Question about HP Computers & Internet
Sd card 2GB and above is not detected by the card reader on my hp pavilion zd8303ea
  • victorewrigh Aug 24, 2008
    The card reader is built in and I have upgraded drivers for it as before it did not recognise any SD cards. Now it does recognise cards up to 2GB but not cards above this. I can only assume that it must be a driver issue and as the memory of SD crd becomes greater the reader cannot recognise them.
    If anyboby else has had this problem and fixed it I would appreciate to know how.
  • 42 Answers
How about 1GB?
does it detect?
try to plug in another pc, if the pc can detect, means your card reader is something wrong.
You're using a build in card reader or usb cable one?
if you're using the build-in, better ask the computer shop staff to change it.
if you're using a usb cable one, just try another card reader.
if still the same, change a new one.
Posted on Aug 24, 2008
  • 106 Answers
TRY IT IN USB 2.0 PORT
What sd ms xd reader driver is best to download for HP Pavilion Slimline s5122f?
Any USB memory card reader that supports your memory card is OK. Most USB memory card readers will support serveral SD memory card types.
Sep 10, 2011 | HP Pavilion Slimline s5122f PC Desktop
I just got the sandisk 2gb micro sd memory card and i was putting it in my computer after i put it in my computer nothing happened am i doing something wrong or is there something i got to download...
The most common possible issue may be that you don't have the necessary drivers for the built in card reader (I'm assuming the card reader is internal ). If this is the case, simply go to your manufacturer's (of the computer)drivers and support page, find the model of your computer, and download the appropriate drivers for the card reader, and this should resolve the issue.
Also, try the SD card in another computer or camera and verify that it in fact does work, if it fails, return it to the store for another one (hope you kept the receipt ;))
Jul 28, 2011 | SanDisk 2GB microSD Memory Card
Hp a720n put a sd card in and it doesnt read it or if u click my computer it doesnt show up need a driver or something to fix it where can i find it i went to hp website but could find a driver
I had the same problem. Turns out that the SD Card reader will only recognize cards with a capacity of 2GB or less. It won't read my 4GB or 16GB cards, but will read my 2GB and 8MB(!) cards.
Jan 11, 2011 | HP Pavilion A720N PC Desktop
Hp pavilion pc sd card reader not working i
vista just had a update for the SD card reader. Go to Microsoft website and update the driver. FYI Vista is also known for having some problems with the SD card readers in the past
Jan 03, 2010 | HP Pavilion dv1000 Notebook
I have a 4gb sandisk micro sdhc with adapter and the computer freezes when i have it in the sd drive.I have a hp pavilion a1 a1203w. Is there anything i can do?? Please Help
I had a similar problem not long ago. The SD and SDHC standards are different. SD only goes up to 2GB, and SDHC (high capacity) goes higher than 2GB. THe problem is that SD card readers aren't capable of reading SDHC cards, even though the card will physically fit into the card reader slot. When you insert an SDHC card into an SD card reader, the reader attempts to read the format, and locks up the OS while trying. You'll need to get an SDHC card reader and use it separately like through a USB port or something.
May 13, 2009 | Computers & Internet
Sd reader trouble on HP laptop
Does it show up in My Computer? That is where it usally resides as a removable drive.
Mar 17, 2009 | HP Pavilion dv5000t Notebook
HP Pavilion ZD8000 Digital Media Reader Issue
Try updating you drivers for your digital media reader. Also check your dcos to see if the DMR will read a 2GB card
Jan 11, 2009 | HP Pavilion zd8000 Notebook
Sd Card reader not recognising SDHC cards
When You Insert your SD card into the internal card reader, then the SD card is not recognised by the system and the SD card drive doesn't show there. The problem can be because of driver issue, system issue and device issue.
To fix the problem you need to go at device manager if there is a yelllow sign in SD card controller, the problem is most probably caused by a driver issue. Then you need to update the driver. You can also download the driver for your card reader.
Also, check if your SD Card is broken. You can also check it into different devices port.
If it is detected then you can backup of your data.
If the problem not resolved by any means and you require you SD Card data then I will suggest you read - https://www.stellarinfo.co.in/services/removable-media-recovery.php
Mar 03, 2017 | Computers & Internet
SD card reader
1) There is SD card reader on pavilion dv 1000, so you need adapter in which you insert mini SD card to make it SD
2) If you have that adapter, check adapter. Maybe it's broken.
3) If your card is biger, like 2GB or higher you may try updatenig drivers (I read on one web page: " There was a software update for support of reading and using higher memory SD cards, for my pavilion ZV5000, on the HP Software update website." )
May 31, 2008 | HP Pavilion dv1000 Notebook
SD Card Reader won't work?
have you tried other sd cards before or is this the first time?
if you have and its just this time it hasent make sure its working in your camera or mp3 player or where ever it came from :-)
if it works have a look in your device manager to make sure there are no problems with the drivers.
1 start
2 control pannel
3 system
4 then the hardware tab and click the device manager.
if there are anyproblems there is useually a little symbol next to the device just double click on it and have a look for the error code.
if all else fails try reinstaling the driver for your card reader or find an updated drivr download.
hope this helps
Dec 07, 2007 | HP Compaq nc6230 Notebook
Computers & Internet Logo
54 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
