Question about Cell Phones
I can't remember my unlock code (like keyguard - 4 digit) on my kyocera cyclops
  • Anonymous Mar 26, 2014
    unable to hard set, rest a kyocera cyclops flip phone
Forgot my security keyguard code how do i unlock it
Posted on Dec 17, 2008
Try the last 4 digits of your phone #.
Just a guess
Posted on Sep 13, 2008
Unlock keyguard
phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Jul 31, 2012 | Cell Phones
Bypass 4 digit lock code for kyocera s1300 qualcomm 3g cdma phone
You will need to call your cellphone provider. They should have a way to unlock it.
Mar 02, 2012 | Cell Phones
I put a lock code now I forgot. It and cantget in my phone.
Messages & Display Issues: The display on my phone reads "Locked" or "Keyguard"
  • If you see the word "Keyguard" on the display of your Kyocera phone, you may have activated the keyguard feature. Press button below "Keyguard," then press 123 or the "OK" key to unlock the Keyguard feature. The phone will display "Keyguard Disabled."
  • Some Kyocera phones also have the phone lock feature available. If the phone lock was activated, the default lock code is 0-0-0-0 (4 zeros). When your handset is programmed with a mobile number by your Mobile Service Provider, the default lock code will change to the last 4-digits of your mobile number. To change your handset lock code, you must go to the Security menu, then select Menu > Settings > Security > Current 4-digit lock code.
  • May 03, 2011 | Kyocera Jax Cell Phone
    Ihave a kyocera phantom cell phone i cant remember unlock code
    go to nearest kyocera service center and unlock
    Aug 26, 2009 | Cell Phones
    Nokia 6301b Security Keyguard code unlock
    You can contact Your local cell phone shop that sells Nokia they will be able to tell you how to unlock the phone. If they can't do it over the phone it can be reset by a phone tech,
    Aug 06, 2009 | Nokia 1100
    NOKIA 1112 need keyguard code
    well u can open it only i mean access for thay reason just prees left upper key for 2 sec then the * will appear on screen just press star at that time but remember u yave only 1 second to press the star further for permnent code u have to refresh the software...
    Mar 25, 2009 | Nokia 1112 Cellular Phone
    ENV2 Keyguard Lock problem
    When your phone is closed, hit OK for the menu, then hit 6 for Keyguard Settings. There, you can not only change the time it takes for the keyguard to automatically go on, but ALSO change the keyguard unlock options from One Step Unlock (just hitting ok) to Two Step Unlock (hitting ok then clr). It's not a 4 digit code, but it's a lot better than just hitting ok, and much more time efficient than locking your phone every time you put it in your pocket.
    Oct 21, 2008 | Verizon Communications enV2 Cellular Phone
    Keyguard
    if you just need to lock the phone temporarily just hold the pound button for about 3 seconds and it will turn on key guard without changing settings.
    Sep 19, 2008 | LG enV VX9900 Cellular Phone
    Locked cell phone keypad
    first, take out the battery and press the RED end call key for 15 seconds, then put the battery back in and turn on the phone.
    if that doesn't work then try this from the website.
    How do I lock/unlock the phone's keypad? To lock and unlock your phone's keypad, press and hold the left navigation key.
    Or, select Menu -> Settings -> Keyguard. Then highlight either of the options and press the OK button. You can set your phone to lock the keypad immediately, or automatically if no key is pressed after 30 seconds, 1 minute, or 5 minutes.
    To unlock the keypad: Press 1-2-3 in that order."
    good luck!
    Apr 15, 2008 | Kyocera K10 Royale Cellular Phone
    How to unlock your keyguard on your phone
    Assuming you're trying to get past the keyguard on the outside screen, simply hit the "Ok" button twice
    If you want to turn the keyguard off alltogether, go (using the outside screen, this is a must) to: Ok > Settings&Tools > Keyguard Timer > Always Off > Ok
    That should do it.
    Nov 09, 2007 | LG enV VX9900 Cellular Phone
    Cell Phones Logo
    298 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
