Question about Canon PIXMA MX310 All-In-One Printer
Printing problem only abe to print part of the page
    Novelist:
  • 110 Answers
Try this
1. Click on START, CONTROL PANEL, PRINTERS AND FAXES (or PRINTERS AND OTHER HARDWARE).
2. Right click your printer, and select PROPERTIES. (If your printer is not listed, click on VIEW INSTALLED PRINTERS first).
3. Select the ADVANCED tab.
4. Select PRINT DIRECTLY TO THE PRINTER.
5. Click on APPLY (if applicable), then OK.
6. Restart your computer.
7. Try printing now.
Posted on Aug 24, 2008
Reverseprinton hp2540
this unit prints one side of paper only
to get it to print 2 sides when you go print on a document thee will be a section that says print all pages , print this page ,print elected pages
in the print selected section type in the pages you want to print ie 1,3,5,7,9 or even pages 2,4,6,8
or there may be a section that opens up with print all pages, print odd pages ,print even pages
to print both sides select odd pages and when they have printed take the whole of the pages and reverse them in the printer feed and then select even pages and print
the operators manual will explain how to do ti.
Feb 15, 2015 | HP Deskjet 2540 Wireless Color All-in-One...
1/3 of page blank when print, or copying
Hi Abe,
1) Press the Ink button -> Test Print -> then choose Print Quality -> the printer will then go through and print a series of small squares in each of the four colors in the shape of parallelograms. If you see any gaps in parallelograms then you will be asked asked to clean the cartridge, do so. -> Just keep repeating process until there are no gaps
2) Then I did an Alignment check right after the cleaning through pretty much same process:
Press Ink button-> Test Print -> then choose Alignment-> and make sure the patterns match to the closest number
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :Brother Printer Support
Feb 10, 2014 | Brother MFC 7420 All-In-One Laser Printer
I have a printer thats printing on one side only. how can i fix this
Do you mean double sided printing? If so this model printer does not have a duplex unit and cannot print double sided prints automatically.
DOUBLY SIDED PRINTING WITHOUT A DUPLEX UNIT
Open your Word document.
Open page 1 - then Print the current page.
Then put the printed page 1 back in the paper tray upside down.Open page 2 and Print the current page (page 2 will beprinted on the other side of the page 1).
Repeat this procedure for the other pages.
Jun 15, 2012 | Brother Office Equipment & Supplies
My smart label printer 100 is backing up at times when I try to print a label and doesn't print right, it skips letters or numbers and continues with the rest of the info. Like abcde will be abe
This skipping could be caused by a roller not turning causing the paper to be forced to much into the thermal.
Repair is quite difficult the unit would need to be taken apart and the feeder investigated. You could put some machine lube on the roller part, but its quite involved.
Another reason could be the module inside not working correctly causing it to print like it is.
If you update me with additional info I could be more of a help to you.
Regards,
Rulds2008
Jul 21, 2011 | Seiko Smart Label Printer 100 Thermal
I have a pixma mp630 and i want to print just one page from multiple page in a document how can i do it?
Move the cursor to the page you want to print. Then click File - Print then in Page range select Print Current page - then click OK to print.
May 04, 2011 | Office Equipment & Supplies
Can only print 1 page off of a website page. Why
first see the print privew of the web page if the page is heaving more then one page you will get the all page print...... the print will take the current opened page print not the internal pages or sub links pages.............
Nov 06, 2009 | Dell Office Equipment & Supplies
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
Mfc 210
if the MFC is a brother..your print head could be dead.
Jun 21, 2008 | Brother MFC 210C All-In-One InkJet Printer
Prints extra blank page for every one page of printed material
hi,
try this
> unplug the usb cable from the computer
> click on "start--> control panel--> printers and faxes"
> select the printer icon associated with your printer and delete it.
> now plug the usb cable to the printer
> wait for few minutes while all the drivers are installed.
thats it... now try to print... it should be resolved
thanks and regards
agnel
Mar 17, 2008 | HP Photosmart 2710 All-In-One InkJet...
Canon PIXMA MX310 All-In-One Printer Logo
20 people viewed this question
old marine
old marine
Corne Viljoen
