Question about Electrolux 18 in. ESL4114 Slim-Line Built-in Dishwasher
Dishlex Global 500 dishwasher
My dishlex global 500 dishwasher has stopped working. There is a noise but no water being pumped it just remains stuck at this point with nothing happening. Have tried disconnecting and resetting but this didn't work. Any suggestions ?
  • alltime Sep 12, 2008
    Thanks for the advice, appreciate it. I did finally get a technician to come and check it.
    There was a burnt out microswitch below and it was caused by a leaking pump pipe
    that had shorted it out.
  • thomasstreet Oct 01, 2008
    When the machine is switched on there is a whirring noise but no water is pumped in and the ECO light is flashing. I have tried switching on and off with no change.
Theres a round plug in the top of dish washer pull it out and clean could be cloged or the bottom spram arm can be pulled out and cleaned aswell
Posted on Sep 12, 2008
Dishlex global300 is gone into flood mode how do I fix it
Dishlex Global 300 Dishwasher issues - Kitchen - Home - Whirlpool ...
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolAug 31, 2011 - As stated in the title, it is Dishlex Global 300 model and it was here when ... is flooding about to happen inside the DW and prevents flooding). Bosch or Asko dishwasher
Mar 7, 2014
Dishwasher that actually WORKS PROPERLY?
Dec 3, 2012
Dishlex Global 300 dishwasher woes
Aug 8, 2005
Dishwashers ...
Mar 28, 2004
More results from forums.whirlpool.net.au
Nov 25, 2015 | Dishwashers
Detergent dispenser not opening
try taping on the lid a few times,it will be stuck tru to many detergent
Jul 26, 2012 | Dishwashers
Dishlex global 300 just installed new pump now wont fill up just stuck on drain
make sure you have the hoses attached to the water supply usually hot water under your sink.
Jul 06, 2010 | Dishwashers
Dishlex global 500 dishwasher says ''of '' . It will not stop making weird noises. I Have had to turn it off at the wall.
Hi there.this is (over fill error).It has over filled & flooded water down into the base.It has tripped a flood switch in the base wich turns the drain pump on even though the washer is off.You can simply try tipping the washer to get the water out or you will need to disassemble the front kick panel at the bottom front to mop out the water.The switch will reset after you do this.Or wait a couple of days and the water will evaporate enough that the pumping will have stopped & the washer should work again.The booklet for your washer has water hight level settings in it.Sometimes someone leans against the washer and presses the buttons wich changes the water level to high & thats why this has probably happened in the first place.It may need setting to a lower level.
Jun 04, 2010 | Electrolux Dishwashers
Dishlex global 300.... The normal light starts flashing mid wash
i think it means the water heater in the dishwasher is not working,or the element is shot.
my 300 had a burning smell before the light started flashing.
Feb 07, 2010 | Electrolux Dishwashers
Dishlex Global 300. Eco light flashing and nothing happens.
could be the water inlet valve or solenoid
Jan 25, 2010 | Dishwashers
I have a dishlex Global 500 which runs for 3-5 minutes then displays nF
nf= not filling. check inlet vale, or fault will be with pressure switch. If you have poor water pressure, you may need to increase the fill time- insructions can be downloaded from:www.electrolux.com.au, click on "customer service", then "download manuals", then Dishwashers-semi integrated, electronic, then download Dishlex Global Part 1 and Part 2.
Information on setting fill time can be found at the back of Part 2, but Part 1 has a list of the fault codes
Aug 05, 2009 | Dishwashers
Dishlex global 500 rinse and wash problem
This was due to a faulty pump motor which I have now replaced.
Jan 10, 2009 | Dishwashers
Global 300 Dishlex draining problem
is the float switch clear of debris so it can go down to its lowest point to shut off the pump,, a peice of food could be stuck in it, keeping it up just enough to keep it running
Jan 03, 2009 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Dishlex Global 2000 starts makes a constant noise tries to start up then stops. Bit of water in the bottom of the dishwasher. Lights flash but does nothing
have you checked that your outlet pipe is not blocked. if it is blocked machines are designed to stop to prevent flooding. this may explain why there is water in bottom
Sep 03, 2008 | Dishwashers
Electrolux 18 in. ESL4114 Slim-Line Built-in Dishwasher Logo
1,372 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
