melted by a short on one of the TVs logic boards. Call a local TV repair man this is not an issue you could fix yourself and will most likely be better off buying a new television. Stay away from off brands like these, spend the few extra bucks on a name brand like Sony, Toshiba, LG, or Samsung and you won't encounter these types of issues.
Feb 15, 2011 | Samsung SPN4235 42 in. Plasma HDTV
I have a inch thick black line down the center of my screen
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Aug 13, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
We have power and sound but no picture , i have
If an authorized service repair center will sell you one. However looking at the reviews you may just want to replace the tv since even service centers have issues repairing the tv.
http://www.comparestoreprices.co.uk/plasma-screens/techwood-twp4210-reviews.asp
May 07, 2010 | Televison & Video
Plasma color TV screen developed dense black vertical line
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Sep 21, 2009 | Hitachi SSH2442 Television
Black line on plasma tv
Jul 19, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Nec plasma tv 42MP4
these plasma vertical black lines are notorious. there's a video of a fix on this plasma tv repair site. good luck!
Jul 29, 2008 | Samsung PPM42S3 42 in. Plasma Television
Ted scaning elektronik tv service
I have a TWP4205[samsung display s42sd-yd05] end VMB 1110 tuner box for TWP4210[LG panel]Hou switched in service mode,for geometry settings...please!
Feb 22, 2008 | LG 42PX5D 42 in. Plasma HDTV
Hyundai 42inch plasma tv
If these are thick black lines, this is most likely line frequency noise entering the set. you may have a leakage from the DC ground on the secondary side of the powersupply to the AC side, or a bad filter capacitor(s). Most of the time it is the filter caps that give these types of problems. If you are connected to cable TV service, or an outside antenna you can also have this problem from an AC ground loop return. Also if there is a device such as a VCR connected to the TV and it has problems, it can cause this as well...
Mar 20, 2006 | Hyundai ImageQuest DPD4210 42 in. HD-Ready...
Televison & Video Logo
760 people viewed this question
Top Televison & Video Experts
