Question about Nokia N95 Cellular Phone
System error Ajkill, thank you very much for that advice. how do i reinstall the software? Do i do that using my USB cable i got with my phone and the CD software in my N95 Nokia pack?
    Genius:
  • 2,035 Answers
Use this software but i would recommend you consult tech support get the firmware to your phone:
Software/:
https://www.nokiausa.com/A4410967
Posted on Aug 24, 2008
How to flash an lg alley
Flashing the phone means reinstalling the phones operating system software files. The phone will be fully formatted and a fresh operating system files will be reinstalled.
You can use software updater to flash the phone. Download software updater from LG website. Install it on your computer, open the software updater, connect the phone via usb cable to your computer. Allow the computer to recognize the phone, then click update. Follow all direction from the software updater application. And your computer must be connected to the internet.
I hope you understand this.
Good luck.
Jan 16, 2012 | LG Cell Phones
Tip
My phone software suite does not install correctly on Windows.
This happens when the first installation of the software had not been successful .
What usually happens is that wrong system registry cannot be deleted when uninstalling software, or overwritten when reinstalling, therefore uninstalling and reinstalling the software does not fix the problem.
A bad setup happens often because you connect the USB data cable before installing the software, The firewall or security software had not been disabled, when you are asked if to allow a change to system during setup and you deny, when your account does not have administrator privileges, or when Windows has a problem.
What you can do is the following:
Unplug the USB cable.
Uninstall the software.
Do a system restore to a date before installing software for the first time.
Disable antivirus, firewall and security software.
Install again the software. Start software setup with USB cable unplugged.
On Vista, to start the setup, locate the installer file (eg. setup.exe or install.exe) and instead of using double click to run the file, click the right button of mouse and chose "Run as Administrator" from the dropdown menu.
Ensure that you always allow changes when asked by the system.
Connect USB data cable with device on when asked.
If that does not work, then Windows has a problem, in that case you may need to reinstall windows.
on May 23, 2009 | Samsung SGH-R225m Phone
Cant get SGH-G600 connected
When this happens, click Start and Control Panel. If you are in Category View, click Performance And Maintenance and then System. If you are using Classical View, double-click the System icon.
In the System Properties dialog box, click the Hardware tab and the Device Manager button. Next, look through the list of devices until you see Universal Serial Bus Controllers and click the plus (+) sign next to it. Double-click one of the USB Root Hub lines and click the Power Management tab in the USB Root Hub Properties dialog box. Click the Allow The Computer To Turn Off This Device To Save Power checkbox so it is unchecked. Click OK and restart your computer.
Mar 09, 2008 | Samsung SGH-D900 Cellular Phone
How to reset k850i...as it is showing an error to place original battery..although it is original .. :(
the problem is as a result of software corruption. Your phone operating system is corrupt for one reason or the other. The phone operating system might have gotten virus through bluetooth transfer, internet browsing or via the memory card.
To solve the problem, you need to flash the phone . Flashing the phone means reinstalling the phones operating system software files. The phone will be fully formatted and a fresh operating system files will be reinstalled.
You can use software updater to flash the phone. Download software updater from sonyerricon.com. Install it on your computer, open the software updater, connect the phone via usb cable to your computer. Allow the computer to recognize the phone, then click update. Follow all direction from the software updater application. And your computer must be connected to the internet.
Good luck.
Jan 05, 2012 | Sony Ericsson K850i Mobile Phone
How to reprogram nokia 5220 what software do i use thank's
If you need to reinstall your phones software you can use the Nokia Software Updater.you can download it directly from the following link.( http://betalabs.nokia.com/apps/nokia-software-updater).Install it on your computer and you need a broadband internet connection to proceed.Connect your phone via USB cable.Your phone will be automatically identified by the software.Never try to disconnect your phone unless the reinstalling is complete and the phone is restarted.Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 17, 2011 | Nokia 5220 XpressMusic Cellular Phone
Ajkill has suggested the perfect solutions guys jut follow that. <a href="http://www.exceltoner.ca/">ink</a>
We need to clear out these error codes stored in your printer NVRAM or memory! Shut down the printer and pc associated with it. Remove data cable and reinstall the software for this printer, press and hold the power button on the printer for 15 seconds, then reconnect the printer after software installation is successful. This process will clear the error codes that you keep receiving.
Jan 22, 2011 | Xerox Office Equipment & Supplies
System error e255
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
Sep 29, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
My all in 1 printer
Hi anna1973, please list the error you are receiving. What operating system are you using?
Mike
May 28, 2008 | Lexmark X2500 All-In-One Printer
CLP-510 SPL-C Error message
SPL stands for "Samsung Printer Language". You are using an USB cable that is either too long (above 6 ft.) or too thin (cheap cables).
The reason why the test page prints is because it is a very simple and small page (thinking on kbyte terms). But larger streams of data do not arrive correctly due to attenuation and the error page prints instead.
If it is absolutely necessary to connect beyong 6 ft, you need either a good quality USB cable (try the Belkin brand found at OfficeMax), or connect using a parallel cable.
Nov 01, 2007 | Samsung CLP-510 Laser Printer
Nokia N95 Cellular Phone Logo
32 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
