Question about Cell Phones
I turn on my n95 and it vibrates the keypad lights up but it will go no further and can only be turned off by removing the battery
My N95 does this too. I have a fix that will turn the phone on properly.
1st take out battery,
2nd press and hold power button,
3rd insert battery while still holding power button,
4th release power button as soon as your phone vibrates.
That works for me.
Posted on Jan 11, 2009
Nokia n95 keypad light not working
There's a light sensor in this phone, go somewhere where there's dark, the keypad light will automatically be switched on. Its just for better battery backup time.
Jul 27, 2011 | Nokia N95 Cellular Phone
Sim card removed battery Completely dead
plz check the battery,if it is ok then your phone needs to be serviced
Jul 23, 2008 | Nokia N95 Cellular Phone
N95 keypad lights are not working
There can be errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone pad light are still absent then the fault is in the hardware section , it can be failure of the drive to the LED or the connection to them check for moisture in the pads, if so dry the pad/board.Check the back light setting time dealy on the menu. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
May 12, 2011 | Nokia N95 Cellular Phone
N95 screen goes white
sounds like the software prob.most of these big multimedia phones crash and need to be updated by a repair shop.these have to be offical nokia updates.....but before that lift out your sim card and sd card and clean them,stick them back in and start it upagain.sometimes these get dirty
Sep 06, 2009 | Nokia N95 Cellular Phone
My phone won't turn on...
You need to take the phone to a mobile service center and have them fix it for you....it needs a new battery and have the mainboard diagnosed
Nov 30, 2008 | Sony Ericsson K800i Cellular Phone
Back Light
First, check that the something is actually displayed :
Turn off the phone then put it on charge.
Check to see if the NOKIA logo appears even if the display is unlit. (try angling the display towards a sunlit window).
Having charged it, try to turn it on.. Do you detect the vibration the phone makes when starting up?
If nothing is displayed but you get that vibration I suspect that the display is somehow damaged and you'll need to look at replacement.
You local nokia centre should be able to provide you with a quote for the repairwork otherwise if you're confident opening it you might be able to replace the screen with one obtained from here for example:
http://www.accessorylink.co.uk/search.asp?Action=search&Keywords=N95
Aug 26, 2008 | Nokia N95 Cellular Phone
Nokia N95, turns itself off, will not turn back on, disconnects calls and just about everything else. It is rubbish but I need it to turn on now so I can get my numbers and it will not turn on.
mine did this take the covers off unscrew the screws seperate the screen and the keypad blow on it all put battery back in try turn on if vibrates put back together if not put back together give to nokia care
Aug 15, 2008 | Cell Phones
Clear/Hangup Key randomly fires
if you have the hair dryer then just dry with that ...
be sure to remove the battery & do that ...
if you still persist the same problem then the keypad might have got stucked with the keypad sensor ....
so if you are good at opening the handset then just open it & remove the keypad & check near the keypad sensor is there any obstacle between it ...
if so clear it then refit the handset your problem will be solved ...
if your are not good at opening the handset then just try tapping the phone lightly ...
this solves your problem ...
any doubts reply me
i am always here to assist you
thank you
bye
dnt forget to rate the solution
Jul 01, 2008 | Nokia N95 Cellular Phone
My screen is upside down N95
leave the phone switched on and remove the battery and sim card . leave for 10 seconds then insert the battery with no sim , turn the handset on , after a while when the phone has fully loaded leave it switched on and then remove the battery again , leave for a further 10 seconds and then insert the sim card and the battery when you now turn on the phone you should see the problem has been fixed , if however you are still experiencing the same problems then you will have to contact nokia and get a warranty repair .
May 07, 2008 | Nokia N95 Cellular Phone
N95 not working
okay, when did this happen? did it happen right after a firmware update? trust me the same happened to me!! i "bricked" my phone, all mine did was display a faint nokia logo and nothing else, and it would slowly turn of after the battery was removed!! if you could tell me when/why/"after what" did it do this? but don't panic! i got my phone fixed next day as it was under warranty free of charge, as long as you haven't played with the interior or faffed about with the settings or poured any thing on it u should be fine!
ill keep in touch as soon as u tell me more info!!
Jan 01, 2008 | Nokia N95 Cellular Phone
Cell Phones Logo
91 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
