Question about Canon PowerShot A70 Digital Camera
Battery Problem My 18-month-old Canon A70 is giving "change the battery pack" message and turning off constantly, even though I have fully charged three different sets of new rechargeable batteries and rotate them as soon as the message comes on. Sometimes with this message I pull out one charged set and put the same back in, and it works fine for quite awhile, then repeats later. I imagine this is a problem in the camera battery power circuit or something. Never happens when plugged into the computer. Any suggestion what to do or where to go?
  • try2help Oct 18, 2008
    I cannot get my A70 to recognize ANY batteries - fresh, new AA batteries, freshly recharged AA NiMH batteries. I even bought a new charger! I know this is an older camera, but it has served me well, and I hate to get rid of it because of battery problems. Any suggestions?
    Sergeant:
  • 255 Answers
I figured out the problem. My AA battery recharger was not making good contact, so although it said the batteries were recharged, this was not the case. After fixing this and getting full recharges, the problem went away.
Posted on Aug 31, 2005
I have just replaced the battery pack in my Canon SX 200 is camera. The battery was bought from a camera dealer, therefore not counterfeit, but when I turn on the camera it asks me to replace the battery...
Mostt batteries have an issue of SHELF LIFE and so if the battery that was given to you was on SHELF for a long time then it can develop BACK EMF and so will not charge to the limit designed. So check the date on the pack and if this is more than 6 months ago , it is better to claim for a refund or replacement. If your camera did not have any other issue this is the only possibility.
The first charge also must be done for 8-15 hours.
Jul 16, 2011 | Cameras
When I plug in the adapter to the charge the consol the orange light lit. The light does not turn off even after 13 hours of charge. After 13 hours when I want to use it, the red light comes on not the...
Hello there. You may need to replace your battery pack, as leaving it charged for over 4 hours can lead to "overcharging" a condition which can dramatically shorten your battery packs lifespan and charge retention.
Also, be sure to charge your console while the device is turned off. Although you may charge it while it is powered on, it will take longer.
As stated, be sure not to leave the system on charge for more than 5-6 hours, as this can damage the battery and is liable to cause battery leakage, burning, or overheating.
Battery life is largely dependent on the game being played - some games can give you up to 10 hours of battery life, though the real-world estimate is really more like 5-7 hours of constant use before you'll need to recharge.
I hope this helps you. -
Frankie.
May 11, 2011 | Nintendo DS Lite Console
CAMERA MESSAGE SD790 IS
Well, I haven't used a Canon PowerShot SD790 IS Digital Camera before, but I want to suggest this: before you start thinking of putting your camera apart, try to clean the battery terminals and the battery contacts of the camera with clean white paper, then reinsert the pack. Please be very careful when doing this so that you do not break or bend the contacts or terminals; they are usually delicate material.
Apr 18, 2010 | Canon PowerShot SD790 IS Digital Camera
Camera is 3 years old. Lately I take a picture
All the battery have a life time fixed working hours. Your battery is charged but he complete is working time. Thats why these msg will come. Dont warry use the battery when you see the power going down after a while of charging then change the battery and buy new 1. Good luck.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Canon Powershot SD450 / IXUS 55 Digital...
Canon IXUS 100is battery pack problem.
Happened the same with mine. At the beginning I tough it was related with the sd card as when I removed the card the camera would turn ON. Later on I found it to be related with the camera contacts. After cleaning the battery contacts with alcohol and a cotton swab it started to work fine. SOLUTION: Clean battery gold contacts.
Oct 12, 2009 | Canon PowerShot S90 Digital Camera
I have a Canon SD1000 battery pack issue.
I have a Canondigital ixusi which had the same problem and I purchased three new batteries, but found that all of them showed the "replace battery pack" message when fully charged. I have solved this problem by cleaning all the terminals on the batteries and in the camera very thoroughly with alcohol and Q-tips. Even though the terminals look completely clean, there must be a slight film which is preventing good contact. The contacts in the camera are spring loaded and I suspect they are not making a very good conection to the battery so any contamination is making a high resistance to the flow of electricity. Hope this helps - it worked for me.
Aug 10, 2009 | Canon PowerShot SD1000 Digital Camera
Canon SD950 IS malfunctioning - please advise
I have vertical bars apperaing on my Olympus SP-560,
In my case I know it has been caused by damp on the light sensor behind the lens, which once dried was better. But ideally I need to remove the lens to clean the sensor. Which I've still yet to work how it is done.
Oct 04, 2008 | Canon PowerShot SD950 IS Digital Camera
Xti wont power up
appears to be a defect and not user serviceable.
sorry for the news.
good luck.
mark.
Nov 25, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon PowerShot A70 Digital Camera Logo
328 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
